The Green Latrine
Forum Index -> Water-cooled VW Share: Facebook Twitter
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed May 01, 2024 7:53 pm    Post subject: The Green Latrine Reply with quote
I was given the opportunity to buy this ‘81 Caddy with a turbo diesel in it, & needing a multitude of repairs. With fuel prices ticking up, I decided to save $20 a day in fuel & run up the clock in this while addressing it’s ailments a bit at a time.
First up, let’s get rid of the donuts of death.
And replaced them with a set of 1” wider steelies off a Jetta.
Since the front struts were pretty sloppy, I scrounged up a pair of Bilstein struts I had laying around & slipped a pair of H&R springs over them that I’ve had so long, I don’t remember how long, or what they came off of. Confused
Oh well, it’s a start.
vwjunkie3
vwjunkie3 is offline
PostPosted: Fri May 03, 2024 5:58 am    Post subject: Re: The Green Latrine Reply with quote
That looks in great shape!! Nice VW pickup!
TDCTDI
TDCTDI is offline
PostPosted: Fri May 03, 2024 10:15 am    Post subject: Re: The Green Latrine Reply with quote
Thank you sir!
Today I carried on with picking away at stupid shit
After tracking down why the driver side turn signals didn’t work, I removed the front turn signal bulb that had the incorrect single element bulb (1156) & replaced it with a correct one (1157. Well, that at least made that side hyper blink, so I used that bulb & put it in the tail light.
Now that the turn signals work, I thought it would be pertinent to get the seat belts working. First up, extract the remains of the originals.
Pilfer a pair from a donor car…
And bolt them into place.
While putzing with the seat belt latches, I found the driver side vent wing glass under the seat, wanting close off that one side, I ran a bit of sealant around the perimeter, slipped it in place & secured it with a screw & washer at the leading edge.
Apparently, the PO attempted something similar with Great Stuff, judging by the missing passenger window, & the placement of this one, his hack wasn’t successful.
Having recently purchased another car with some sporty alloy wheels, I thought I might try them out on the Caddy.
However, after a quick drive, I realized that these were adding significant rotational mass & drag to the vehicle. And there was something else that bothered me about them …. Then I realized what it was, they look exactly like those horrible late mk1 hubcaps.
So off they came.
Then I decided to slam the rear end.
Just kidding, that’s how much it droops with 22 batteries in the bed. Laughing
TornadoRed06
TornadoRed06 is offline
PostPosted: Fri May 03, 2024 2:53 pm    Post subject: Re: The Green Latrine Reply with quote
Oh no! Another one that should be great to follow! Very Happy
Interesting, what width rims are these? 4.5 or 5 inch? I find tire width already meatier...
Those look nice, but aren't they with a chrome ring?
TDCTDI
TDCTDI is offline
PostPosted: Sat May 04, 2024 4:48 am    Post subject: Re: The Green Latrine Reply with quote
Thank you.
These are the stock 4.5” with 175/70-13 tires.
These are the Jetta 5.5” and, yes, they have the beauty rings on them. In my opinion, the beauty rings pull off an optical illusion that enhances the width of the wheel a bit. These wheels are shod with the same size tires as the previous set.
vwjunkie3
PostPosted: Sun May 05, 2024 8:02 am    Post subject: Re: The Green Latrine Reply with quote
Gotta love the nit picky things to repair/ Necessary evil...
It looks good with the steel wheels and small center caps.
What were the aftermarket wheels?
oprn
oprn is offline
PostPosted: Sun May 05, 2024 8:04 am    Post subject: Re: The Green Latrine Reply with quote
I love those little pickups! That is quite a rare color too. And to find one that rust free would never happen here!
TDCTDI
TDCTDI is offline
PostPosted: Sun May 05, 2024 11:26 am    Post subject: Re: The Green Latrine Reply with quote
Thank you.
The wheels were Ronal R10.
Yes, me too, I’ve had about a dozen over the years. I dunno about rare color, this will be my third in this color, although it’s much rarer. While I went back to green, I was never too fond of the ‘70s-esque gold-green this color is close to. I had my last one shot in the 2000-ish Jetta green.
Speaking of nitpicky stuff, with a few days of precipitation scheduled, i needed to plug the missing vent wing in the passenger door. Unable to source a replacement, I secured a piece of scrap plexiglass from a local hardware store & began paring it down to fit.
Unfortunately, when I took measurements, I failed to recognize that the divider is not at a 90° & is slightly laid back. This made the 15” height about an inch too short, oh well, I used the slight gap as a way to anchor the window with a screw.
Not pretty, but it’ll do until i find some proper replacements.
Another thing bugging me was the position of the wiper arms, I just wasn’t able to get them to align correctly, then it dawned on me & I swapped the arms & cinched them down.
Additionally, someone informed me that my passenger side brake light wasn’t functioning correctly & I traced it down to a bad bulb.
vwjunkie3
PostPosted: Sun May 05, 2024 12:05 pm    Post subject: Re: The Green Latrine Reply with quote
Need to find some bolt through vent window setups. Seen some for sale on the classifieds.
