67 bug----- will 60 thru 66 fenders fit on front and rear ?
xliny
xliny is offline
PostPosted: Thu Apr 24, 2014 7:15 pm    Post subject: 67 bug----- will 60 thru 66 fenders fit on front and rear ? Reply with quote
hi folks,...... I just bought a 67 bug and wanted to know if fenders from a 60 thru 66 bug fit on the front and rear THANX IN ADVANCE Smile
RareAir
RareAir is offline
PostPosted: Thu Apr 24, 2014 7:30 pm    Post subject: Reply with quote
Yes, those fenders will fit your '67 just fine.
If you're going for 100% originality, you'll want to look for 1962-67 rear fenders. Otherwise the tail light mounting holes will need to be re-drilled to their proper locations.
As for the front, US specification Beetles had a 1 year only 1967 style fender. If you don't care about that, then 1964-66 front fenders match best. Anything earlier & you'll need to change the front turn signal type.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
ZENVWDRIVER
ZENVWDRIVER is offline
yes, all 4 pre '67 fenders will fit on a '67.
I once bought a '63 ragtop with '67 fenders on it.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
xliny
xliny is offline
PostPosted: Fri Apr 25, 2014 5:21 am    Post subject: Reply with quote
thanx people,....you folks are awesome !
67 Sunroof
67 Sunroof is offline
PostPosted: Fri Apr 25, 2014 5:23 am    Post subject: Reply with quote
I JUST posted this question a week ago. I planned on keeping the original fenders and getting earlier fenders and painting them ALL the same time so if I decide to go back they are already painted!!
Gilbert Alvarez
Gilbert Alvarez is offline
PostPosted: Sun May 19, 2024 6:10 pm    Post subject: Re: 67 bug----- will 60 thru 66 fenders fit on front and rear ? Reply with quote
Hi everyone,
I need rear fenders for my 60 rag. Will rear fenders from a 63 fit?
Rome
Rome is offline
PostPosted: Sun May 19, 2024 10:05 pm    Post subject: Re: 67 bug----- will 60 thru 66 fenders fit on front and rear ? Reply with quote
^ Yes, but if you transfer your '60 taillamps to the '63 fenders, they'll be too high... And I think the holes in the fenders for the taillamp mounting studs will be a larger distance than for your '60 housings, so that you'll need to drill at least one new hole. Many people won't notice the difference in taillamp height but some of us here do.
