Murphy's Law Samba Member
Joined: June 26, 2023 Posts: 18 Location: Near Schenectady NY
Posted: Thu Apr 04, 2024 6:17 pm Post subject: E brake switch |
Does anyone know where I can get an E brake switch? I got the one for the door like everyone says should fit, but it hits the shift rod when it's in the down position. It also doesn't match up with the screw hole to attach it, the mount is too short to reach. Yes, a new hole I know, but that doesn't fix the shift rod problem.
I have a door switch from the '74 super I'm gutting for some needs but it also sits too deep and it has four small blades though it is a plastic housing compared to an earlier bug with the "open" switch design.
I turned it around, drilled and tapped a new hole but being in place backward it hits the ratchet cam for the handle. I think a shorter Normally Open switch would do it no matter how I had to mount it.
Has anyone had this problem? I'm on a '74 bug pan which came without a switch, the switch from the '74 super was also missing so I don't know what was supposed to be there.
This is such a small detail it's pi**ing me off. I spent 1/2 a day on this almost and I have plenty of 'glass work left to do so this is about the last thing left on the pan. I wanted to lock this in and start the mount/trial/unmount etc. before I start asking WWJD about the 'glass work. (What Would Joe Do). |
joemama Samba Member
Joined: February 09, 2006 Posts: 1639 Location: La Crescenta, California
Posted: Thu Apr 04, 2024 6:33 pm Post subject: Re: E brake switch |
Do you actually need this? I have been around buggies and bajas, bugs, for a long time, not sure I have ever seen one. Sounds like maybe it was on the later model bugs, but with the design of the bug ebrake, I dont see how you would ever have to worry about not knowing it was on. |
Posted: Fri Apr 05, 2024 6:07 am Post subject: Re: E brake switch |
You know, now that you say that, I suppose I don't really need one. Yes, it was there, yes the handle tells me if it's on or not. I guess I was looking to add more lights to the dash to distract me. I'll leave the wiring and if I find one sometime down the road I'll add it. |
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 93 Location: Sacramento
Posted: Fri Apr 05, 2024 3:19 pm Post subject: Re: E brake switch |
For CA light and brake inspection I needed one. I crudely added a courtesy light switch the grounded out when the handle wend up. I literally had a light clamped under the dash that came on when the handle went up. As soon as I passed inspection all that junk came out in a matter of a couple minutes. |
