idle fluctuation up/down running RICH 84 Digijet 1.9L
peaceman
peaceman is offline
PostPosted: Sun Jan 11, 2009 10:58 am    Post subject: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
HELP please. I have searched and have only found bits and peices on the forum.
So my 84 Westfalia 1.9 digijet idle would fluctuate up and down once the engine was warm. It would not change- constant up and down.
I found a bad connection to the O2 sensor and that fixed the problem.
NOW it runs way rich. I have unplugged the O2 sensor and it still is blowing black smoke. the new spark plugs are black and sometimes wet with fuel.
Now it wont start.
PLEASE HELP. Should I turn the AFM a couple clicks clockwise?
SHould I hook up the O2 sensor or not?
WHere can I find info on troubleshooting this stuff. THe bently manual is useless since I do not have a graph meter YET.
PEace,
Jeff
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Jan 11, 2009 11:13 am    Post subject: Reply with quote
It sure sounds like the throttle positioning switches.
The Bentley really is terrible for diagnosing & resolving injection problems.
Take a ride over to the samba.com Vanagon parts section.
I have a Digijet factory injection manual available that will help you dial in your 84.
If you can't find the manual there,go to;
http://community.webtv.net/VanStuff/VanagonWestfalia
T.K.
tencentlife
tencentlife is offline
PostPosted: Sun Jan 11, 2009 11:56 am    Post subject: Reply with quote
Sounds like a classic ground fault in the O2 sensor signal circuit. I'm just going to copy the procedure here from another thread, to save you having to hunt around. With an ohmmeter this is pretty easy to check, and usually easy to repair unless the fault is in some buried location:
Check it exactly like this:
Disconnect the single-wire signal lead of the O2 sensor from the green coax. You will find the connection hanging between the left cylinder head and the left wall of the engine bay.
(If your van has a three-wire heated sensor, you can leave the two-pin heater plug for the sensor connected; it has nothing to do with the signal circuit).
Leave the disconnected end of the green coax hanging free. Make sure it won't touch ground inadvertently.
Ignition off! Disconnect the multi-pin connector from the ECU.
Put VOM in ohms mode, lowest-range if not auto-ranging.
Connect one VOM probe to the free end of the coax center wire.
Touch the other probe to ground. You should only ever see infinite ohms (open circuit). This verifies that the signal wire is not inadvertently shorting to ground. With the probe still attached, move the coax wire around a bit and watch that there is never any continuity to ground.
Leave the probe connected at the signal wire of the coax. Now touch the other probe to the O2 signal pin at the ECU harness plug. You should see zero ohms. This confirms that you have a continuous signal circuit.
Pull the small rubber boot back from the double-male connector that should be on the free end of the coax. Now take the first probe from the signal wire at the end of the coax, and touch it instead to the coax sheathing braid. Touch the other probe to ground. You should see zero ohms. This confirms that the noise-suppressing sheathing is properly grounded (it is grounded up near to the ECU harness connector).
That is the complete, isolated test of the signal circuit and noise-suppression.
Don't concern yourself with checking the resistance of the O2 sensor to ground (irrelevant), the resistance of the O2 signal circuit thru the ECU (also irrelevant). Confine your tests to the signal coax in isolation.
The area to inspect very closely is the free end of the coax. Many times the ground fault is due to the fine wires of the sheathing braid fraying and coming into contact with the signal core wire or connector. Trim back the sheathing and make sure not a single braid wire can reach any part of the center wire.
If the fault isn't there, sometimes the coax has been mashed or pinched somewhere, causing internal damage where the braid is forced thru the center wire's insulation. You should do a careful visual check of the whole coax run looking for damage.
Now, there's also a quicky functional test for grounding of the O2 signal circuit with the engine running and warmed up, everything connected as normal including the O2 sensor (this test also works with the o2 sensor disconnected). Under those conditions, you take a jumper from ground and connect it to the O2 signal connection (or simply ground the free end of the coax signal wire with the sensor disconnected). Whenever you ground the signal wire, the engine should noticeably alter speed and run stink-rich. If there is no change, then there is already shorting to ground somewhere of the O2 signal. If it does change to a very rich idle, and back to normal when you unground, then functionally all is fine with the signal circuit. This does not confirm anything about the quality of the O2 sensor output, only that the signal will reaching the ECU cleanly.
Don't be tempted, by the way, to ground the free end of the coax's sheathing braid. It is grounded up near the ECU, and to cancel noise a sheath like that can only be grounded in one location.
At birth you only know how to suck. Spend the rest your life learning how not to.
climberjohn
climberjohn is offline
PostPosted: Sun Jan 11, 2009 12:38 pm    Post subject: Reply with quote
Hot Rod,
In under 1 hour you got answers from Terry K and Tencent.
