VanGeek Samba Member
Joined: September 25, 2022 Posts: 231 Location: New England
Posted: Mon Apr 08, 2024 11:34 am Post subject: If you use a phone cradle, consider this! |
Been looking at these automagic motorized wireless charging cradles for awhile, and finally purchased and installed one in Vanna. It uses the same ball-mount that my prior mechanical cradle used, so was basically plug and play for me.
You can mount these on vents, a suction mount to the windshield or dash, use my mount that occupies the small unused dash cubby, or do something else. The model I linked below has a ball mount with a shaft that fits perfectly (after you cut the shaft to size) with my mount: https://www.thingiverse.com/thing:6059879
You drop you phone into it, and it retracts to grab the phone. Push a button on the side and it releases it. Charges a phone at anywhere from 5-15 watts wirelessly. SO easy to use. I'm installing these in every car I own... This is just one example but there are another half-dozen options available on amazon, aliexpress, and ebay.
https://www.amazon.com/dp/B0BL1S9LFJ? |
BeConscious Samba Member
Posted: Wed Apr 24, 2024 11:15 am Post subject: Re: If you use a phone cradle, consider this! |
Thanks for sharing this. I just printed out both versions.
How did you run the wiring for the charger if you don't mind me asking? |
Posted: Wed Apr 24, 2024 5:54 pm Post subject: Re: If you use a phone cradle, consider this! |
There are several options for the power supply to the cradle. It only requires a quick-charge 3.0 port.
So -- easiest option is to use the cigarette lighter with a quick-charge 3.0 adapter inserted into it and a short cable to the cradle.
I also added a dedicated circuit and a qc 3.0 port into the area which was previously occupied by the cigarette tray. This is more involved since it required a new =12V supply from the starter or coach battery, a relay with igntion trigger, wiring to the ashtray area, and fabrication of a panel to cover the ashtray and incorporate the qc 3.0 port. Pls let me know if you want my .stl file for the panel and other details about wiring and I can supply them! |
