Box on Wheels Samba Member
Joined: September 05, 2004 Posts: 398 Location: The Box,CA
Posted: Thu May 26, 2022 2:44 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Pulled the doors apart to get the window frames out and this was found underneath the door panel on the passenger door. Thought it was pretty cool. Someone at the factory hand brushed painted this in Palm Green paint. Does anyone have ideas as to what this means? _________________ 58 PGSG Westfalia
64 Türkis SO-35 Flip seat Westfalia
66 Pearl White SO-42 Pop-Top Westfalia
67 Titian Red SO-42 Pop-Top walk-thru Westfalia
64 Safari Beige Sunroof Notchback
97 993 S Coupe
97 993 Cabriolet
04 996 C4S Coupe
God, guts, and guns made America great!
Live free or Die |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Thu May 26, 2022 11:21 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Box on Wheels wrote: |
Pulled the doors apart to get the window frames out and this was found underneath the door panel on the passenger door. Thought it was pretty cool. Someone at the factory hand brushed painted this in Palm Green paint. Does anyone have ideas as to what this means? |
Don't know what it means, but my August, 58' mango standard had the number 29 written the same way in mango paint on the inside right rear corner:
Your bus and my mango were built within 4 months of each other. Lots of new things were going on during that time.
When I saw the number 29 in mine, I thought maybe they were counting down the last of the pressed bumper buses or who knows?? It's fun to speculate.. _________________ Brandon |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Fri May 27, 2022 3:17 am Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Interesting. Maybe its VW applied then, not westfalia? Do those numbers show up in your VIN? |
oakman Samba Member
Posted: Fri May 27, 2022 6:16 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
buseric wrote: |
On my mango, 29 isn't part of the vin number. _________________ Brandon |
Bendango Samba Member
Posted: Sun Sep 04, 2022 9:02 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
So whats happening with this amazing beast!? _________________ I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote: |
Where did you find the elephant dick? |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1264 Location: Yulee FL
Posted: Fri Feb 02, 2024 11:03 am Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
this popped up on my youtube recommendations... I thought it looked familiar!! Was curious what happened to this one
https://youtu.be/N-4sfXljIPE?si=OV-zrenvhoaIJdoC |
Stocknazi Samba Member
Posted: Fri Feb 02, 2024 3:58 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Is that really the original seat/cushion material? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Sun Feb 04, 2024 8:18 am Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Stocknazi wrote: |
Is that really the original seat/cushion material? |
I strongly believe it could be. Stitching, pattern etc line up. Wedge pillows. Chances of it being off the road for 40 years and having a redone interior before that, and close to og specs, while everything else is original on the bus is very small. I also swear I have seen that pattern somewhere before but I haven't been able to locate a pic.
I know others with early westfalia experience have told Daniel otherwise but....we don't know everything including options and colours offered by westfalia. We continue to learn new things as buses are discovered.
I got the chance to cruise this bus this past summer. Its a beauty and is getting used! |
Tomasz Samba Member
Joined: September 08, 2005 Posts: 1096 Location: in a van down by the river
Posted: Mon Mar 25, 2024 6:26 pm Post subject: Re: The Adventures of a 1958 Palm Green/Sand Green (PGSG) Westfalia |
Pleasure meeting / talking to you this past weekend at Silverado Show.
Cheers,
Tomasz
_________________ '56 - Wolfsburg Kombi (1200)
'74 - Type 181 (1600)
'85 - Westy Mosaik Joker Hightop (1.6 TD)
'87 - 16" Syncro High Top (1.9 TD)
'88 - Westy (EJ25)
'14 - Jetta Sportswagen (2.0 TDI) |
