Trev60 Samba Member
Posted: Sat Jun 22, 2024 3:38 am Post subject: Front brakes, discs or drums? |
I'm a long way off this point yet, but as I'm on the forum I thought I'd ask.
Is there any real advantage in terms of braking performance to converting to disc brakes on the front. Understandably there's the regular adjustment needed but that couldn't really be easier could it? But a good drum set-up properly maintained should be good I think (and less expensive I reckon). I forgot to mention, it's a 71 1302
What do you think?? _________________ Nothing is impossible, it's only rust!!!!!
Past projects 1972 Citroen Dyane, 1971 Citroen D-Super. 1971 T120 Bonneville, 1960's Triumph Tiger Cub |
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 492 Location: GALWAY,IRELAND
Posted: Sat Jun 22, 2024 4:12 am Post subject: Re: Front brakes, discs or drums? |
I changed my 1200 standard from drum to disks a few years ago
It is better braking now overall but the main advantage is in wet weather,
then it is way better as drums are not good once water gets in.
I drive everyday in Ireland where it rains half the year so for me it's worth it. |
passionre Samba Member
Joined: November 28, 2021 Posts: 103 Location: Oklahoma
Posted: Sat Jun 22, 2024 4:46 am Post subject: Re: Front brakes, discs or drums? |
Braking power is slightly better with discs after a several hundred mile break in period from what I've noticed. The big advantage is not having to adjust the brakes as often. |
goober Samba Member
Posted: Sat Jun 22, 2024 7:43 am Post subject: Re: Front brakes, discs or drums? |
I've never had disc's on my stock Bugs. But I keep my brakes in good shape. I can lock up the wheels when needed. True, deep water does bother drums more. But a little driving with some peddle pressure dries them pretty quick.
I've always found adjusting the rear shoes more tedious than the front. I've nothing against disc brakes but for 50+ years I've never felt a real need for them.
But then again, I've always driven conservatively in my Bugs. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16584 Location: North Florida, USA
Posted: Sat Jun 22, 2024 10:57 am Post subject: Re: Front brakes, discs or drums? |
In short, disc brakes are functionally better than drums. That function is to safely stop your car in the shortest distance. Any other concerns (adjustment frequency or cost) are not part of the “function”.
Since disc brakes are self adjusting the point on adjustments for drum brakes is only a deficit as forgetting to adjust your brake shoes can compromises your brake function. The point on water affecting drums more than disc is another point against the braking function of drums. In that short period where you are “drying out” your brake shoes your brakes are not fully functioning. That period for discs is basically one revolution of the disc and you don’t even need to intentionally do anything as the pads sitting a hair’s width off the disc will wipe the water off the disc as it rotates. Again, better function.
The only argument I could understand for keeping front drum brakes is if you wanted to keep your car 100% stock (Note: VW DID use disc brakes on non-US Beetles so disc brakes are not necessarily an aftermarket-only option). But even then, the changes to front brakes can be undone if you keep your OE parts. So I only see it as an argument for a trailered show car that is not driven on the road.
Installing a front disc brake kit on my Beetle was probably the best investment I made. _________________ AshMan40
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1692 Location: Central Pennsylvania
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Sat Jun 22, 2024 11:50 am Post subject: Re: Front brakes, discs or drums? |
I switched to front disc brakes and noticed an immediate improvement. And this was with an Empi front disc conversion (which, surprisingly, considering Empi's reputation at the time, amazed me).
You can buy good aftermarket front disc conversions for the price you'd pay for a complete front drum brake r & r, using good Zimmerman drums, ATE wheel cylinders, etc.
As long as I owned that '74 SB, I never had a bit of trouble with the front brakes.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Trev60 Samba Member
Posted: Sat Jun 22, 2024 11:57 am Post subject: Re: Front brakes, discs or drums? |
Ok cool, thanks for the advise, general consensus is go for discs, you're right, I'll have to replace drums etc. anyhoo.  _________________ Nothing is impossible, it's only rust!!!!!
lner JP Samba Member
Posted: Sat Jun 22, 2024 12:23 pm Post subject: Re: Front brakes, discs or drums? |
My experiance and understanding is that drum brakes are just as good as disks when cold, however they suffer from fade much more than disks when hot, so if your journey dosent involve much braking then drums will be fine, but if you have to do a lot of braking round town or going down hill then disks are a noticeable improvement.
JP |
unclewede Samba Member
Posted: Tue Jun 25, 2024 2:27 pm Post subject: Re: Front brakes, discs or drums? |
When the 77 rolled back off the trailer, it had ZERO brakes (other than Flintstones) Swapped to front disc as one of the first things we did while the engine was out being rebuilt. Then did the shocks, then got into cosmetics.
Because I needed to replace the master cylinder to support the new disc, I figure there is a more even breaking power applied to multiple surfaces in the rotors vs drum.
I also dropped 1" during the disc conversion, thing is on rails around a corner compared to any other vehicles I drive. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3170 Location: Sydney Australia
Posted: Tue Jun 25, 2024 3:37 pm Post subject: Re: Front brakes, discs or drums? |
Well, my 68 RHD came with discs as standard from the factory. My Dad's previous car was a drum braked 64 and he (being a professional driver) commented on how much better the STANDARD disc brakes were compared to the previous drum brake model.
