ABA Vanagon Conversion
vw62kid
vw62kid is offline
PostPosted: Fri Mar 29, 2024 7:28 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Vanagon Nut wrote:
...I don't know why but the machine shop I used screwed up their first attempt at installing the IM shaft inner bearing. i.e. I could see installing that part as being a bit tricky.
Neil.
Yeaaaah I ended up destroying my inner IM shaft bearing myself. Now I need to order another set Shocked all a learning experience!
______________
62 Ragtop Project (Anthracite Grey)
https://www.thesamba.com/vw/forum/viewtopic.php?t=597378&highlight=
59 Logo Single Cab Project (L345 Light Grey)
90 Vanagon tin-top ABA convserion...work in progress
https://www.thesamba.com/vw/forum/viewtopic.php?t=...1a11892111
vw62kid
vw62kid is offline
PostPosted: Fri Mar 29, 2024 7:31 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Well I got the outter IM shaft bearing pressed in!! But I ended up destroying my other bearing though. Another set is on the way already. Now I just need to find a better press bit for it.
______________
rogertj
rogertj is offline
PostPosted: Sun Mar 31, 2024 7:35 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
See if the harbor freight Bearing race and seal driver set help those are cheap and can sustain a pounding those are the ones that have and have always worked you can always see if the pricier ones are right for you.
Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
View user's profile Send private message MSN Messenger Twitter Gallery Classifieds Feedback
vw62kid
vw62kid is offline
PostPosted: Tue Apr 02, 2024 5:50 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Good idea! I'll definitely look into that! I've also had a couple people tell me that a cam bearing tool for a v8 works. I'll have to check both options out.
______________
Abscate Premium Member
Abscate is offline
PostPosted: Tue Apr 02, 2024 9:03 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
With all the uncertainties in these conversions its great to see that people will take a chance on an ABA
vanagonjr
vanagonjr is offline
PostPosted: Tue Apr 02, 2024 10:04 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
On the ABA that I resealed, I think I left the inner bearing alone, but I made a home made puller to remove to remove the outer one. I may have used it to install the bearing as well. I don't have access to it right now for pictures, but I used stepped plastic fitting from McMaster to press (or tap-hammer) the bearing in.
And I did wreck a bearing before developing a new approach.
I look and post a picture tonight. I should have some extra inner bearings that I could give you.
I could not get the oil hole in the bearing to align with such in the block very well, as I bearing rotates slightly as it is pressed in.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Apr 02, 2024 11:19 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Vanagon Nut wrote:
vw62kid wrote:
....Does anyone have any information on what bit you used to press these bearings in?
You might find info on that searching VW diesel engine re builds here.
I was searching for ?Waldo? posts and found this re IM shaft et al:
https://www.thesamba.com/vw/forum/viewtopic.php?p=...ng#9551749
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
vw62kid
vw62kid is offline
PostPosted: Tue Apr 02, 2024 6:52 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
vanagonjr wrote:
...I look and post a picture tonight. I should have some extra inner bearings that I could give you.
If BBM doesn't get back to me I might have to bug you for one of those Very Happy
______________
vw62kid
vw62kid is offline
PostPosted: Wed Apr 03, 2024 8:31 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Vanagon Nut wrote:
...I was searching for ?Waldo? posts and found this re IM shaft et al
It looks like he had a machine shop make his press tools. I bet those work nice. If the cam bearing tool doesn't fit the way I'd like it to I may have to see about something like this since I work at a metal fabrication shop.
______________
Kptstyle
Kptstyle is offline
PostPosted: Sun Apr 07, 2024 6:20 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
What are you using for a oil pan? I got the 50 deg pickup tube installed and my stock oil pan don’t fit? Thanks
connorsvw2
connorsvw2 is offline
PostPosted: Mon Apr 08, 2024 6:54 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
I saw a post on the Vortex recently about using a camshaft bearing driver for V8 engines for the IMS bearings. Of course now I can't find the bookmark...
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
Vanagon Nut
PostPosted: Mon Apr 08, 2024 11:23 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
This?
https://www.vwvortex.com/threads/nerding-out-on-intermediate-shaft-bearings.9534602/
One tool linked on that thread:
https://www.summitracing.com/parts/wmr-w89220
I might rebuild my spare ABA so thanks for that pointer.
Neil.
(VW Gas I4)
VE7TBN
vw62kid
vw62kid is offline
PostPosted: Tue Apr 09, 2024 4:24 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
You'll need the 50° oil pan off of a diesel vanagon. I purchased one off of ebay and it bolts up to the aba block.
______________
vw62kid
vw62kid is offline
PostPosted: Tue Apr 09, 2024 4:25 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
I've heard of this myself. BBM suggested using a cam bearing tool for a v8 as well. As soon as I receive my new bearing I'll grab one and take pictures of how it fits up to the bearing.
______________
Kptstyle
Kptstyle is offline
PostPosted: Wed Apr 10, 2024 6:30 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Thanks man oddly enough I couldn’t find this info anywhere .
vw62kid
vw62kid is offline
PostPosted: Thu Apr 11, 2024 3:20 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
For sure man! Yeah I just bought a no name oil pan off of ebay for a little over $100. (I think prices went up) Something like this. I bet the real vw one is better though.
https://www.ebay.com/itm/401776894531?chn=ps&m...efdaf3409e
______________
Kptstyle
Kptstyle is offline
PostPosted: Mon Apr 29, 2024 4:29 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Does the oil capacity change ? I put 4.7 qts in it with the pickup tube and 50 deg oil pan and my oil light is on I’m running 10w 40 oil thanks !
vw62kid
vw62kid is offline
PostPosted: Tue Apr 30, 2024 4:28 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
You installed the diesel oil pick up tube? The last aba swap we did we put a little less than what the diesel vanagon oil capacity is which I think is 4.8qts so it sounds like you're right with the oil capacity. I'm not really sure when it comes to this because I'm not at this step yet, but I've heard of people needing to prime their oil pumps. Maybe this could be causing it?
______________
Kptstyle
Kptstyle is offline
PostPosted: Tue Apr 30, 2024 7:18 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Yea I used the 50 deg pickup tube I’ll look into priming it thanks
Vanagon Nut
PostPosted: Tue Apr 30, 2024 7:51 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
edit: In light of Mark Wards post, I'm reminded of work I did on my 50º DV/ABA oil pump:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8854020&highlight=vanagon+nut#8854020
As a (still) engine rebuilding newb, I did my best but the oil pump still loses its' prime. But, the oil filter really helps with that.
To be clear i wasn't suggesting that *all* ABA swaps using the DV/ABA oil pump combo will have this "issue" but if one does, using the filter I point to could really help that.
end edit.
For a 50º ABA with diesel Vanagon pickup tube and ABA oil pump. Consider using this filter:
VW branded 06A 115 561 B (not Mann, Mahle)
image:
https://www.thesamba.com/vw/gallery/pix/2345750.jpg
Engine cold: this filter, vs Mahle, Mann, consistently shortens time my diesel-ABA oil pump takes to "pump up" at start. Pump sound takes only a full second at most to abate, even after engine not used for days or longer.
Neil.
(VW Gas I4)
VE7TBN
Page 6 of 10