Only way to fix it and not have to deal with it again...
TDCTDI
TDCTDI is offline
PostPosted: Sun May 05, 2024 1:25 pm    Post subject: Re: The Green Latrine Reply with quote
Yes, i contacted that seller several times & they finally got back to me & said they couldn’t find the passenger side, & I haven’t heard back from them yet.
I also found a pair in a local yard, but they would only sell the complete doors at $200 each. They haven’t sold anything off that car for three years. Confused
vwjunkie3
PostPosted: Mon May 06, 2024 9:20 am    Post subject: Re: The Green Latrine Reply with quote
That's sad of those folks. I have 2 sets in cars yet.
Seems typical anymore.
TDCTDI
TDCTDI is offline
PostPosted: Mon May 06, 2024 12:03 pm    Post subject: Re: The Green Latrine Reply with quote
Having had a couple of MKI chassis fracture at the frame horns, & knowing my tendency to… ummm… let’s say “conserve forward momentum”, today’s project is to build a lower tie bar, so let’s turn this into one.
After a bit of trimming, drilling, & welding, I turned it into this.
I still need to fab up the triangulation legs, but this is a start.
While under there, I found the cause of the horrendous rattle I hear when going over bumps. What I thought was just a lack of brake pad shims is also compounded by missing caliper slide pin grommets.
Looks like I’ll also need some CV boots.
TDCTDI
TDCTDI is offline
PostPosted: Tue May 07, 2024 8:13 am    Post subject: Re: The Green Latrine Reply with quote
This morning I acquired the slide pin bushing kit.
It even came with the anti rattle shims.
So, let’s stuff them in.
First up is to install the shims.
Next, the bushings. My technique is to fold them over onto themselves & slide them onto the bores.
However, instead of them popping back into shape once in, they just wouldn’t. After removing it, I realized that some asshat tried to fill the void with epoxy.
Huh I don’t remember that being a factory friction surface.
So after some scraping & a final cleaning with a battery post terminal cleaner…
I finally got the bushings in & the caliper bolted back up.
While there, I took a moment to half ass a grommet for the brake hose by cutting a slit into a piece of hose
And slipping it into the bracket before stuffing the hose back in.
TDCTDI
TDCTDI is offline
PostPosted: Wed May 08, 2024 1:15 pm    Post subject: Re: The Green Latrine Reply with quote
I rubbed a couple minutes together & cut up a few more pieces of angle iron & clamped them to the chassis.
And then tacked the remainder of the square tubing in place.
After scrounging up another piece, I repeated the process on the other side & fused them together.
Once fully welded, I drilled holes through the chassis & brace & bolted it back in.
TDCTDI
TDCTDI is offline
PostPosted: Fri May 10, 2024 12:53 pm    Post subject: Re: The Green Latrine Reply with quote
Well, as everyone knows, early diesels were noisy, & rattly, however, this one was ever so much more so. With a generator light that would flicker at idle, & light up solid if the roads were wet, I decided to address the drive belt issue.
With a too long A/C belt, compounded by the compressor missing several mounting bolts, today’s endeavors quickly went downhill & required removal of the alternator & A/C compressor.
This has obviously been an issue for a very long time.
As it turns out, one of the bolts had sheared off in the bracket & not having enough room to drill it out in place, & not having the desire to remove the bracket (which also requires removing the injection pump.), I cheated by heating up the bracket & & coaxing the sleeve out of the bracket.
Once out, I used a left handed bit & extracted the remnants from the sleeve.
And, well, after that I got a correct sized belt, & got so deep into putting everything back together & forgot to take more pics.
Oh, well, until next time.
Ceckert64
Ceckert64 is offline
PostPosted: Tue May 28, 2024 6:51 pm    Post subject: Re: The Green Latrine Reply with quote
Awesome to see another one of your projects! I’ve been wanting a rabbit truck lately or a rabbit, this thread my convince me Laughing
I always enjoy seeing your upgrades on these, keep it up
“Rome” 91 Syncro
vwjunkie3
PostPosted: Wed May 29, 2024 9:27 am    Post subject: Re: The Green Latrine Reply with quote
Looking good sir. Sense of satisfaction when done helps alot!!
didget69
didget69 is offline
PostPosted: Mon Jul 15, 2024 3:01 pm    Post subject: Re: The Green Latrine Reply with quote
Oooohhh! A tow ball on bumper -
Good for towing a Flxible from West to East!
Dancing Dancing
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
TDCTDI
TDCTDI is offline
PostPosted: Tue Oct 29, 2024 5:35 pm    Post subject: Re: The Green Latrine Reply with quote
Needing a new tires, I opted for a different look & I wrapped some new sneakers around a set 13x7 steelies that I banded a while ago.
vwjunkie3
PostPosted: Wed Oct 30, 2024 7:26 am    Post subject: Re: The Green Latrine Reply with quote
Looking good. Nice steelies!!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
