dhaavers Samba Member
Joined: March 19, 2010 Posts: 8415 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Mar 09, 2024 5:25 pm Post subject: Re: 270 degree awning |
flemcadiddlehopper wrote: |
It is just under 8' out from the slider and only 7' out from the back. If you have room to unfold it at the slider, you should almost have room to open it all the way.
It is also a good excuse not to camp so close to others. But it can be used as a partial deployment. Just keep some of it bunched up and use the tie-downs to keep it spread... |
This sounds perfect…thanks!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
colins84 Samba Member
Joined: January 20, 2012 Posts: 92 Location: Newport Beach, CA
Posted: Sun Mar 10, 2024 4:23 pm Post subject: Re: 270 degree awning |
I have had my eye on a few of these awnings, but hadn’t seen anyone bit the bullet first…
Looking at the Overland Vehicle Systems Nomadic 270.
https://overlandvehiclesystems.com/Nomadic-Awning-270-Passenger-Side---Dark-Gray-w/Black-Cover
@flemcadiddlehopper when the awning is fully deployed, are you able to open the rear hatch?
Really nice to finally see some pictures of this awning on a Vanagon! _________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
1986 Vanagon GL (2.2L) |
Posted: Sun Mar 10, 2024 7:02 pm Post subject: Re: 270 degree awning |
colin, check out my link above…($685 <vs> $800)
I pulled the trigger today, mine arrives in a week or so. I’ll keep all y’all posted!
"The WonderVan"
E1 Samba Member
Joined: January 21, 2013 Posts: 8305 Location: Westfalia, Earth
Posted: Sun Mar 10, 2024 7:47 pm Post subject: Re: 270 degree awning |
Sweet, Congrats! _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sun Mar 10, 2024 8:20 pm Post subject: Re: 270 degree awning |
Actually, the way I have my set up right now,no. I have the hatch ladder with my spare on there. Future plans are for swing away carriers which would change that. So, with nothing on the hatch it will open.
Remember you can mount this awning at any height you wish.
gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
skemems Samba Member
Joined: February 23, 2017 Posts: 247 Location: Oregon
Posted: Mon Mar 11, 2024 9:44 am Post subject: Re: 270 degree awning |
We are quite happy with it.
Seems like this needs to be installed towards rear of van, to allow rear section to go around the van.
Was the front bracket not needed? (bracket between slider and passenger door)
Doesnt seem like anything is attached to it. _________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
Posted: Tue Mar 12, 2024 7:56 am Post subject: Re: 270 degree awning |
Yes you are correct. The awning does need to be mounted towards the rear to clear the pop-top.
The front bracket you see has not been attached to the awning yet. I have added a plate that reaches back to the awning in hopes to add a bit more torsional stiffness to the assembly. This is quite a heavy unit, 75lbs, and when opened without the support legs it does droop a good bit.
If using this awning on a tin-top with it mounted to a solid roof rack, that would not be a problem. But being a Westy, I only have 3" below the rain gutter for torsional support.
All of that is not an issue for me. It comes with six legs, three permanently mounted, and loads of straps, ropes and pegs to keep it all in place.
Gordo. _________________ Everybody Dies....Some Never Live.
rpureber Samba Member
Posted: Fri May 10, 2024 7:01 am Post subject: Re: 270 degree awning |
Gordo. |
I'd like to verify the brackets used for this. Is it these and how many are you using? https://gowesty.com/products/f45-awning-bracket-and-hardware-68-79?variant=42977842331813
I just ordered the awning to replace my Shady Boy and am very excited for the ease of use and great coverage. Do you know of a good way to rain gutter mount the awning (pop-top) without drilling the holes in the van? I spoke to Van Cafe yesterday and they said they're re-designing their ARB mount and they should be available in 3-4 weeks. Their current version doesn't look to require drilling into the van. I'm assuming either bracket would require drilling for the awning mounting holes. I'm fine drilling holes into the brackets I just always try to avoid drilling a hole into the van, if possible.
Thanks for any information you may be able to provide. |
Posted: Mon May 13, 2024 8:18 pm Post subject: Re: 270 degree awning |
My OVS 270 showed up today... man it is heavier than my current Shady Boy. I have two of the Shady Boy brackets drilled/installed on the outside edges of the slider... I'm wondering if I can easily fabricate a plate to mount the OVS 270 onto these brackets... then maybe add 1 or 2 of these for more support.
https://countryhomescampers.com/shop/custom-brackets-for-shady-boy-awnings/
Any thoughts? |
Posted: Mon May 13, 2024 9:37 pm Post subject: Re: 270 degree awning |
^^^ OK, here’s my $0.02…
I’m convinced that “standard” “flat” 10- or 11-ga brackets will eventually fail under the weight and/or wind exposure of this awning.
To wit, about a week ago…
I set mine up in the driveway for its first fitting, using (3) Van Cafe mounts placed similarly to flemcadiddlehopper above. The weight of the awning is so great that it was sagging significantly as soon as I tried to swing out the awning arms. It was a real struggle to keep the arms up and parallel to the ground as I worked to swing down the support legs.
