Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Thu Mar 28, 2024 8:47 am Post subject: Engine build |
I have had issues with this motor for a long time , short history , the
1800 turns out to be a 1700.
I purchased 15 years ago A&A 1900 set .
I thought 1800s would not fit a 1700 case unless machined? They slipped in so i thought i had a 1800!.
Wrong !
So I calculated wrong when i set this up !. I am open to suggestions .
The motor ran but was gutless , its a automatic and drives nice but a little more on some hills would be nice .
Also it is hard to start as it seems the timing is jumping around leading me to think that endplay was a factor , but upon inspection so far its very tight . So maybe distributer drive may be worn out?
When starting it sometimes backfires or is hard to start !
Wildthings wrote:
The "0" mark should be TDC and the "I" mark should be 27° BTDC, though there are variants out there. |
Posted: Thu Mar 28, 2024 11:21 am Post subject: Re: Engine build |
There are sealing washers on the heads are these required on type four ?
If i remove them i will bring my compression up into range ?
Thanks for your help ! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16976 Location: San Diego, California
Posted: Thu Mar 28, 2024 9:36 pm Post subject: Re: Engine build |
All of the engines I deal with are built by professionals. Too much at stake for guesswork _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Mar 29, 2024 9:58 am Post subject: Re: Engine build |
I have found out the problem .
The motor is a 1700 which has been machined out to except 1800 pistons .
When i installed the piston set i measured the deck hight and ….. then i installed
The cylinder head Shims ( finding out now that these are not used ) .
This caused my calculation to be out and have very low compression.
I will do more measurements and make sure i have no vacuum leaks .
I might have new shims (10mm) i think this will bring my compression up!
Thanks for everyone’s help !!!!! |