What more could ask for on this great forum?
Good luck!
(For what it's worth, I recently had the same problem in my 86 with Digifant. Adjusting the Throttle Positioning Switch (TPS) fixed it for me.)
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
peaceman
peaceman is offline
PostPosted: Sun Jan 11, 2009 1:15 pm    Post subject: Reply with quote
Thank you both very much.
I messed with adjusting the cog wheel on the AFS
swapped out the temperature thermal switch
runs rough and pops a bit now.
The cat was glowing red. Big rich problem. I'll buy the fuel injection book.
So many variables to a running rich problem.
Oh and the idle fluctuation is back. What a drag this engine is.....
If anyone knows of how to obtain a Factory Vanagon repair manual please let me know.
Going to check the O2 sensor now. Thanks Terry and tencentlife.
tencentlife
PostPosted: Sun Jan 11, 2009 2:09 pm    Post subject: Reply with quote
I would point you to Dogpilot's public files where he has the Digifant Protraining Manual you can download, but yours is a Digijet, so only the fuel section is relevant. Nonetheless, the operating principles and a lot of the components are the same, so it might help you understand it better. If you take some time searching here, though, we have collectively written the book on these systems. Bit by bit you can glean a very complete picture of what's going on and ways to check and diagnose almost anything.
Terry Kay
Banned
PostPosted: Sun Jan 11, 2009 2:57 pm    Post subject: Reply with quote
<< so only the fuel section is relevant. Nonetheless, the operating principles and a lot of the components are the same,>>
What?
Name one component that is the same--
the distributor, spark plugs, Or the intake boot?
<< so it might help you understand it better.>>
What is going to happen here is that your going to confuse the poster big time.
Digijet & Digifant are night and day apart--- not even close.
What he's goig to be gleaning is a dime's worth of confusion---
Bit by Bit--Little by Little he'll be doing some real gleaning--like a combine.
Good info--
T.K.
turbo2cv
turbo2cv is offline
PostPosted: Fri Jun 22, 2012 9:28 am    Post subject: Reply with quote
Tencent: the trimming of the coax shield away from the center wire is a great advice. Not found in any book. It worked for me.
Thank you
tencentlife
PostPosted: Fri Jun 22, 2012 11:13 am    Post subject: Reply with quote
Thanks, glad it helped. Bentley does have something on this as a quick check, buried somewhere in the FI chapter (p.24.54 in my copy), it's presented as testing the O2 sensor/lambda response. What they tell you to do is to deliberately ground the O2 signal line with the engine idling warm. If the idle changes to obviously rich within seconds of grounding the line, that is good, it shows the line is normally isolated from ground because the only thing you changed was to ground it. If the idle doesn't change (and presumably it is already running stink-rich), then they point you to the wiring checks table, but what it means is that the line is already grounded, or the ECU is bad.
The Illinois-ing One wrote:
...Digijet & Digifant are night and day apart--- not even close...
This aggro-igno-rant, not even comically redeemed by the trademark cornpone condescension, never deserved the dignity of a response. But since I'm here, I'll merely state that that could only be said by someone with no understanding of either.
Terry Kay
Banned
PostPosted: Fri Jun 22, 2012 8:53 pm    Post subject: Reply with quote
The problem could very well be the O2 sensor, but as soon as the OP mentioned the glowing red converter, in my Aggro- Nomical wisdom, I really believe it is beyond the O2 sensor.
And for the life of me, sure can't figure out why all of the folks all of the time go right for the O2 Sensor first thing, when the switches at the TB mechanically open and close a thousand times a day--every time you touch the throttle they open close, or close & open.
However you want it.
They are like a set of contacts in a points ignition--and usually the first item to wear & fail.
Nobody will even give them a primary adustment first, before playing ring around the rosie, pocket full of posies, removing and replacing insignificant secondary eletrica control item's.
Something is telling the ECU & the injectors to blow more fuel at the cylinder's than they can burn.
The dual switches are a pain at the throttle switches.
set the up first, then you have an engine running base from which to start the other electrcal engine managment tests.
But here's another thought.
If the converter is plugged solid--it'll glow redder than a hot potato--which would cause big time, full time operating problems.
What my corn fed mind is wondering, what happened to the OP and the Van?
Did he get it running OK??
12 of 09 was one hell of a long time ago.
He more than likely got frusrated and bailed.
Been awhile.
Digijet & Digifant are like like apples & marshmallow's--not even close to operating the same.
