1985 Vanagon Subaru 2000 2.2 swap - need help with black box
van go 1985
van go 1985 is offline
PostPosted: Tue Jun 04, 2024 8:08 pm    Post subject: 1985 Vanagon Subaru 2000 2.2 swap - need help with black box Reply with quote
hi group i am doing a vanagon subaru swap need help with the electrical the black box thanks Question Question
4Gears4Tires
4Gears4Tires is offline
PostPosted: Wed Jun 05, 2024 10:17 am    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
Who did you buy the kit from?
van go 1985
PostPosted: Wed Jun 05, 2024 10:54 am    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
mick from busaru
4Gears4Tires
PostPosted: Wed Jun 05, 2024 11:19 am    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
Did you ship them your wiring?
wesitarz
wesitarz is offline
PostPosted: Wed Jun 05, 2024 4:05 pm    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
This might help:
http://subaruvanagon.com/tom/Getting%20Started.htm
space
space is offline
PostPosted: Thu Jun 06, 2024 5:21 am    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
I have a Busaru install
What are you looking for?
Mines a 2.5 JDM
T
82 westy
w:
2.5 JDM Subie
Rear discs
van go 1985
PostPosted: Sat Jun 08, 2024 8:43 am    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
i am looking for information on a 1985 vw vanagon black box what wires do i splice inn to a 1985 thanks
wesitarz
wesitarz is offline
PostPosted: Sat Jun 08, 2024 8:21 pm    Post subject: Re: 1985 vw vangon subaru 2000 2.2 swap need help with black box Reply with quote
Do you have an 85 wiring diagram. If not these can be read:
https://www.ebay.com/itm/185863646739
start (RB?)- goes to the Subaru harness and ECU and starter solenoid
ignition ON (B?)- goes to ignition ON subaru harness (10 amp fuse)
Battery + from hot post 15 amp fuse (connected to alternator)
alt warning light (BW?) connects to VW blue wire
other through T7 round connector
Plus look at previous link provided.
Edit:
https://www.thesamba.com/vw/archives/manuals/1985_...agrams.pdf
van go 1985
PostPosted: Sun Jun 09, 2024 11:48 am    Post subject: Re: 1985 Vanagon Subaru 2000 2.2 swap - need help with black box Reply with quote
hey hey yes i have all that. just wanted to be sure before , i start cutting wires i am ok with mechanical. things just when it comes to electrical i suck thanks for you knowledge and time
