What did you do to your Oval today?
Page: Previous  1, 2, 3 ... , 57, 58, 59  Next
5500 is offline
PostPosted: Wed May 11, 2022 9:29 am    Post subject: Re: What did you do to your Oval today? Reply with quote
donny273 wrote:
Putting together a 36 hp wolfsberg west dual port motor with counterwighted crank and a few other goodies. Noticed I have two types of shroud fans lying about. One has more vanes on it than the other. Was one for a buss and the other a type1. Which should I use? Looking for reliability not crazy high performance. Thanks for your help.
Assuming both have holes in the backing plate (how the early generators were cooled).. The early fans had fewer blades. Later ones cool a bit better at the expense of a couple of horsepower. I went with the later ( I think 24 blade vs. 16).
Da TOW'D
Da TOW'D is offline
PostPosted: Tue Jul 19, 2022 3:33 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
I replaced the 30 year old cracked tires with new 185 60 R 15 from CIP 1 and being wider than the original 165 15 I added longer front bolts that keep the tires from rubbing on the front suspension. But the new bolt was too long now I have less steering angle. So back in the shop and grind a few threads off.
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'69 Karmann Ghia Convertible (new project)
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
aa390392
aa390392 is offline
PostPosted: Mon Aug 29, 2022 8:32 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Polished the Inca red Kab,
Polished out prairie beige
Picture tomorrow
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
aa390392
aa390392 is offline
PostPosted: Sat Sep 03, 2022 8:04 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
And I sold it today
55 ragtop
56 delux sedan
56 Kabriolet
2Dokas
2Dokas is offline
PostPosted: Sun Sep 04, 2022 7:48 am    Post subject: Re: What did you do to your Oval today? Reply with quote
aa390392 wrote:
And I sold it today
Looks awesome. Happy or Sad?
87 Doka 2WD Ej22,
56 Convertible
aa390392
aa390392 is offline
PostPosted: Mon Sep 05, 2022 10:22 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Am kind of remorseful, I put a lot of love/work into it..and enjoyed it immensely
The color, Inca red was most unusual and not often seen..she was fun to share with viewers..hopefully the new owner will also enjoy, but I have my doubts.
55 ragtop
56 delux sedan
56 Kabriolet
tehillah1
tehillah1 is offline
PostPosted: Tue Sep 06, 2022 2:47 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Picture tomorrow
What a great color. Was that exclusive to convertibles?
Ya gotta be sad to see that one go. Do you have your sights on the next one?
Da TOW'D
Da TOW'D is offline
PostPosted: Sat Nov 05, 2022 9:45 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Over the years I've hired a high school kid to lend a hand in my shop and maybe they would learn something.
In the 80's one of my helpers always showed on time and was enthusiastic.
We found a '60 bug and put it together for him. His family moved to Halifax and he drove the bug across Canada and used it for a few years.
His father was a doctor and his mom was a nurse so he and his 2 brothers became doctors.
Flash forward to today he stopped in to say hi and wanted to see my VW fleet.
First I showed him my 1957 black beetle and he asked if it still runs.
I told him of the long story of how a friend traded it to me for doing a brake job on their Toyota. How another high school guy and I stripped it down and rebuilt it.
I checked the oil and pushed on the vee belt .
It is just a little above freezing here so I told him to push the manual choke on the carburetor because the choke cable is broken.
Then noticed that the flex fuel hose was split and just sitting on the fuel pump with the outlet aimed right at the distributor.
I replaced the hose and we started it right up.
I'm sure glad I was showing off and not just got in and tried to drive off.
BTW I do have a on board fire extinguisher
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Sun Nov 06, 2022 8:50 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Gratifying I'm sure to know you played a part in him becoming a good quality human.
It really does take a village!
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
markendee
markendee is offline
PostPosted: Thu Jul 13, 2023 3:38 am    Post subject: Re: What did you do to your Oval today? Reply with quote
I registered the 54 in March but couldn't decide on a way to attach the plates that made me happy.
I finally fitted my number plates today.
I Really did not want to drill holes in front bumper and have the plate hanging down and getting all bent up.
I looked at frames at accessory shops and online but couldn't find what I wanted.
We replaced the front bumper (?) in my daughter's Toyota on Monday and I liked the look of the number plate support frame.
Bit of recycling and jobs done.
Also like that the rear plate colour matches the Hearts (sort of)
Member # 145244
WadeLinger
WadeLinger is offline
PostPosted: Mon Jan 08, 2024 1:10 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Wired up the headlights.
WadeLinger
PostPosted: Mon Jan 29, 2024 9:29 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Hooked up the wires behind the dash.
MJMarkham
MJMarkham is offline
PostPosted: Wed Feb 21, 2024 6:33 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
After years of the cheap TMI vinyl interior kit, I have reworked the interior on the '57... new headliner, carpet, seat covers and door panels. Also upgraded the steering wheel...
