sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4045 Location: Deep In My Own Psyche
Posted: Thu Mar 07, 2024 12:46 am Post subject: Re: What did you do for your Type 3 today? |
Move it to the house
Getting ready to finish front end _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Scotty D Samba Member
Joined: February 08, 2020 Posts: 254 Location: Claremont CA
Posted: Wed Apr 24, 2024 2:00 pm Post subject: Re: What did you do for your Type 3 today? |
Steering wheel swap.
highwheelerboy22 Samba Member
Joined: July 10, 2010 Posts: 28 Location: Rockford TN
Posted: Sat Apr 27, 2024 7:41 am Post subject: Re: What did you do for your Type 3 today? |
Cleaned bumpers up, window tracks and regulators were cleaned and greased/oiled. Mufflers were cleaned, painted, and polished. Put on the missing clamps. Got the fuel sending unit in and got the gauge working. Adjusted vacuum modulator. Drained and changed ATF, installed correct window cranks arms. Next are door panel clips and vapor barrier behind door panels and repray wheels silver.
oldskoolsteve Samba Member
Joined: July 01, 2007 Posts: 89 Location: Vancouver Island Canada
Posted: Thu May 23, 2024 11:32 am Post subject: Re: What did you do for your Type 3 today? |
finished my rear brakes.
bled the brakes.
Made a new accelerator cable.
pulled the starter to bench test it.
my list to fire up dwindles... _________________ 63 Type 3 1500 notch
84 WESTY: Suby EJ22 powered
85 WESTY: needs engine and trans
Hoodride for life |
Posted: Mon Jul 08, 2024 1:54 pm Post subject: Re: What did you do for your Type 3 today? |
After fault diag. for a spark issue, I chased the problem to the o.g. big cap distributor. I believe its worn so I bought a 009 locally and installed a 6 volt electronic ignition and it fired right up.
Was then able to adjust and tune the new dual carbs and got it running fairly good.
Still having rear brake locking up issues after a good drive that I believe to be the flex lines, new on the way.
All in all it took two and a half months to get driving again for the first time in 7 years...but made the local show last Sunday and that was the goal.
Now I can really start working on it... _________________ 63 Type 3 1500 notch
Hoodride for life |
papichuito Samba Member
Joined: July 28, 2009 Posts: 166 Location: Radcliff, KY 40160
Posted: Tue Apr 29, 2025 4:38 pm Post subject: Re: What did you do for your Type 3 today? |
I sanded and painted the wiper arms. Oh and reinstall them _________________ Jesus Roman |
