kheberling Samba Member
Joined: August 19, 2013 Posts: 26 Location: Bethel, PA
Posted: Tue Mar 19, 2024 1:17 pm Post subject: 1962 Ghia Turn Signals |
I am restoring my 62 Ghia, converted to 12 volt with new harness and testing with a battery charger set to 2 amps which works well. I have everything working, horn, brake lights, headlights, radio, dash lights, Parking lights, ut cannot get the turn signals to work. I have a new 12 volt flasher unit, 49 goes to fuse box for power, 49a goes to the turn signal on the column, other turn signal goes to led and right T object wiring, 49a also goes to the indicator light on the speedometer, 31 goes to a ground on the speedometer housing. When connect charger to power the relay clicks with key off and buzzes if I move the turn signal lever to engage left of right signal. Signals will not flash. Also right rear driving light will not light on parking mode but will light on headlight mode. All lights are grounded. Strange.
Also front and rear light Boeings are original, front take dual filament and rear single filament, not sure if that matters. Need help figuring this out. Thanks!! |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1683 Location: Raleigh, NC
Posted: Tue Mar 19, 2024 2:54 pm Post subject: Re: 1962 Ghia Turn Signals |
kheberling wrote: |
Also front and rear light Boeings are original |
There's your problem, it's a Boeing.
Sorry couldn't resist. My dad is a retired commercial pilot, and the Boeing jokes are non-stop. I'm sure someone with actual help will chime in _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Mar 21, 2024 6:00 pm Post subject: Re: 1962 Ghia Turn Signals |
kheberling wrote: |
other turn signal goes to led and right T object wiring |
Can you explain this sentence better? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Fri Mar 22, 2024 10:00 am Post subject: Re: 1962 Ghia Turn Signals |
There are 2 wires on 49a, one goes to the turn signal lever on the steering column the other wire goes to the speedometer indicator light. The other 2 wires coming from the turn signal lever go to the 2 T connectors that feed the front and rear turn signals. |