M J Markham
57 Ragtop Oval, 58 Lowlight Coupe
WANTED: Original 58 Ghia Dash Knob
56Cabrio
56Cabrio is offline
PostPosted: Wed Jun 12, 2024 3:51 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Got the vert running after years of being parked.. for 13 years Embarassed
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
slayer61
slayer61 is offline
PostPosted: Thu Jun 13, 2024 6:46 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Applause Thumbs Up
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
Strawman914 Premium Member
Strawman914 is offline
PostPosted: Fri Jun 21, 2024 9:34 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Long-time lurker, but it is finally time that I shared my VW project. Long story is that when I was born, my parents were broke college students and had to sell their '56 Euro (for $280) to pay my birthing bills in New Haven, CT in 1966. My first car was a 1964 Beetle sunroof that I bought in 1982 while a sophomore at Sacred Heart High School in San Francisco. I used my paper route money to hotrod it in my mother's San Francisco house with a tiny garage. Mods included: 1385cc pistons/barrels, Engle 110 cam, header, dual Kadrons, lowered with a lowering front sway bar (remember those?), and one-piece windows. It was stolen from in front of my house about six months into the project, and I replaced it with a '66 11-window Bus. I've also owned one more Beetle ('63), '66 Fastback, '69 Squareback, '67 rusted-out 21-window Bus that I bought for its engine (and sent to the crusher in 1983!), Manx-style buggy, '75 Bus during college, '81 diesel Westy (GTi Golf-swapped in 1999), '86 Syncro Westy (Suby-swapped in 2001), and most recently a '93 Westy Eurovan (TDI & manual swapped). But it was always my dream to build a "legacy" Euro Beetle.
I finally found a '56 Euro Beetle in a Samba ad about two years ago. My wife and I dragged it out of the guy's front yard in Oakland, CA using a come-along. It is a complete basket-case: the MY '58 36hp engine is locked up; the doors were cut for one-piece windows; the trim holes are welded-up (poorly); it is missing the semaphores & W-lid; the seats are hashed; it has the wrong aprons (riveted on!), fenders and hood; it came with no lights/lenses; it has no interior panels; etc. But it is surprisingly straight and there's not too much rust. The cowl is damaged from the hinges; obviously, the hood flew open at one point...
Because I'm a Porsche 914 guy and I recently bought out a guy's estate that included two 914s, five engines, six transaxles and four trailer loads of "stash," I am in the midst of building an upright Type 4 engine and have recently completed a 901 5-speed conversion into a '74 Beetle IRS chassis. Regarding that pan, I narrowed the front beam 2" and installed CB Performance disc brakes on raised spindles, welded-in adjusters, new balljoints, and I installed narrowed tie-rods and sway bar. I also narrowed the rear trailing arms 1" each side so that the wheels will tuck under correctly beneath the narrower early body. I welded-in early pans so I can install early-style seats; I have a set of 1980s era Corbeaus that I might use, although I might opt for 914 seats since I've got a couple good sets.
This is a medium-term project, since I've got a couple other projects that I'm trying to finish up (M54B30 swap into an '85 BMW 524td chassis, Suby EG33 swap into 1975 Porsche 914 that I plan to flip, and I'm helping a friend swap an M54B30 into a 2000 BMW 323 wagon) before going whole-hog into this Beetle. I also autocross a built EJ257-swapped '73 914 (302whp, LSD in modified Suby transaxle, metal flares, 911 front suspension, big front sway bar, etc.), and my wife autocrosses an '01 Corvette or her mostly stock '75 914 -- and those cars always need attention.
As shown below, last night I finished welding up a rotisserie that will make it easier for me to address rust -- mostly in the bottom of the heater channels. My luggage tray has some rust-through, too.
obus Premium Member
obus is offline
PostPosted: Sat May 03, 2025 4:33 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Got it legally registered, insured and plated here in NJ and took it on its 1st ride
redbug64
redbug64 is offline
PostPosted: Fri Jun 13, 2025 12:10 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
After owning my 1954 For close to 20 years, having saved it from laying dormant in a barn for probably 20 prior to that, I was able to drive it for the first time today. Be it still in need of many things, it moved under its own power!
Jason Arms
Fairfax, Vermont
1954 Standard Beetle
1965 Firetruck Red Double Cab
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Random Toyota daily drivers because winter.
obus Premium Member
obus is offline
PostPosted: Sun Jun 29, 2025 6:24 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
My Wife passed away last Sunday and my buddy dragged me out in the beetle for bbq and the ghia for a ride later.
Da TOW'D
Da TOW'D is offline
PostPosted: Thu Jul 10, 2025 9:07 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
I have not driven my '57 beetle at all for the last 3 years. I've started it and let it run for a while just to keep things lubed up a few times.
Yesterday I figured it time to take a cruise, I put it in first had the clutch on the floor yet when I twisted the key we started moving ahead and then the engine started. I still had clutch pedal on the floor. I shut the engine off and tried again same thing-- the clutch was seized and not disengaging.
So today i pulled the old fresh air 40hp. out. After I removed the pressure plate bolts I found that the disk was stuck against the pressure plate and flywheel with rust, i had to tap around the pressure plate to knock it off.
The flywheel, pressure plate and disk got cleaned up with a grinder with a flex pad. I removed the gland bolt and cleaned it with gas and repacked it with a little grease. no leaks on the front seal so I left it. All the valves checked good so tomorrow it is going back together.
The bug was sitting out side all that time so it is time to clean the addition next to my shop and give it a spot out of the rain coast weather.
Part of the cycle Fix it, Enjoy it, Neglect it , Fix it again and so on
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
Page 58 of 59
