Fuel injected to carburetor swap
Gizzmo57
Gizzmo57 is offline
PostPosted: Sat Mar 23, 2024 5:30 am    Post subject: Fuel injected to carburetor swap Reply with quote
I’ve been working to restore a 78 type two Bus the gentleman working on my motor sadly passed he had the motor done except for intake and exhaust when I look up a 78 2 L engine I get fuel and injected wiring. Can anybody tell me where I can find 2 L wiring that is carbureted Also, what size fuel pump and do I need voltage regulator?thanks
Wildthings
Wildthings is offline
PostPosted: Sat Mar 23, 2024 9:01 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
The wiring harness for a single carb is just a few wires and easy enough to build. You need power to the coil (which should still be there) and then power to the fuel pump and coil heater, which are best done with a FI relay with a built in timer to cut power if the engine isn't running. I just use a low pressure (<4psi) Airtex marine pump while many use low pressure rotary pumps.
If you find you need to rejet the carb to get it to run well, I would start by disabling the power valve as that can make the carb and engine vacuum signal match better.
It can take a bit of work to get a progressive carb to work well on these engines as there is no manifold heat or preheated intake air for the carb. You should just keep a lookout for a decent looking fuel injection including the fuel pump.
aeromech
aeromech is offline
PostPosted: Sat Mar 23, 2024 9:32 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
I’ve never seen an air cleaner like that in a bus.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Wildthings
PostPosted: Sat Mar 23, 2024 12:31 pm    Post subject: Re: Fuel injected to carburetor swap Reply with quote
It's not as good of a choice as one with a inlet horn as the horn makes it easier to feed warm air into the carb. Do know how the one shown fits onto the progressive carb either.
Gizzmo57
Gizzmo57 is offline
PostPosted: Sun Mar 24, 2024 12:51 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
Thanks for your input. I just set the air filter on there more or less just to keep things from going into the carburetor. I’m not sure what kind of air filter should be on there. I guess my big question is hooking up the alternator with a voltage regulator a good wiring diagram would be helpful thanks for your help
crownline
crownline is offline
PostPosted: Sun Mar 24, 2024 4:45 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
That center section should be turned around so the brake booster hose faces front ie: towards the flywheel. Also see if you can get some cooling flaps from busted bus or one of the other scrappers.
A Bentley Manual will have all the wiring diagrams you need and shows cooling flaps and associated parts.
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
busdaddy
busdaddy is offline
PostPosted: Sun Mar 24, 2024 7:57 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
Ask the the used parts seller about a carb style breather box cap too, that FI one won't work.
Слава Україні!
Wildthings
PostPosted: Sun Mar 24, 2024 8:43 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
Not sure what you are trying to do, but you can find wiring diaphragm in the Technical section at the top right of any Samba page.
Wildthings
PostPosted: Sun Mar 24, 2024 8:52 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
This was my solution, but it took some work to make the adaption. The setup has been somewhat modified since the picture were taken to improve its function.
Gizzmo57
Gizzmo57 is offline
PostPosted: Sun Mar 24, 2024 10:41 am    Post subject: Re: Fuel injected to carburetor swap Reply with quote
Thanks guys I didn’t notice the flat missing appreciate all the help. This is my first BW. I’m working on all help appreciated.
