poundman Samba Member
Joined: April 05, 2024 Posts: 405 Location: Sugar Land, Texas
Posted: Thu Jun 13, 2024 10:24 pm Post subject: Re: Brake Booster Issue |
Question. I have issue with my recently purchased 1972 bus that has been setting for over 20 years in storage. Engine not running yet but the brake pedal is hard as a rock and will not budge when I try to press. How can I troubleshoot the issue with no working engine. I am not sure if the problem is with MC or the booster. PO said it needs a new MC but I am not sure if that is the case.
What is the latest opinion on replacement vs restore?
Thanks. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5289 Location: Southern AB
Posted: Fri Jun 14, 2024 5:34 am Post subject: Re: Brake Booster Issue |
poundman wrote: |
Thanks. |
first you need to see what is seized, could be the assembly pedal itself
https://volkswagen.7zap.com/en/usa/type+2/t2/1971-29/7/721-60000/ _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17626 Location: San Diego, California
Posted: Fri Jun 14, 2024 6:54 am Post subject: Re: Brake Booster Issue |
If a visual inspection fails to find a cause I would probably remove the master cylinder. Press on the pedal. See what happens. In my mind, the brake system is going to need a full rebuild anyhow, so bleeding is going to be necessary anyway at the least. I’m thinking that you have rust inside the mc causing your jammed pedal. Water gets into the brake fluid and after a long time would freeze the spool in the mc _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Jun 14, 2024 7:42 am Post subject: Re: Brake Booster Issue |
Thanks, I suspect the MC is the issue but I will remove and test the pedal. I think I will have them both rebuilt. I have sent email to Karps. Any other suggestion for rebuild. I am in Houston area but don't mind shipping. |
Posted: Fri Jun 14, 2024 7:52 am Post subject: Re: Brake Booster Issue |
In all my years I’ve never seen a frozen brake pedal mechanism and I think other than a visual inspection and a quick squirt with some spray lubricant, you’d be wasting your time disassembling your pedal.
If you want, you could remove the long rod from the booster to the pedal and then try your brake but it’s even easier than that. One end of that rod has a fork and a pin. Remove the cotter key, remove the pin, then pull down on the rod and it will disconnect to your pedal. At that point you’ve separated the system in half.
The rod is 25A in the illustration _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Jun 15, 2024 8:06 pm Post subject: Re: Brake Booster Issue |
I removed my MC and disconnected the pedal linkage. My MC and booster are definitely corroded. The booster was full of brake fluid. I have another question. Where does the vacuum line from the back side of the booster attach? And where does the air hose from the front side attach? thanks |
Posted: Sat Jun 15, 2024 8:19 pm Post subject: Re: Brake Booster Issue |
The front side is just a vent to atmosphere. The rear goes to your engine. What year bus do you have? You might add that to your signature line along with other info maybe, like location _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Jun 15, 2024 8:56 pm Post subject: Re: Brake Booster Issue |
aeromech wrote: |
The front side is just a vent to atmosphere. The rear goes to your engine. What year bus do you have? You might add that to your signature line along with other info maybe, like location |
1972 bus
Posted: Sat Jun 15, 2024 9:01 pm Post subject: Re: Brake Booster Issue |
I think you’re missing my point. Go back to your preferences and fill out your location and year of your bus. Then, when you post people will know that info and can better help you. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun Jun 16, 2024 10:58 am Post subject: Re: Brake Booster Issue |
aeromech wrote: |
I think you’re missing my point. Go back to your preferences and fill out your location and year of your bus. Then, when you post people will know that info and can better help you. |
I have now fixed _________________ -----------------------------------------
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2772 Location: Plattsburgh, New York
Posted: Wed May 14, 2025 7:08 am Post subject: Re: Brake Booster Issue |
Just adding my own experience to this thread. Brakes were feeling a bit weak especially when coming to a complete stop, along with an increase in idle speed when brakes were applied. Went through all the vacuum hoses and connections to rule out a simple leak. But fairly clear it was the booster.
Brazil booster was the best I could find at the time. I was aware of the fitment issues from this thread. The studs are in a different place compared to the original. It’s not just a matter of drilling new holes. The original bracket is too narrow. I bought a strip of 1/2x1/8 steel from the hardware store because I was too lazy to cut metal and welded them on to the original bracket. Made a pizza box template with old/new holes and drilled new holes. Took me more time than expected but it’s a solid repair.
I had a used booster I got from the classifieds but it was too mauled for a rebuild.
Sometimes you get lucky with the classifieds. Sometimes you get burned. Was advertised as booster from working bus. Word of advice when parting out buses: Pull parts before it goes to the crusher, not after. And don’t use a splitting maul to remove parts.
My original booster looks like a good candidate for a refurb. It’s all there, just leaky.
The Brazilian booster works great. Stops on a dime with no pedal effort. This is the way servo assisted bus brakes should feel. If you have been driving for a long time with a leaky booster like I have, your first stop at speed might feel like you’re gonna get thrown through the windshield. |
