GMendoza Samba Member
Joined: November 15, 2007 Posts: 341 Location: Alta Loma, CA
Posted: Tue Mar 26, 2024 4:08 pm Post subject: Later trans WITHOUT bus nose cone? |
Has anyone installed a later trans in an early oval by welding in a new front mount rather than using a bus nose cone?
If so, any other issues to be aware of? |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Wed Mar 27, 2024 1:40 am Post subject: Re: Later trans WITHOUT bus nose cone? |
It will cause the front of the trans to be too low by 40mm (or maybe it's 60mm??). This will cause your muffler to be too high.
Don't create problems, use the Bus nose cone. _________________
the dominator Samba Member
Joined: March 18, 2016 Posts: 112 Location: The Netherlands
Posted: Wed Mar 27, 2024 2:38 am Post subject: Re: Later trans WITHOUT bus nose cone? |
same opinion overhere, I would leave the chassis original and mount the bus nosecone.
I have recently mounted the bus nosecone, then it is plug and play
_________________ 54 iceland green oval, done!
52 Zwitter standard ragtop, parts hunting
67 T2A candywaxred en chestnutbrown
1988 T3 doka synco 2.1WBX |
splitjunkie Samba Member
Posted: Wed Mar 27, 2024 3:48 am Post subject: Re: Later trans WITHOUT bus nose cone? |
Bruce wrote: |
Don't create problems, use the Bus nose cone. |
He is talking about welding in the front mounting plate to the front torsion tube so this won't be a true statement.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701173c
However, the original front mounting plate is actually cast into the center part of the torsion tube and will be difficult to remove. It will require a lot of cutting and grinding. Just get a bus nosecone and be done with it. _________________ Chris
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Mar 27, 2024 5:36 am Post subject: Re: Later trans WITHOUT bus nose cone? |
I haven't had a bus and beetle noise cone side by side for a while, but I recall it's not just the mount that is different, it's the shift rod height too. So raising the mount won't do any good, as now the shift rod would be above the tunnel and the nosecone will likely be hitting the floor. _________________ modok wrote:
jitbba Samba Member
Joined: August 20, 2013 Posts: 165 Location: San Antonio
Posted: Wed Mar 27, 2024 7:28 am Post subject: Re: Later trans WITHOUT bus nose cone? |
I welded in that exact front mount for mine and used the regular nose cone for my transmission. No problems and pretty straight forward _________________ My other ride is a Zildjian |
Posted: Wed Mar 27, 2024 7:47 am Post subject: Re: Later trans WITHOUT bus nose cone? |
esde wrote: |
I haven't had a bus and beetle noise cone side by side for a while, but I recall it's not just the mount that is different, it's the shift rod height too. So raising the mount won't do any good, as now the shift rod would be above the tunnel and the nosecone will likely be hitting the floor. |
Yes, the orientation of the mount holes and the shift rod are different between the two.
Use the stock mount plate on the torsion tube and you have to use the bus nose cone. Everything will line up.
Weld in the late style front mount plate on the torsion tube and you can use the standard sedan nose cone. Everything will line up.
He is suggesting the second option. _________________ Chris
Posted: Thu Mar 28, 2024 9:09 am Post subject: Re: Later trans WITHOUT bus nose cone? |
Thanks guys for all the info, very useful! |
Bruce Samba Member
Posted: Sun Mar 31, 2024 2:38 am Post subject: Re: Later trans WITHOUT bus nose cone? |
splitjunkie wrote: |
Bruce wrote: |
If you weld on that bracket and use a late Beetle nose cone, the hockey stick will be centered in the hole going into the tunnel. This will cause the next casting on the trans (gear carrier) to be lower than if you use a Bus nose cone and the original mount. In other words, the front of the trans is tilted down. Causing the tail pipes to ride higher, possibly hitting the rear apron.
Weld in the late style front mount plate on the torsion tube and you can use the standard sedan nose cone. Everything will line up. |
The nose cone and hockey stick will line up, but it pulls the rest of the front of the trans down. _________________
jitbba Samba Member
Posted: Mon Apr 01, 2024 7:44 am Post subject: Re: Later trans WITHOUT bus nose cone? |
maybe I was lucky, but this was not the case when I did mine. Welded in that front transmission mount, used the mid-60s transmission, and everything lined up perfect. No issues with the tailpipes, how the engine sits, engine seals, etc.
My only complaint is the new transmission makes the stock 36hp engine slower but I'll use the motor until it gives up the ghost, then opt for something more powerful _________________ My other ride is a Zildjian |
Ian M Samba Member
Posted: Tue Apr 02, 2024 7:40 am Post subject: Re: Later trans WITHOUT bus nose cone? |
Bus nosecone is the way to go. Bolt in easy.
The hockey stick is lower on a bus nosecone,that's why they are also used with '60s cars that have raised transmission mounts-to keep the shift rod in the tunnel.
My oval had a later tunnel case mount like welded in decades ago,like mentioned here previously it resulted in the nosecone being too low and the rear of the engine being too high. Probably worked ok as a beater with the 40hp that was in it,but...
In my case, I welded in a solid mid mount (cal look car,not concerned with noise) and ran a bus nose cone to keep the shift rod in the stock location,simply eliminating the nose cone mount altogether. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed Apr 03, 2024 5:38 am Post subject: Re: Later trans WITHOUT bus nose cone? |
That's your standard bus nosecone which is what the OP was asking if he could avoid using. Wolfsburg West as well as others sell them. Definitely the best way to go, although a '60 presents a problem because of the one year only front mount. Best option for a '60 is to remove the front mount and weld in the later front mount plate and use a standard sedan nose cone. _________________ Chris
jitbba Samba Member
Posted: Wed Apr 03, 2024 7:30 am Post subject: Re: Later trans WITHOUT bus nose cone? |
The reason I went with welding in a new mount was to avoid mutt parts. In my mind, it made it too complicated to have to keep track of which years/models were with what parts if I ever had to service anything. _________________ My other ride is a Zildjian |
Chip26 Samba Member
Posted: Wed Apr 03, 2024 10:01 pm Post subject: Re: Later trans WITHOUT bus nose cone? |
Consider using a bus nose cone or welding in a new mount while considering shift rod height and transmission compatibility, and consulting with experts for a safe and reliable installation of a later transmission in an early oval VW. |
Posted: Thu Apr 04, 2024 4:05 pm Post subject: Re: Later trans WITHOUT bus nose cone? |
Chip26 wrote: |
It's really not that hard.
You have a '59 and earlier, not including splits with the doughnut mount, and you don't want to modify the pan, you use a bus nosecone.
You don't mind modifying the pan, cut off the old mount plate as necessary and weld in a late model front mount plate and use a standard sedan nosecone.
Easy Peasy. I don't know why people over complicate it. _________________ Chris
