Your installing your swing axle seals wrong!!! Read this..
Rockbound
Rockbound is offline
PostPosted: Fri May 10, 2024 10:40 pm    Post subject: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
Ok so I’ve searched and read just about every thread on leaky axle seals. I’ve been battling seals for years since I built my buggy. Constant leaks, tried everything I read but never saw, or maybe just didn’t pay attention to assembly order of part if it was written somewhere. I’ve always installed according to the explained view. But finally after the 4 time replacing them something clicked in my head.
So. According to this view here was my solution and order of install. Finally no more leaks.
After bearing is installed and after new seal and splash washer installed in cover.
1 - install #7 washer
2 - install #8 sealing ring
3 - install #9 sealing ring
4 - *** DO NOT INSTALL OUTER SPACER ON AXLE SHAFT.
5 - install outer spacer into oil seal in the cover on your bench
This ensures the seal is properly seated around the outer spacer and you can
see what’s going on with the seal, instead of crushing it when installing cove over it on the axle.
6 - install paper gasket
7 - install cover and outer spacer onto axle shaft and tighten cover
modok
modok is offline
PostPosted: Fri May 10, 2024 11:28 pm    Post subject: Re: YOUR INSTALLING YOUR SWING AXLE SEALS WRONG!!! Read this.. Reply with quote
good tip
nsracing
nsracing is offline
PostPosted: Sun May 12, 2024 7:31 am    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
all you gotta do is pay attention to what you are installing. many just slap the parts and see what leaks. Laughing
esde
esde is offline
PostPosted: Sun May 12, 2024 8:26 am    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
There is also the issue of mismatching axle tubes, backing plates, and bearing retainers. There are several changes in the bearing bore depths, and backing plate thickness. Use the wrong combo of parts and the big o-ring is not going to seal the deal. Spending a few minutes to polish the seal spacer is also always a good idea.
SD
modok wrote:
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Mon May 13, 2024 1:11 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
Firstly.... I am not a mechanic..... just a hobbyist.
On mine..... It leaked.
When I pulled it down I did notice the small o ring was not crushed.... but did not think anything of it at first.
But when went back together with a new seal kit I do notice the spacer bottomed out before feeling spongy on the ring.
Come to find out the o ring was too thin in cross section diameter. Bought another kit, still not right. Dug through the junk pile and all the spacers I found all had the same chamfer. I got some empi spacers and the chafer was smaller and the length longer. I lathed on them until I felt I had the right amount of crush between that chamfer and I ring. I think I used a generic o ring out of the assortment kit at my employment.
Since that time I have helped a couple friends and theirs was the same way.
So
check the crush on the small o ring.
if you have a disc brake kit then check the crush on the large o ring also.
especially on a swing axle.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
Busstom
Busstom is offline
PostPosted: Mon May 13, 2024 3:18 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
DeathBySnuSnu wrote:
Come to find out the o ring was too thin in cross section diameter...
I got some empi spacers and the chamfer was smaller and the length longer...
Okay, well this sucks. So aftermarket parts are drifting and not matching dimensions of OE parts? I wonder who's deciding to change them and consider it acceptable. Empi? No surprise there.
Can you clarify? Did you chuck the spacers up on a lathe and turn them until you had an appropriate height?
cory464 wrote:
DeathBySnuSnu
PostPosted: Mon May 13, 2024 5:16 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
I did get from a couple different sources.
The most expensive was the same as the cheapest except for the name on the lip seal. I am talking fit only, do not know durability.
The parts that came closest to fitting was empi seal kit and the empi spacer.
The width/depth of the chamfer was still to large.
I think I picked a generic o ring and trimmed the face true and cut the chamfer until it fit the way I wanted.
The empi spacers were too long and I had plenty material to work with. They were fairly hard but not as hard as stock.
Now I do think this is all swing axle.
I have since built my IRS and even though a lot of it is empi most of it measured out and did not take much to fit.
Root_Werks
Root_Werks is offline
PostPosted: Wed May 15, 2024 10:17 am    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
Putting the spacer in the seal before placing the hub on the axle is a good tip. Learned that number of years back. Easy for the spring in the seal to fold or pop out.
When I set my timing, why do I flush, then take a pee?
petrol punk
petrol punk is offline
PostPosted: Thu May 16, 2024 6:29 am    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
SD
This is true. I put 58-64 brakes on my '56 split case and it always leaked no matter what I did. turns out the newer backing plates were I think 0.5mm thicker. I swapped the axle tubes out with some 58-60 split case axle tubes and I haven't had a leak since.
