TXHCBeetle Samba Member
Joined: October 07, 2021 Posts: 177 Location: Boerne, TX
Posted: Tue Mar 19, 2024 7:11 am Post subject: Re: Lightening any and everything … |
Vanapplebomb wrote: |
Bruce, that is only true for direct loading in tension. What you are talking about is how much force it takes to yield two different areas for a given material strength, which is a linear relationship to yield strength and cross section area. Indirectly, this can also be applied to deflection (stiffness), but it isn’t linear. So, yes, obviously hollowing out journals reduces the load that can be applied in tension and bending for a given deflection.
HOWEVER…
It’s not that simple. A crankshaft does not see a maintained static force applied in one direction. It is cyclical, and that changed EVERYTHING. Same is true for bolts. Your baseline yield or tensile strength is rendered somewhat irrelevant because the strength properties change in relation to operating conditions. Survival of the part becomes less dependent (to a degree) on force over a given cross section area (like you talk about), and more about shear stresses at the surface grain boundaries. There are a whole host of things that play into surface conditions… localized compressive forces (shot peening), part geometry, stress concentrations, etc. Remember, due to fatigue, you can fracture a part with FAR less force than the theoretical force based on the tensile strength of the material and cross section area. To some degree, you can manipulate those variables to change how strong you part is at a given number of cycles. See the picture I posted above. Cyclical loading is a whole different ball game.  |
 _________________ In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5572 Location: Holland, MI
Posted: Tue Mar 19, 2024 8:21 am Post subject: Re: Lightening any and everything … |
These are the lifters I was wondering about on the last page. If anyone knows any current manufacturers, I would be interested.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
BFB Samba Member
Posted: Sat Mar 30, 2024 8:00 pm Post subject: Re: Lightening any and everything … |
_________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17573 Location: Left coast, Canada
Posted: Sun Mar 31, 2024 3:06 am Post subject: Re: Lightening any and everything … |
Is that a stock steel retainer?
Weights?
I bet it still weighs more than a Ti retainer. _________________
celtune Samba Member
Posted: Sun Mar 31, 2024 3:16 am Post subject: Re: Lightening any and everything … |
Bruce wrote: |
Weights?
I bet it still weighs more than a Ti retainer. |
Hi Bruce,
i could not find an exact weight but here is the discription from the csp page:
"These special valve spring retainers are made of Saar steel - 42CrMo4 CNC and have a strength of 900 - 1200 N/mm² with a weight saving of approx. 5 grams per piece compared to the standard Type-4 valve spring retainer. The two-stage valve spring seat allows the use of an outer Type-4 valve spring, which can be combined with an inner waterboxer valve spring if required."
https://www.csp-shop.com/en/?func=detailcall&artnr=32515a
You need to switch to the german page for the pics |
modok Samba Member
Joined: October 30, 2009 Posts: 27657 Location: Colorado Springs
Posted: Sun Mar 31, 2024 11:22 am Post subject: Re: Lightening any and everything … |
Neat solution for that particular problem but not the most ideal design.
I like tool steel retainers, they can be made very thin.
The retainer can be springy, it can be an extension of the spring, and springs don't need holes. |
panel Samba Member
Joined: December 02, 2001 Posts: 1189 Location: Victoria B.C. Canada
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Mon Apr 29, 2024 11:40 am Post subject: Re: Lightening any and everything … |
Quite a few years ago, I walked into Dave Folts' shop, and he was carving a few ounces from the backside of a customer's ring gear, end-milling neat little pockets between the bolt holes. Needless to say, Dave appreciates the 7 POUNDS we removed from the GT version 091 TBD .. https://www.thesamba.com/vw/gallery/pix/2270675.jpg _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
QRP Samba Member
Joined: April 27, 2008 Posts: 1887 Location: NORTH HOLLYWOOD,CA
Posted: Mon Apr 29, 2024 2:05 pm Post subject: Re: Lightening any and everything … |
Bruce wrote: |
Weights?
Stock retainers are about 17g, I trimmed some down to 14g |
Posted: Mon Apr 29, 2024 2:15 pm Post subject: Re: Lightening any and everything … |
Trimming a stock retainer down to 14 is pretty good, actually. Took off more than I thought you could.
These are stock steel retainers for a popular V8 engine (you can probably guess which one), but nobody said you can’t use other engine parts on a VW.
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3508 Location: Charleston, SC
Posted: Thu May 02, 2024 9:15 am Post subject: Re: Lightening any and everything … |
When Schubeck closed, a former employee picked up manufacture of the lifters (Smith Machine/SM Lifters), at least for V8 applications. Apparently, they are closed, too.
I don't believe there are any current manufacturers. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
panel Samba Member
BFB Samba Member
Posted: Sat Jan 18, 2025 12:56 pm Post subject: Re: Lightening any and everything … |
I had a Mazzone sandrail that had drums on it like that _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
BFB Samba Member
Posted: Sat May 17, 2025 7:17 am Post subject: Re: Lightening any and everything … |
liquidrush Samba Member
Posted: Sat May 17, 2025 4:39 pm Post subject: Re: Lightening any and everything … |
That is completely wild! How much weight do you reckon you removed? Looks like about 30% and looks totally cool too. Like having a life size cut away learning tool. |
BFB Samba Member
Posted: Sat May 17, 2025 5:40 pm Post subject: Re: Lightening any and everything … |
Sorry, not mine, it was in the Samba photos. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
jim martin Samba Member
Joined: January 14, 2004 Posts: 337 Location: Vancouver, BC
Posted: Sun May 18, 2025 2:53 pm Post subject: Re: Lightening any and everything … |
I’m kinda opposite with crank and flywheel .
I remember when I switched to a Demello full circle crank and a nearly full weight flywheel I ended up turning faster 60 and 330 ft times which led to faster 1/4 times .
There was just more rotational mass the car would not bog and put more power going fwd , motor just maintained rpm instead of trying to recover it.
Even now I follow same program with crank and flywheel . On the street or launching at the strip just works _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
panel Samba Member
oprn Samba Member
Joined: November 13, 2016 Posts: 14713 Location: Western Canada
Posted: Thu Jun 26, 2025 4:30 am Post subject: Re: Lightening any and everything … |
jim martin wrote: |
Even now I follow same program with crank and flywheel . On the street or launching at the strip just works |
I suppose it may be possible to take the momentum principle to the extreme. Have a Brigs and Stratton back there winding up a huge flywheel for say 30 minutes, roll up to the starting line with it just singing and dump the clutch! Just like those little toy cars and trucks you push hard several times and lift up then drop on the floor and they scoot across the kitchen...
...or, a set of tractor wheel weights and a pneumatic bumper jack. Wind her up with your 1200cc 40 horse and dump the air when the light turns green.
I wonder if it has been tried! That would be the polar opposite of what lightening everything is supposed to do. The shorter the track the more advantage you would have.
Ok, done my morning tea, taken my meds, time to go put a set of shocks in the wife's car!  _________________ Our cars get old, we get old but driving an old VW never gets old! |
