Rear Disc Brake Comparison
Page: Previous  1, 2, 3
a914622
a914622 is offline
PostPosted: Thu Mar 28, 2024 6:15 am    Post subject: Re: Rear Disc Brake Comparison Reply with quote
WOW this again!!
I do think rear disk are a need not a want. Drive up the pass to go skiing alone , drums ok. Pick up 4-5 friends and there gear for the ride down the pass and your 2k heavier, drums not so good.
As to the better kit? I would say one that matches your fronts. ( do them first) 2 piston a plus. I think you need at least a 300mm rotor in front. I like the 290 eurovan in rear.
As far as ebrake. New cables are a must. And I really think the back end of the rod should have a support so there is no sag when not under tension. Or elictric ebrake.
Mine runs Lexus’s ls400 fronts and 06 jetta in the rear. I can lock up all 4 if needed.
Good luck
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
Wellington
Wellington is offline
PostPosted: Thu Mar 28, 2024 7:49 am    Post subject: Re: Rear Disc Brake Comparison Reply with quote
I presently have SA rear drums and my own 303mm front disc set up. 16" wheels.
No doubt about it, discs are a breeze to maintain, and I'm entertaining the thought of a kit, or my own set up of discs for the rear.
Years back, the word was the rear disc kits parking brake would not hold a heavy van, the kits used a rear car caliper, I believe an Audi from my years ago was the choice.
The Eurovan rear caliper is using a 38mm piston, and the reports are it is working out well on the Vanagon.
Does anyone have info on piston sizes that were not up to the task?
Eurovan carriers can be difficult to find, and I'm considering looking into rear vented discs as well. Possibility of SLine rear calipers.
I know this topic was about kits, but there are others that have made their own "kits" that have intelligently combined parts.
markswagen
markswagen is offline
PostPosted: Thu Mar 28, 2024 12:22 pm    Post subject: Re: Rear Disc Brake Comparison Reply with quote
never mind rear disc brakes, tell us about the rear sway bar.
mathieux46 wrote:
Hi,
619 201 0310
mathieux46
mathieux46 is offline
PostPosted: Thu Mar 28, 2024 8:25 pm    Post subject: Re: Rear Disc Brake Comparison Reply with quote
Markswagen,
Details of the sway bar can be found here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=341321&start=20
Highly recommend upgrade!!
Thanks
markswagen
PostPosted: Fri Mar 29, 2024 10:38 pm    Post subject: Re: Rear Disc Brake Comparison Reply with quote
thank you.
l thought l recognized it.
l've been collecting 19mm front sway bars.
l plan on using stock end links, as they are a whole lot easier to come by.
mathieux46 wrote:
Markswagen,
Thanks
619 201 0310
Page 3 of 3