36hp '56 European DeLuxe oval
'70 bug 1835cc
sjbartnik
sjbartnik is offline
PostPosted: Fri May 17, 2024 3:06 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
It's a great tip which I learned the hard way. One time put the spacer in after the cover plate was already on the axle - it dislodged the spring from inside the seal and it leaked like a sieve.
So now the spacer always gets lubed up and put in the seal before the cover goes on the axle.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
esde
esde is offline
PostPosted: Fri May 17, 2024 3:39 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
petrol punk wrote:
SD
Yes, you either swap the tubes to match the other brake hardware, or machine the bearing cap to accommodate the thicker backing plate
modok wrote:
clonebug
clonebug is offline
PostPosted: Fri May 17, 2024 6:43 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
I ordered a bunch of new o-rings online that were a higher quality than the ones in the kits. I replace the large o-ring with one from oringsandmore.com and it does seem to help with leakage. My last install has held for 3 years now.
There are also differing levels of quality between the brands of axle kits you can buy.
I've also found the seal is very sensitive to the installation of the spacer. It is very easy to damage and roll over the seal lip. Putting the spacer into the seal before installing the bearing cap helps immensely in not damaging the seal during install.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
EVfun Premium Member
EVfun is offline
PostPosted: Fri May 17, 2024 9:17 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
I was curious about how you tried this. Did you grind the sides of the '56 axle bearing caps and then use them with the later backing plates, or use the later bearing caps that clear the center reinforcement on the later brake backing plate?
The reason I ask is that I was told if the original oval window era bearing caps where modified to clear the reinforcement in the later backing plates it would work. If the later bearing cap was used I was told it would leak. I haven't personally done an oval brake swap, but did consider it at one point.
Going back to the original post in this thread I want to point out that there is no part 13 in the end caps prior to 1965. It makes the seal easy to install from the outside with a flat block of hardwood. The paper gasket, part 11, was not used on pre-'65 Bugs as there is no weep hole to seal. I'm running the '58-'64 brakes on my buggy.
Wildthings wrote:
esde
esde is offline
PostPosted: Sat May 18, 2024 2:59 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
strange timing, that one of the new axle seals on my rebuilt split case trans is dripping.. and I was very careful during the installation. Check it out:
The o-ring behind the spacer got pinched into the little gap between the shim #7 and the axle. I don't know if it's a problem with the shim or O-ring, the spacer is stamped VW so I assume it's got the correct bevel to fit against the o-ring. This is a Wolfsburg West seal kit, and to be honest I do not like them.
Here's the spacer and o-ring after picking it out.
My current plan is to leave the rubber thats stuck in the shim, and fit a new o-ring to see if it still leaks. If it does I'll R&R the whole thing with new shims and seals.
Yes, you have to grind the sides of the early cap to fit the hourglass shape of the backing plate stiffener.
Here: halfway down page 3 I have measurements and pics of different early swing axle tubes, backing plate thickness and bearing cap details. Mundane details to attempt fixing a leak..
https://www.thesamba.com/vw/forum/viewtopic.php?p=10175866&highlight=#10175866
EVfun is offline
PostPosted: Sat May 18, 2024 3:22 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
Interesting, so that 0.5mm is a problem with later backing plates. There are other differences between the steps in the sealing that make mixing pre and post ‘57 axles tubes and axle tube end caps a no-go. Somewhere I found dimensional drawing of both side by side.
I had an oval with a 40 horse transaxle and the older stock brakes and never had a problem with that 1/2 mm the other way.
Wildthings wrote:
neil68
neil68 is offline
PostPosted: Sat May 18, 2024 6:09 pm    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
#7 washer should be 0.75 mm thick as per OEM.
I had some aftermarket rebuild kits supplied with 0.5 mm washers and had an annoying leak. After buying new German kits with 0.75 mm washers, the leak was fixed:)
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
Fender38
Fender38 is offline
PostPosted: Mon May 20, 2024 9:59 am    Post subject: Re: Your installing your swing axle seals wrong!!! Read this.. Reply with quote
I learned how to do this properly a number of years ago from watching a YouTube video. It was from a mechanic in the UK. And just like the diagram you posted, I remember the paper gasket was one of the last parts installed, which I thought was strange at the time. Well, mine have never leaked a drop after that. So, I'm a believer.
