Has anyone not liked the BMW booster upgrade?
Page: Previous  1, 2
Sodo
Sodo is offline
PostPosted: Thu Apr 11, 2024 11:00 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
I have two vans:
    '90 Westy Syncro, appx 5,200 lbs, 10% bigger wheels, with big brakes, rear discs, garden-variety brake pad materials and age
    '87 TinTop Syncro, appx 4300 lbs, 10% bigger wheels, 100% original 54k mile factory brakes - original pads, original shoes
The '87 tintop 100% stock brakes feel MUCH better, less pedal pressure.
There are a lot of details to balance when making brake improvements.
Especially if changing multiple parameters at once.
....KTMs, GasGas, SPOT mtb
82westyrabbit
82westyrabbit is offline
PostPosted: Thu Apr 11, 2024 11:06 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
I installed a BMW brake booster with stock early brakes about four years ago. Just to make it clear, I installed the brake booster because it was cheap and available not because I was looking for a performance upgrade. At first I felt like I had a soft pedal. I had to rebleed the brakes, and I adjusted the rear brakes to get the pedal to feel right. It takes less pedal pressure to stop the van but the pedal is at the same hight as it was before the BMW booster. If the rest of the brake system is not in great shape the new booster will amplify the problem. The speedometer cable is a problem. I get a slight clicking sound from the cable. I am happy with the upgrade if you want to call it that. I have recently installed a big brake kit but have not driven the van since. it will be interesting to see how I feel about the brakes now after I drive it. John
Christopher Schimke
PostPosted: Thu Apr 11, 2024 11:19 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
Sodo wrote:
I have two vans:
Do you mind divulging what front/rear brake kits you have on the '90 Syncro?
Also, I assume you mean that the stock brakes on the '87 take less pedal pressure to achieve similar braking performance/stopping distances compared to your '90? Hard to quantify, I know. I'm just trying to figure out if it's just he feel of the pedal that you like better or the combination of the pedal feel plus the brake performance.
MarkWard
MarkWard is offline
PostPosted: Thu Apr 11, 2024 11:59 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
MarkWard wrote:
As crazy as this sounds, I would drive the van. While the pedal has a different feel, it may stop fine in use and you will adapt to the new pedal feel assuming properly bled.
This is why I suggested driving the van in question. Certainly feel is subjective and braking distance is likely a measure of improvement. Don’t see where anyone has measured braking distance, pedal effort before and after. There is also that it’s rare to fix brakes that are working satisfactory. So fixing poor braking with new parts is going to feel better. There is likely a placebo affect going on. “ I just spent $2000 upgrading my brakes” of course they feel better.
Something similar happens with bolt on power. The bragging is a result of the driver’s butt Dyno. We have a chassis Dyno that can actually measure power reliably before and after. We’ve had owners come in with their 10% increase in power and want to compare their butt Dyno and the hype of the bolt on power added only to be disappointed with real measurements.
Driving style should be a consideration too. I rarely use the brakes in our 82 2 piston caliper stock setup. In city driving I coast a lot looking ahead. On highway s I coast up the exit ramps. Every now and then an idiot forces me to actually threshold brake to avoid a collision and the van has always stopped in time. Someone living on a mountain is going to have different requirements from me. It’s all subjective.
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Apr 11, 2024 4:35 pm    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
MarkWard wrote:
I’ve not been impressed with the vans that I’ve worked on with the bmw booster. Only a few. My impression is the soft pedal is the additional assist you’d expect from a larger booster.
I’ve upgraded two of these vans with the BMW Master Cylinder. The larger diameter should increase pedal effort. But all in all the stock booster and master work fine for me.
A larger booster alone is not going to make the brake hydraulics stronger. It can only reduce pedal effort. Also make sure the master is returning fully. There is a member selling new adapted stock size boosters in the classifieds. That would be my choice.
That's me selling the boosters.
I started it to actually remove the BMW booster and go back to stock size booster, and needed a brand new stock size booster that didn't exist.
You won't catch me dead installing the new JP Group repros Twisted Evil
Sodo
Sodo is offline
PostPosted: Fri Apr 12, 2024 7:31 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
Christopher Schimke wrote:
Sodo wrote:
I have two vans:
OG brake boosters in both vans.
