Lightweight drums
PV AUTO
PV AUTO is offline
PostPosted: Sat Jun 01, 2024 3:18 pm    Post subject: Lightweight drums Reply with quote
So I bought a old 80s sand rail and came with some unique lightweight drums. Does anybody remember these? They look like they had alot of work to make them look like this. Looks like a death trap though lol
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sat Jun 01, 2024 3:32 pm    Post subject: Re: Lightweight drums Reply with quote
Not for serious stopping. Imagine how quickly they would heat soak with such little mass on the friction surface Laughing Laughing
1800 Type 4 Berrien 295
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Sat Jun 01, 2024 3:45 pm    Post subject: Re: Lightweight drums Reply with quote
Chromed too. That can't help with the heat.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jun 01, 2024 5:36 pm    Post subject: Re: Lightweight drums Reply with quote
I don't see any brake linings or shoes.
Show car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busdaddy
busdaddy is offline
PostPosted: Sat Jun 01, 2024 5:41 pm    Post subject: Re: Lightweight drums Reply with quote
Glenn wrote:
Show car.
I agree, but I do see shoes and lining peeking out on the sides. those are pretty good, but in this case much more pretty than good.
Слава Україні!
Mr. 010
Glenn is offline
PostPosted: Sat Jun 01, 2024 6:00 pm    Post subject: Re: Lightweight drums Reply with quote
Now I see them, the holes are not see through.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
oprn
oprn is offline
PostPosted: Sun Jun 02, 2024 5:16 am    Post subject: Re: Lightweight drums Reply with quote
I would limit those to 40 mph maximum on back country trails and sand. Or on and off the trailer at car shows.
I think those would flex enough to make for a spongy brake peddle. They would shed water and sand pretty well though...
Dusty1
Dusty1 is offline
PostPosted: Sun Jun 02, 2024 6:52 am    Post subject: Re: Lightweight drums Reply with quote
Brakes just slow you down. The brakes on my old VWs are fantastic compared to brakes on my old motorcycles. Y' all are spoiled rotten with these new fangled disks with ABS and stuff.
Then again, y' all lived long enough to tell about it... Rolling Eyes
Drill 'em fulla holes on a sand buggy. That lets the sand out. Otherwise the sand grinds away at the shoes and makes the drums all groovy.
NJ John
NJ John is offline
PostPosted: Sun Jun 02, 2024 8:45 am    Post subject: Re: Lightweight drums Reply with quote
Yes, I’m sure that a 100% sand modification. Probably locks up the rear wheels of the rail, just fine.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Busstom
Busstom is offline
PostPosted: Sun Jun 02, 2024 9:23 am    Post subject: Re: Lightweight drums Reply with quote
What's odd is, it looks like the majority of the backing plate has been machined away too, which would make for more sand ingress in the first place. But some of the plate must remain, or what else could be holding the slaves and shoes?
cory464 wrote:
QRP
QRP is offline
PostPosted: Sun Jun 02, 2024 10:25 am    Post subject: Re: Lightweight drums Reply with quote
Anyone who has ever been to the dunes knows that once you let off the gas you basically stop moving!
This is perfectly acceptable for a dedicated sand car.
No matter what the sand will get into the drums so the idea behind this is to get the sand out faster.
Although I wouldn't have drilled such large holes on the OD and instead made more smaller ones.
67rustavenger
67rustavenger is offline
PostPosted: Sun Jun 02, 2024 10:34 am    Post subject: Re: Lightweight drums Reply with quote
Drilling the drums to let the sand out is old school tech from 40+ years ago.
I had seen it on many sand cars back in the day at Pismo Beach.
Yes back then the holes were drilled that large and the backing plates cleared as well.
I have never seen the web portion of the drums drilled, so that's a new one to me.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
EVfun Premium Member
EVfun is offline
PostPosted: Sun Jun 02, 2024 1:44 pm    Post subject: Re: Lightweight drums Reply with quote
I remember seeing a sand rail where it looked to me like they un-spot-welded the sheet metal part of the backing plate off the stronger stamped center strap. The drums where not drilled. I think the backing plate modification pretty much necessitates the use of '64 or earlier brakes, with the narrow slot wheel cylinder and adjusters, since those slots are the only thing locating the brake shoes (no center hold down spring).
I have wondered if that modification is safe. It would look pretty cool on the front of a beach buggy.
Wildthings wrote:
Dusty1
Dusty1 is offline
PostPosted: Sun Jun 02, 2024 4:22 pm    Post subject: Re: Lightweight drums Reply with quote
When I say, "I'm into bikes." most people assume motorcycles. I've cut down to maybe three dozen motorcycles. I still have a ton of bicycles. The old school lightweight bicycles use a substance called
drillium
which replaces metal with negative space I mean holes. Old Campagnolo parts are loaded with holes all carefully drilled and chamfered by a real old school craftsman.
I wandered around the Nationals yesterday looking at drilled out parts among other things. The proliferation of finite element analysis and CNC facilitates some fancy patterns. Cool
Mr. 010
Glenn is offline
PostPosted: Sun Jun 02, 2024 4:39 pm    Post subject: Re: Lightweight drums Reply with quote
drillium
Carbon fiber
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