T.K.
downshifting1984
downshifting1984 is offline
PostPosted: Sat Jun 23, 2018 11:49 am    Post subject: Re: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
Hi everyone! 1st, let me say that this site and its contributors are the brst. as i get better, i’ll contribute more. So, any tips on trimming back the o2 sensor coax canle shielding? i need to trim the cable to put in a new connector, and i eant to avoid the signal shorting to ground.
thanks!!
reevesme
reevesme is offline
PostPosted: Mon Jun 03, 2024 3:43 pm    Post subject: Digijet O2 sensor shield connection Reply with quote
I had a question about the grounding of the coax shield of the O2 sensor.
[/i]
I did not see conducting path to ground (pins 7 and 25 or the FCU cable), so I opened up the plug. I saw that the shield was actually connected to pin6, which is not to ground but to the air flow sensor potentiometer. This is consistent with the digijet wiring diagram copied here. Would you please clarify that this is the best way to connect the shield on the O2 sensor? Thanks!
RawUmber
RawUmber is offline
PostPosted: Mon Jun 03, 2024 4:28 pm    Post subject: Re: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
Digijet ECU is supplied a ground from the cylinder head on its pin 7. Inside the ECU, pin 6 and 7 are bonded/connected together. The ECU uses pin 6 to supply this ground to the AFM and O2 sensor shield.
'Best' in this context is usually to keep things stock/standard. Makes for easier troubleshooting. If it were to be re-engineered, maybe an ADC within the O2 sensor outputting a digital value to an ECU would be better, but that would be beyond the realm of Digijet. The Digijet was engineered for the O2 sensor it uses and its sensitivity and noise mitigations were taken into account in its design.
reevesme
reevesme is offline
PostPosted: Mon Jun 03, 2024 7:08 pm    Post subject: Re: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
Thanks for the clarification. I agree with your closing sentiment and np need to modify since I now understand where the ground comes in. I took a look at your impressive collection of technical images and burned out vanagons. Very impressive.
I am trying to improve my mpg, which is now at 15-16 while driving 65. The power plant is a 2.1L donor engine (MV series) with the 2.1L cooling system and 2.1L exhaust. I have kept the digijet as my likely next move with be to get a mansispeed electronic ignition system. So my question ...
is there any adjustment that I can make AFM a little leaner in the closed loop mode? Right now my air fuel gauge is reading around 14.2 - 14.4 at sea level. When driving in Colorado at 10,000 + feet, the gauge reads 14.6-14.8 and the mpg's increased to 18. Might also help that I was driving up Loveland Pass .. slow speeds up mountain and faster speeds down!
Will continue to hunt for other problems now that you helped me to rule out ground loops in the O2 sensor circuit.
RawUmber
RawUmber is offline
PostPosted: Tue Jun 04, 2024 9:54 am    Post subject: Re: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
Digijeting a 2.1l MV is a bit unique. Overseas, VW did something similar- Digijet w/ a 2.1l DJ engine. In this case, they used a different Digijet ECU (025906021E for auto transmission, 025906021F for manual). I don't know off the top about the difference w/ injection quantity vs North American Digijet 1.9l.
The AFM can be adjusted. There are probably some good threads you can find here regarding that. However, any adjustment will affect both open and closed loop operation. I wonder about the difference in the engine load measurement of a Digifant AFM vs Digijet AFM. A mismatch of AFM and ECU could reveal some enrichment differences if those AFMs don't generate identical output.
It might be interesting to put a meter on your O2 sensor output and see if it's dwelling in the rich zone (<0.4V) rather than oscillating above and below 0.5V (~stoichiometric/lambda) during closed loop, as per typical operation.
If you're serious about moving to a Mansispeed system in the near term, a lot of this will be irrelevant.
reevesme
reevesme is offline
PostPosted: Tue Jun 04, 2024 10:32 am    Post subject: Re: idle fluctuation up/down running RICH 84 Digijet 1.9L Reply with quote
Thanks for the detailed answer. I will check the O2 sensor. Right now I have two O2 sensors: a wideband (for the air/fuel gauge) and the narrow band that feeds the ECU. Also, I kept the entire digijet system: ECU, AFM, and throttlebody. Have added mansispeed injectors. So compatibility between the AFM and ECU should not be an issue, though the "engine under load" will be different between the 1.9L and the MV.
I did adjust the AFM, but ended up winding it so tight to get to a lean condition that it didn't seem right. Will give it another go and also look at the narrowband sensor output.
Mansispeed ECU will have to wait about a year, while I rebuild another MV engine that I purchased. Right now am running a core engine bought from Small Car that I stuffed in to replace a GW stroked engine with a broken crankshaft. Stroker was neither a good engineering strategy nor good purchasing decision. We camp a lot and this gets us out of the driveway.