'87 has higher stopping power under less pedal pressure.
I don't know how to quantify it except when I jump from one van to the next, anecdotally it feels like "double".
Instrumentation would probably not show "double".
But the foot says "significant".
'90: SmallCar brake kits front & rear from 2009.
Brake pads from the FLAPS.
Rotors not re-surfaced, just replaced brake pads, I don't know how long ago (years).
AFAIK the pads are wearing evenly, but I have not looked at it 'critically'.
I just glance at the thickness and it looks 'OK'.
Brake booster pulls the pedal down when the engine is started.
And it's a camper so has 'stuff, on shelves, perched etc' consequently I never do any "panic stop" tests (yard sale).
In the old days I used to "panic-stop-test" my vehicles,
often enough that I knew what was gonna happen.
Performance will be revealed (as with everyone else) during the actual emergency.
Isn't that kinda dumb?
After which I will kick myself, because it is an easy test, easy knowledge, easy performance confirmation.
All it takes is an empty road and a little foresight.
I'm no Samba historian, but can't recall anyone ever discussing/demonstrating this on theSamba over the years.
But that's for a different thread perhaps specifically named like "Tested panic stop distance?"
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Fri Apr 12, 2024 9:32 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
I guess I would also warn that with this upgrade you are going to see more black dust on your front wheels. Like, a LOT of black dust, I am constantly cleaning it off because I have shiny parts. The dust comes off the brakes hot and electrically charged, so it sticks mightily and on some surfaces actually burns itself into the coating. reporst are that ceramic brake pads being a lighter color make less visible dust particles. Also that a "ceramic wax" on your wheels will prevent such severe sticking. I don't know for real but researched it because of such a lot of black dust on my wheels.
Sodo
Sodo is offline
PostPosted: Fri Apr 12, 2024 5:26 pm    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
Interesting re: charged particles sticking….. but how much heat can a tiny particle retain as it passes through the air enroute to your shiny bits?
I wonder if there is an acid etch or something.
It seems to me that it wipes off easily, if you clean it soon, more difficult if you wait.
Wouldn’t the amount of dust depend upon how you use your “increased pedal assistance”?
Braking harder will logically produce more brake dust.
Some might brake the same as before, just pushing less hard on the pedal, and get “same dust.
dkoesyncro
dkoesyncro is offline
PostPosted: Fri Apr 12, 2024 9:57 pm    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
I have had the girling 60 front brakes and BMW booster for apx. 13 yrs. This has been a great feel. This last MogFest I produced some carnage that gave me an opportunity to do a rear disc conversion. I made my own using the Eurovan.
I had a hell of a time bleeding the system so I thought! Soft pedal after soft pedal and nearly 3 qts. of fluid. I convinced myself that my son had over extended the MC and the seals rolled while bleeding . I took apart the MC, cleaned it up and ensured that the seals will ride right. Bench Bled the MC and repeated the whole thing again with a pressure bleeder.
I cracked everything, even the rumored air trapped proportioning valve, joints and junctions. Viola, absolutely sure I’m air free. However, I will report that the pedal feel is softer than it was with rear drums. The e-brake is great though.
As for the MC, years ago and maybe it was even Siekel the Audi 4000 MC was an option. Although fluid dynamics is not my specialty and I believe that larger lines were also needed for those who were going to benefit from this conversion.
mitch5
mitch5 is offline
PostPosted: Mon Apr 15, 2024 8:39 am    Post subject: Re: Has anyone not liked the BMW booster upgrade? Reply with quote
So update, for all those considering doing a swap with booster. Now that I have driven the van I will say it’s not as soft as it was Initially, it stops and has the feel similar to an early 2000’s Subaru. I had some air trapped in the master that the power bleed didn’t get. Cracking open the line then depressing the pedal finally got that.
I will suggest that if you planning to update/convert to discs then I would swap the brakes first without ditching the stock booster. If you like the pedal feel with that then I would keep it. The bmw booster will just decrease the overall force needed but also will change how/when the force is applied.
Page: Previous  1, 2
Page 2 of 2