As has been noted above, discs are less maintenance, better after getting wet and most importantly for some, are prone to less brake fade when used hard e.g. in steep downhill inclines.
I could never understand why the US models were not fitted with disc brakes as standard as they were such an improvement in safety. I mean the US mandated padded dashes and high back seats that the rest of the world didn't necessarily get in 1968.
The cynic in me might suggest that being the biggest market for VW in the world that there was money to be made in higher maintenance and spare parts costs for drum brake maintenance.
If you think of the complexity of a drum brake mechanism, star adjusters, return springs, crossover bar, backing plate pins and the associated hardware compared to a unitary brake caliper not to mention the time taken to change a set of brake shoes after getting off a stubborn drum and ensuring the correct parts go back in their correct location then maybe there is some truth in that. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4495 Location: viroqua wi.
Posted: Tue Jun 25, 2024 4:49 pm Post subject: Re: Front brakes, discs or drums? |
Why would you think your cynical that VW or any other company was out to make money. |
goober Samba Member
Posted: Tue Jun 25, 2024 5:27 pm Post subject: Re: Front brakes, discs or drums? |
Why aren't we applying the often sighted VW "Engineering Test"? That is, if VW engineers did it, it couldn't possibly be wrong.
And my Bug came directly from the factory with drum brakes.  |
74 Thing Samba Member
Posted: Tue Jun 25, 2024 6:24 pm Post subject: Re: Front brakes, discs or drums? |
The advantages are better braking in wet weather, they are self adjusting, and better braking when heated up where drum braking will fade once hot.
All that said I still run drum brakes all around for 30+ years. They do take regular maintenance, but if you got in my car and drove it you would think, damn this car stops well.
One advantage I can think of is that drums are usually a lot lighter than the disc brake options out there (research unsprung weight and pay attention to your wheel and tire weight as well).
That said regular adjustments are required (may be every other week if you drive regularly like I do; shoe liner material makes a difference; using steel braided brake hoses help with the pedal firmness; arcing the shoes to the drum so you get use of the full stopping surface is recommended; lubing the friction contact areas on the backing plate is recommended; changing wheel cylinder sizes can help with smaller tires on the front and larger on the rear; it is important that both sides of each wheel cylinder moves freely and is lubed appropriately and that there is no debris under the protective boots; German drums are preferred (CSP or Wolfburg West); changing brake fluid every few years is also recommended.
With all of that one of these days I am going to purchase a set of CB Performance front wide 5 disc brakes to see how there are. They are much lighter than the heavy EMPI and AC Industries kits. |
goober Samba Member
Posted: Tue Jun 25, 2024 9:29 pm Post subject: Re: Front brakes, discs or drums? |
74 Thing wrote: |
All that said I still run drum brakes all around for 30+ years. They do take regular maintenance, but if you got in my car and drove it you would think, damn this car stops well. |
Mine too.
Another 30+ years?
No problem.  |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17589 Location: Left coast, Canada
Posted: Tue Jun 25, 2024 11:33 pm Post subject: Re: Front brakes, discs or drums? |
goober wrote: |
I can lock up the wheels when needed. |
This is actually very bad. That's why modern cars have ABS, to prevent that.
Disc brakes have less tendency to locking up. IOW, it takes a stronger push on the pedal to lock them up. Shorter braking distances result.
Not all disc brakes are immune to the wet. When I first put discs on my car, after a long run on the freeway in the wet, the first push on the pedal gave no braking while the pads hydroplaned on the rotors. It took a second or two to clean them off. Installing the factory shields cured the problem completely. _________________
slayer61 Samba Member
Posted: Wed Jun 26, 2024 6:40 am Post subject: Re: Front brakes, discs or drums? |
To this old knuckle dragger... It's a "no-brainer".
I have disc brakes front and rear. Better performance and less complicated and less moving parts. Easy Peasey!
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger |
doug bugg Samba Member
Joined: March 08, 2003 Posts: 369 Location: Minneapolis
Posted: Wed Jun 26, 2024 6:52 am Post subject: Re: Front brakes, discs or drums? |
slayer61 wrote: |
I have disc brakes front and rear. Better performance and less complicated and less moving parts. Easy Peasey!  |
100% agree. To me it's like the difference between bias ply and radial. Drums can be a real pain-- I did a disc conversion couple years ago and have never regretted it. _________________ "Knowledge is Good" - Faber College |
PatJr Samba Member
Posted: Wed Jun 26, 2024 7:26 am Post subject: Re: Front brakes, discs or drums? |
I hatted the drum brakes on the front wheels.
The disc brakes have their own issues but drums are just a nightmare, for me anyway. _________________ #############################################
1970 Transporter a orange one
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Wed Jun 26, 2024 8:41 am Post subject: Re: Front brakes, discs or drums? |
I switched to front discs on my '75. My issue was brake fade running around the hilly area I live in... and just the general not having to adjust the fronts is fantastic |
