djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2365 Location: Graz, Austria, Europe
indianpeaksjoe Samba Member
Posted: Thu May 23, 2024 3:21 pm Post subject: Re: What did you do to your Beetle this week? |
djfordmanjack wrote: |
Do you use 1/2 throttle or more at starting hot, without pumping the accelerator ? |
I've tried 1/2 throttle, full throttle, 1 pump, 2 pumps, 3 pumps, etc
I am at 5500'. It starts like a brand new car when cold, even below 0. It always push starts while this is happening FWIW.
-Joe _________________ Adventures in owning a 66 beetle |
Posted: Fri May 24, 2024 12:07 am Post subject: Re: What did you do to your Beetle this week? |
Interesting, I certainly thought about you probably living and driving on high altitude. air is a lot thinner on 5500' than on sea level. but you have probably adjusted the carb to that anyways.It's peculiar, that the hot start relais won't help.
Is the starter still a lot slower than on cold start ?
It sounds as if it may short out a bit, draw more amps and weakens spark. since it push starts easily (so it must get gas AND spark).
What air cleaner do you have on the carb? _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2864 Location: Thornton, CO
Posted: Fri May 24, 2024 7:17 am Post subject: Re: What did you do to your Beetle this week? |
If you're pumping the throttle (to the floor), even once, in a warm/hot start situation, you will open the choke, and then, at least in my experience, the car will not start. I have to go back and manually release the choke for it to start.
In today's perfect FI world, people tend to forget how iffy carbs could be in some situations. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11093 Location: Oregon
Posted: Fri May 24, 2024 4:11 pm Post subject: Re: What did you do to your Beetle this week? |
The warm engine start procedure is outlined in the owners manuals.
In this case, a 68 read the owners manual page 18, At temperatures above above freezing point or warm starts,
https://www.thesamba.com/vw/archives/manuals/1968b...ransit.pdf
Note the last line in the instructions. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Mon May 27, 2024 2:25 pm Post subject: Re: What did you do to your Beetle this week? |
I swapped to 90° elbows on the pump, swapped in the metal 3031 filter and shortened the hoses. The beetle has been great on the two drives since then.
I changed the oil, added MOA and cleaned the strainer.
Got caught behind this cool camper, fortunately it was going 40 in a 65, which is fine by me.
Posted: Sun Jun 09, 2024 12:13 pm Post subject: Re: What did you do to your Beetle this week? |
In my continued hot start troubles I replaced my new beru coil with a Pertronix, replaced the wire from the starter to the alternator and replaced the wire from the coil to both sides of the carb.
Posted: Sun Jun 09, 2024 1:01 pm Post subject: Re: What did you do to your Beetle this week? |
I also added led rock lights on my roof basket to act as emergency flashers. Since they are going through the spod I can run them fully on, flashing or strobe(super fast flash).
Posted: Tue Jun 11, 2024 11:52 am Post subject: Re: What did you do to your Beetle this week? |
OK today I once again think I might have fixed the hot start issue, could it be a bad distributor? I had a no-name electronic distributor and a no name starter. I replaced them both. I put in a pertronix and a bosch starter. It sounds good to me. Short test drive was good, I need to drive a little further. But hopefully this fixed it. I mean... how many more things can I replace ! It sounds noticeably better now.
KingAir42 Samba Member
Joined: May 24, 2002 Posts: 618 Location: Bakersfield California
Posted: Wed Jun 12, 2024 8:24 pm Post subject: Re: What did you do to your Beetle this week? |
I replaced my generator. It was my first time doing the removing the fan nut without lifting out the shroud method. I can remove a generator in 15 minutes now! _________________ A stitch in time saves nine |
shanered Samba Member
Posted: Fri Jun 14, 2024 9:56 am Post subject: Re: What did you do to your Beetle this week? |
KingAir42 wrote: |
I replaced my generator. It was my first time doing the removing the fan nut without lifting out the shroud method. I can remove a generator in 15 minutes now! |
your fan is expensive, delicate and sensitive to off balance, misplaced spacers and shims can cause damage to fan hub slot. Been working on vws 25 years, never liked that method, isnt that hard to pull lid/shroud and a properly prepped generator will outlast two full life span motors.....  |
WVDriver Samba Member
Joined: May 18, 2024 Posts: 10 Location: West Virginia
Posted: Sat Jun 15, 2024 2:11 am Post subject: Re: What did you do to your Beetle this week? |
Installed new drums, front brake shoes, front wheel cylinders, master cylinder, and brake light switch. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33091 Location: Hot Arizona
Posted: Sat Jun 15, 2024 7:23 am Post subject: Re: What did you do to your Beetle this week? |
WVDriver wrote: |
And apparently did a great job, as I see no complaints about brake bleeding !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Jun 16, 2024 8:35 pm Post subject: Re: What did you do to your Beetle this week? |
Had to change my oil again, when I put the sump plate back on 50 miles ago it developed a leak. It was warped from age and over tightening. I could have banged it straight, but honestly I didn’t feel like risking a leak still being present. So a new Empi plate and fel-pro gasket.
More pics here : https://robonza.com/beetle/index.php/2024/06/15/leaky-oil-sump-plate/
bandi Samba Member
Joined: August 24, 2005 Posts: 1100 Location: Campbellford, Ontario, Canada
Posted: Wed Jun 19, 2024 6:46 pm Post subject: Re: What did you do to your Beetle this week? |
I slept in it for three nights in a row at a vintage racing festival! I made a folding plywood panel roughly the same shape as the passenger floorpan - at night, I removed the passenger seat, put two milk crates down which I had camping gear in, unfolded the plywood piece, put a camping mattress on top, a pillow on the back seat, and honestly had a very comfortable sleep!
(I am not tall) _________________ '60 Canadian Standard, '64 Bug, '66 Bug, '66 Bus, '69 Sunroof Bug, '71 Super, '72 Super, '73 Canadian Custom, '73 Super, '74 Love Bug, '83 Mexi Bug, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S. And some Fieros. |
Posted: Sat Jun 22, 2024 8:45 pm Post subject: Re: What did you do to your Beetle this week? |
Bandi that is awesome!
I put a little padded p-clamp on the fan shroud to keep the gas line away from heat sources. I used a nutzert to secure it.
Posted: Sat Jun 22, 2024 8:53 pm Post subject: Re: What did you do to your Beetle this week? |
I also replaced my cracking intake boots with the ingenious EMPI split boots. So easy!
