splittie65 Samba Member
Joined: August 03, 2023 Posts: 42 Location: Surrey, UK
Posted: Sat Apr 13, 2024 8:47 am Post subject: Charging indicator |
I have an alternator conversion on my '65 splitty that has been on there some time.
When I start the engine up, the charging light stays red until I rev the engine quite high. Once I've done this, it goes out, and it stays out even at low revs.
As I intend to do a large road trip soon, I wondered if this is something I should worry about (and if so how to sort it) or will it be fine.
I should add the belt is taught and not slipping. |
Slip356 Samba Member
Posted: Sat Apr 13, 2024 1:27 pm Post subject: Re: Charging indicator |
| Not a problem, with an alternator vs generator they all do that. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53261 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 13, 2024 1:52 pm Post subject: Re: Charging indicator |
Some take a few more revs to initiate a charge, not really any thing to worry about. If it bugs you try a higher wattage bulb in the speedo, but that might bring on new problems so best you just live with it as is. Does a volt meter say the battery is charging once the light goes out? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26424 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 13, 2024 4:49 pm Post subject: Re: Charging indicator |
Which crankshaft pulley are you running? Too small can cause charging problems and increase engine operating temp so as to reduce longevity.
Posting an image of the engine might help. _________________ In Stereo, Where Available! |
Posted: Sat Apr 13, 2024 11:27 pm Post subject: Re: Charging indicator |
As requested... a photo of the engine. Also a photo of the van, just because
Since this photo was taken i've added a split charger which shows upto max 15V when the engine is revved
Posted: Sun Apr 14, 2024 7:55 am Post subject: Re: Charging indicator |
Definitely a larger stock crankshaft pulley. Does it measure 7" across?
You really need to get the stock air cleaner, it will be better for the engine.
Missing the heat riser tins with their seals, need those to keep the engine cooler.
Hopefully you have all the tins underneath and up front of the shroud if that is a dog house unit. _________________ In Stereo, Where Available! |
Clara  Samba Member
Posted: Sun Apr 14, 2024 9:36 am Post subject: Re: Charging indicator |
| Slip356 wrote: |
X2
What you describe is normal with an alternator _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Fri Apr 19, 2024 4:31 am Post subject: Re: Charging indicator |
I re-checked the voltage I'm getting and it is 14.5V at tick over to 16.5V when revved up.
This on both the van battery and the leisure battery. They drop to 13.7V when the engine is turned off. |
Posted: Fri Apr 19, 2024 7:04 am Post subject: Re: Charging indicator |
16.5 is way too high, it should be 14.5 at speed. It's going to cook your batteries and will be hard on bulbs and electronics as is.
Might want to try another volt meter first before freaking out though. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Apr 19, 2024 9:06 am Post subject: Re: Charging indicator |
I thought as much... just tested again with a different meter with the same results!
I'm doing a 400 mile trip in 3 weeks and a 2500 mile trip around France in June, so I have a a replacement alternator being delivered. Don't want to take risks.
I have fitted one with the engine still in place... but a long time ago in a different split (15 years ago?).
I know the principles, but if anyone has helpful tips, I'm happy to listen! |
Posted: Fri Apr 19, 2024 9:18 am Post subject: Re: Charging indicator |
Remove the carb, then reach around and remove the fan nut, leave the fan in the shroud and remove the alternator. Hopefully the lower two fasteners attching the backing plate to the shroud are hex headed, if they are screws it's challenging due to the manifold being in the way, not impossible, but it'll test your patience.
Careful you don't drop any washers or shims, and do a dry run and shim the fan outside of the bus, then take the fan back off and put it in the shroud before offering up the alternator and backing plate assembly. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Apr 19, 2024 9:54 am Post subject: Re: Charging indicator |
| busdaddy wrote: |
Looking at my photo of the engine above... it looks like they're going to be screws  |
Posted: Fri Apr 19, 2024 10:30 am Post subject: Re: Charging indicator |
| splittie65 wrote: |
| busdaddy wrote: |
Sometimes an angled screwdriver helps, often it's a job for needlenosed vise grips. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 20, 2024 5:47 am Post subject: Re: Charging indicator |
| Quote: |
| Sometimes an angled screwdriver helps, often it's a job for needlenosed vise grips. |
I've started doing some dismantling, air filter, carburettor, fanbelt etc...
I thought I'd try loosening off the four screws holding the alternator to the fan shroud before going too far. of course the top two undo fairly easily, but the bottom two seem to be stuck solid with the access I've got.
Would it be worth trying to raise the fan shroud by undoing the alternator strap and the two side bolts to gain better access? Or do I just bite the bullet and take the engine out?
I've not had this engine out so I'd be dreading what I find like wrong bolts not accessable etc... |
Posted: Sat Apr 20, 2024 7:20 am Post subject: Re: Charging indicator |
Before raising a shroud check for a thermostat below, and the throttle tube too.
Raising a shroud in the bus is not only a pain, it also makes it really hard to get everything lined up nicely later, it's easier to just drop the engine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 21, 2024 6:21 am Post subject: Re: Charging indicator |
| busdaddy wrote: |
Raising a shroud in the bus is not only a pain, it also makes it really hard to get everything lined up nicely later, it's easier to just drop the engine. |
So I've decided to drop the engine...but taking my time, with breaks... i'm not as young as I used to be.
During the process I've got to the point of undoing the engine/gearbox bolts. I've sprayed WD40 on the lower ones in preparation, and noticed an anomaly on the top ones. (see photo}. Only a nut on the RHS. As the van has had a straight axle conversion it will have a different gearbox. i've read that I might have to access this from the other side. Correct?
Is there any thing else I should look out for? Bottom gearbox support?
Posted: Sun Apr 21, 2024 7:56 am Post subject: Re: Charging indicator |
The nut on the RH top bolt is common, the the bolt it's on should have a D haped head and not turn as you remove the nut. The LH upper is also standard on dual port cases, remove the bolt from the front (transmission) side on that one, the nut is pressed into the case and stays with it.
If your bus has frame horns there's no need to support anything, the transmission stays in place while you pull the engine back and lower it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 21, 2024 8:02 am Post subject: Re: Charging indicator |
Would look for the upper LH side bolt to see if it is even there and which clutch arm is in use. Curved original arm does not allow for easy bolt access, later straight arm does, but that changes the angle the clutch cable comes out the end of bowden tube and can then cause premature cable wear there. As in replace clutch cable as often as every 6,000 miles, instead of 50,000+.
With engine out it is a lot easier or even doable at all to check many things to make your VW more reliable. This can even result with increased engine longevity.
From that front of shroud image you are missing the thermostatic flaps, so pickup a set from the classifieds ASAP. _________________ In Stereo, Where Available! |
Posted: Sun Apr 21, 2024 8:14 am Post subject: Re: Charging indicator |
Would also check the rear bowden tube mount. It could be the cast part of the transaxle one for curved arm or bolt on type for straight arm. _________________ In Stereo, Where Available! |
Posted: Tue Apr 23, 2024 4:13 am Post subject: Re: Charging indicator |
I've undone the bottom engine mounts... although with one the whole stud has come out.
I'm now searching for the hidden top mount. Difficult to see and take photos.
Is it where the red arrow is... and is it missing? Is it a round allen bolt?
