perello Samba Member
Joined: April 15, 2005 Posts: 891 Location: where social security comes for free
Posted: Mon Jun 17, 2024 7:18 am Post subject: 1200 in need of some TLC |
this guy now is 21
and will inherit the car behind him as his first car...so I though is time to do some necessary repairs...I will be dropping randomly the work I do around it on here.... _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Mon Jun 17, 2024 7:58 am Post subject: Re: 1200 in need of some TLC |
perello wrote: |
this guy now is 21
and will inherit the car behind him as his first car...so I though is time to do some necessary repairs... |
On the car, or to the kid?
 _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Mon Jun 17, 2024 8:00 am Post subject: Re: 1200 in need of some TLC |
KTPhil wrote: |
kid got TLC overdose already  _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Mon Jun 17, 2024 5:08 pm Post subject: Re: 1200 in need of some TLC |
I'm trying to figure out the free social security and first car at 21. _________________ www.vwnos.com [email protected]
Posted: Tue Jun 18, 2024 12:57 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
I'm trying to figure out the free social security and first car at 21. |
haha hint: look at the international section
anyway first hing was to remove the old rusted half floor pans
and make obvious the different rusted spots
1974 German Thing
1978 Bug 1200
Posted: Wed Jun 19, 2024 12:47 am Post subject: Re: 1200 in need of some TLC |
so, after cutting out the rust, slowly welding back heater channels
and wheel wells
[/url] _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Thu Jun 20, 2024 1:04 am Post subject: Re: 1200 in need of some TLC |
some more welding, the patch parts available in the market are not that great....also I dont fully understand the inner of this section...
1974 German Thing
1978 Bug 1200
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 492 Location: GALWAY,IRELAND
Posted: Fri Jun 21, 2024 9:48 am Post subject: Re: 1200 in need of some TLC |
Great, come and do mine, I've been putting it off for ten years as I drive my 72 standard daily! |
Posted: Tue Jun 25, 2024 1:50 am Post subject: Re: 1200 in need of some TLC |
jarmchairpilot wrote: |
hahaah on my way!
i jumped to check the front, removed the spindles, lower ball joint dust cover was ruined so time to replace
while there checked if spindles were straight
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Tue Jun 25, 2024 9:02 am Post subject: Re: 1200 in need of some TLC |
What is going on in that picture? Looks like you have stuff held together with a car jack. _________________ www.vwnos.com [email protected]
Posted: Tue Jun 25, 2024 10:19 am Post subject: Re: 1200 in need of some TLC |
Quote: |
What is going on in that picture? Looks like you have stuff held together with a car jack. |
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Tue Jun 25, 2024 10:22 am Post subject: Re: 1200 in need of some TLC |
You use that before you replace the ball joint or after? _________________ www.vwnos.com [email protected]
Posted: Tue Jun 25, 2024 10:28 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
You use that before you replace the ball joint or after? |
to get the spindle off and then back in _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Tue Jun 25, 2024 11:10 am Post subject: Re: 1200 in need of some TLC |
perello wrote: |
heimlich wrote: |
to get the spindle off and then back in |
OK. I understand now. I always replaced the ball joint with everything attached to the car. It looks like you are going through everything to make it tip top shape. _________________ www.vwnos.com [email protected]
Posted: Wed Jun 26, 2024 12:51 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
OK. I understand now. I always replaced the ball joint with everything attached to the car. It looks like you are going through everything to make it tip top shape. |
I was talking about replacing the rubber dust cover
to replace the ball joint I need to remove the torsion arm and use a 20 ton hidraulic press...how you do that attached to the car?
some candy
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Wed Jun 26, 2024 6:31 am Post subject: Re: 1200 in need of some TLC |
perello wrote: |
I have a ball joint tool. There are cups that fit over the ball joint.
Here's a newly made tool. I have one specific to the VW one now but you can get the general idea from it.
Posted: Tue Jul 23, 2024 3:26 am Post subject: Re: 1200 in need of some TLC |
some progress, I did remove the transaxle to clean and replace boots, i like the seamless type
Taking out axle bearings
also fitted firewall tarboard, guess its the jbugs thick version...I did all possible mistakes
1974 German Thing
1978 Bug 1200 |
Posted: Tue Sep 03, 2024 4:02 am Post subject: Re: 1200 in need of some TLC |
the work is going on, I am replacing the front beam... too rusty, and took the opportunity to
check the steering box
The roller was pitted so I replaced with a new one
and cleaned all parts
thanks to the incredible Tom thread on type 3 section, the resto end up looking good
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Tue Sep 03, 2024 8:14 am Post subject: Re: 1200 in need of some TLC |
That roller is definitely pitted. Where'd you get the replacement? _________________ www.vwnos.com [email protected]
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4729 Location: Arizona Highways
Posted: Thu Sep 05, 2024 8:28 pm Post subject: Re: 1200 in need of some TLC |
looks like you got the right tools!
proceed  _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
