BMFBMF Samba Member
Joined: November 13, 2020 Posts: 457 Location: Swtzerland
Posted: Sun May 26, 2024 1:02 pm Post subject: Pretreating death foam |
All this talk on the other thread about the rear window vents have made me wonder about my 71.
Car lived in a dry salt-free place and so has very little rest, but I wonder if I should preemptively zap inside the death foam cavity with cavity spray from both the inside and from the outside vents?
Can't hurt right? _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1514 Location: Modesto, CA
Posted: Sun May 26, 2024 1:13 pm Post subject: Re: Pretreating death foam |
I'm with you. I bought my car in Mojave, where it lived a pampered life out of the Sun's destructive gaze. My death foam is, thus far, healthy and intact. I often wonder if I should preemptively deal with it
H2OSB _________________ (o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2002 Location: Wichita, KS
Posted: Sun May 26, 2024 1:23 pm Post subject: Re: Pretreating death foam |
I think the main thing to worry about is water being able to get in along sheet metal seams of the vent area, and/or along edges of the rear window. If both those areas are adequately sealed, water shouldn’t be able to get in and then seep/wick below into the space between the foam and sheet metal. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
AZ guy Samba Member
Posted: Sun May 26, 2024 3:33 pm Post subject: Re: Pretreating death foam |
As the guy who started the rear windows posts, would you quit making more things for me to think about/do.
I've got enough on my hands already.
Meanwhile, what is it I should spray in there? |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 999 Location: half a bubble from plumb
Posted: Sun May 26, 2024 3:57 pm Post subject: Re: Pretreating death foam |
Maybe start by pulling the rear side panels & shine a light in there, hoping the foam isn't totally obstructing the metal.
Ospho stuff would need to be neutralized.
A quality paint that encapsulates would be best.
Perhaps shoot Eastwood an email.
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10931 Location: Oregon
Posted: Sun May 26, 2024 4:16 pm Post subject: Re: Pretreating death foam |
Didn't VW start using the death foam beginning in 1973?
If so, why is this an issue on a 71 in Europe? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1692 Location: Central Pennsylvania
Posted: Sun May 26, 2024 6:37 pm Post subject: Re: Pretreating death foam |
67rustavenger wrote: |
If so, why is this an issue on a 71 in Europe? |
Pretty sure VW started using the foam by 1970 or even earlier (perhaps 1967 or 1968?). My car is a 1971 and definitely has the foam in it.
Before that, they stuffed triangular “pillows” up in there to help combat noise from the engine compartment. The noise level from the back was always an issue, and suspect the foam performed a lot better than the pillows at reducing that. _________________ 1971 Standard Beetle — fairly stock / driver
beetlenut Samba Member
Posted: Sun May 26, 2024 9:20 pm Post subject: Re: Pretreating death foam |
Sounds good in theory, but the foam is bonded to either side of the inner and outer metal. If you're hoping the foam absorbs the ospho or encapsulator, doubt it would absorb enough to stop all the rust. Condensation is the chief way water gets in there.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
vamram  Samba Member
Posted: Mon May 27, 2024 5:43 am Post subject: Re: Pretreating death foam |
My '72 had death foam so it definitely began before '73. I cleaned it out as best I could from the engine compartment and reaching from inside the rear seat side panels, sprayed with rust converter, primer, paint, then undercoating. Then stuffed a couple of those chemically expanding packaging foam bags in there. Was fine for 3 years then I sold it in 2018 so I've no idea how that whole thing held up.. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
empi3 Samba Member
Joined: October 03, 2015 Posts: 379 Location: SW Wyoming
Posted: Mon May 27, 2024 6:11 am Post subject: Re: Pretreating death foam |
Looks like Aug '65 making it the 1966 model year.
From "Progressive Refinements"
Steven _________________ The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle
1968 Ghia |
dopeboat Samba Member
Posted: Mon May 27, 2024 7:44 pm Post subject: Re: Pretreating death foam |
IMO if your car has the foam, you should get it out of there. Sure, you could squeeze some sealant into where the crescent vent seals sit, but you’re kicking a potentially very expensive and annoying can down the road. I just completed my death foam repair and I certainly wish somebody had caught it sooner. Best case scenario, you open up those sides (from INSIDE the vehicle), and once the foam is out of the way, there’s some lovely painted metal staring back at you. Worst case scenario, it’s swiss cheese that a previous owner has filled in with JB weld and painted over. Either way it’s better than waiting for it to rot from the inside out, which as I understand it, is inevitable. Does anybody have a car with death foam that has opened the area up and found it completely unaffected? _________________ '77 FI Bahama Blue Type 1 |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5552 Location: Lefty, CA
vamram  Samba Member
Posted: Tue May 28, 2024 4:15 am Post subject: Re: Pretreating death foam |
As I understand it, water proof foam won't necessarily solve the problem since moisture between the foam and the metal is where the rust happens. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Tom K. Samba Member
viiking Samba Member
Joined: May 10, 2013 Posts: 3125 Location: Sydney Australia
Posted: Tue May 28, 2024 6:02 pm Post subject: Re: Pretreating death foam |
My unmolested Euro Feb 68 still had the pillows inside and no-rust. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
BMFBMF Samba Member
Posted: Tue May 28, 2024 9:54 pm Post subject: Re: Pretreating death foam |
Thanks for the input guys. _________________ -----Slava Ukraini-----
Posted: Wed May 29, 2024 5:05 pm Post subject: Re: Pretreating death foam |
Did you have foam or pillows? _________________ '77 FI Bahama Blue Type 1 |
vamram  Samba Member
Posted: Wed May 29, 2024 5:52 pm Post subject: Re: Pretreating death foam |
dopeboat wrote: |
Did you have foam or pillows? |
Tom K. wrote: |
....The "death foam" does not absorb moisture. Once I apply liberal sealant above and below my good seals as a safety measure and then paint the entire cabinet with several coats of Eastman's cavity paint, I plan to simply spray closed cell foam right back in there - but further aft of the vent window (where the pillows originally were placed) to allow me to inspect whenever I want the area under the seals through the inner holes that I cut. I'm also thinking about mounting speakers into those holes. |
Click to view image
Save the Supers!! |