Long story short, after about 45 minutes of adjusting & fine tuning, a single gust of wind blew the whole thing up, cranked two of the mounts off the rain gutter & then pulled the remaining single mount down with enough force to bend it almost 90 degrees from it’s original shape. I’ll allow that I did not have ropes anchored in the same way that I will in the future, but man…it only took a second, the force of the wind was undeniable and the weight of the awning structure caused complete failure of the mount(s). Scared me straight, just like in juvie…
To be clear, Flem started with standard GW mounts, but “boxed” in the structure and welded a taller plate to account for the 4-1/2” height of the awning rail upon which the whole structure of this awning is attached.
***I’ll ask flemcadiddlehopper to share pics of his bracket mods.*** (Please!!!???)
They look good, but he also mentions significant sag when swinging out the arms. The rain gutter is only so strong.
Me? I’ll be reinstalling my old arb-knockoff awning for a road trip this week, but when I get home I plan to spend about a week straightening my failed VC mounts, cutting the 1/4” steel OVS mounts (supplied with the awning) and welding those pieces to reinforce the VC mounts in every conceivable direction before attempting another fitting.
Just saying, if planning to mount on the rain gutter, I’d plan in advance to reinforce, reinforce, reinforce.
I also plan to bolt through my VC mounts into the rivnuts from my previous GW bracket install at the B & D pillars.
Did I mention to reinforce? 👿🙄🤷♂️
"The WonderVan"
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1198 Location: Atlanta, GA
Posted: Tue May 14, 2024 4:21 am Post subject: Re: 270 degree awning |
I know of at least one of two folks who made their own awning mounts from late model Beetle front bumper brackets. If those bend you probably will see a few characters from The Wizard of Oz whizzing by. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Posted: Tue May 14, 2024 7:58 am Post subject: Re: 270 degree awning |
Silverghost500 wrote: |
…late model Beetle front bumper brackets… |
Interesting…you mean “late” (1990’s?)…or “NEW” beetle (2000’s)?
Got a link? 🤔
"The WonderVan"
Posted: Tue May 14, 2024 2:16 pm Post subject: Re: 270 degree awning |
70's era Beetle bumper brackets. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Tue May 14, 2024 8:07 pm Post subject: Re: 270 degree awning |
70's era Beetle bumper brackets. |
Pics, please???!!!
"The WonderVan"
Corwyn  Samba Member
Joined: December 29, 2009 Posts: 2426 Location: Olympia, Washington
Posted: Fri Sep 20, 2024 8:48 am Post subject: Re: 270 degree awning |
Too much canvas. I like to go camping where and when I don't NEED my awning. It's usually only deployed IF it's going to rain. Just my humble opinion . . .  _________________ '90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
liamlrb Samba Member
Posted: Sat Feb 08, 2025 11:44 pm Post subject: Re: 270 degree awning |
If anyone has a file for these brackets, I can make a dozen and bring them down to syncrofest. I have a plasma table and press brake, but little time
ottoman308 wrote: |
Comes with 2 pretty heavy duty brackets. I'm mounting some custom gutter mounts I have to save myself any headaches. I swear these vans turn into the gift that keeps on giving.
4Gears4Tires Samba Member
Posted: Sun Feb 09, 2025 8:18 am Post subject: Re: 270 degree awning |
Interesting first post!
Welcome to the samba. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Sun Feb 09, 2025 10:49 am Post subject: Re: 270 degree awning |
liamlrb wrote: |
ottoman308 wrote: |
FYI: These ^^^ are the stock brackets that come with the 270 awning.
Readily available, but really only useful with a roof rack. I contacted ottoman about his
“custom mounts” but it turns out he’s also mounting to a roof rack, not rain gutter.
Lacking anything better, I plan to cut these up to add reinforcement to my GW mounts which
failed last year. This work will wait until spring…still only 10°F in my unheated garage...
"The WonderVan"
Vana408Goon Samba Member
Joined: January 09, 2025 Posts: 3 Location: San Jose CA
Posted: Wed Feb 19, 2025 1:02 pm Post subject: Re: 270 degree awning |
Hi , following this thread in hopes for a solution.
I recently purchased a Nomadic 180 awning (was most appealing awning to me)
Had seen a video on YouTube of it installed on a vanagon. Now am trying to install on my 91 weekender pop top. Want to install onto the Rain Gutters but seeing how heavy this awning is . All the “available brackets for a T3” just won’t hold up. Mounting onto crossbars will interfere with functionality of the pop top.
Found some brackets from Europe used on T5 & T6 models by company called Vamoose that do not interfere with pop top functionality.
Only issue I can’t find a seller in the U.S. of A.
TheBigE Samba Member
Joined: December 14, 2014 Posts: 5 Location: Okanagan BC Canada
Posted: Thu Feb 20, 2025 10:43 am Post subject: Re: 270 degree awning |
I installed a right hand drive model from Australian company Bushwakka. It pivots on the passenger A pillar. I love it.
