US Wheel 15x7 and 15x8
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
NJ John
NJ John is offline
PostPosted: Sun May 19, 2024 11:44 am    Post subject: US Wheel 15x7 and 15x8 Reply with quote
https://www.uswheel.com/wheel/7702/us%2Dwheel%2Dvw%2Doem%2Dbeetleghia%2Dseries%2D130/?finishID=1
Chrome stock style 4x130 wheels. 15x7 with 5.5 back space and 15x8 with 6” back space. One, if not both may fit under the back of a bug without much trouble. Finally some realistic VW back spacing.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
motomwo
motomwo is offline
PostPosted: Thu May 23, 2024 8:15 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Thank you for posting those wheels! They have them in wide five smoothies too!
https://www.uswheel.com/wheel/16266/us%2Dwheel%2Dvw%2Dsmoothie%2Dseries%2D510/?finishID=2345
Marty
1961 Bug, 2276 cb wedge ports 44x37 11.1 comp fk10 1.5 rockers 48idf's 1 3/4" header Rancho pro street trans SAW axles Airkewld 4# narrowed beam, Koni shocks, Airkewld dis brake all around. 5.5/4.5 BRMs
1966 Bug, 2127, panchito heads, fk8, 1.3 rockers, dual 44idfs, 1 5/8 merge header, Rancho pro strt flyer, empi axles, Airkewld's 4" beam and discs all around and adjustable shocks. 4.5 & 5.5 BRMs
Raceace24
Raceace24 is offline
PostPosted: Tue Jul 09, 2024 3:07 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I have a set of 15x8s coming for my 70 Std.
I’ve always wanted bigger tire on the rear of my Bug,,
Now I’m wondering which tire size to go with.
They’re going on the rear of the Bug, so I’m wondering if a 245/60-15 or a 255/60 -15 would be better.
There’s less than a half inch difference in tire height, but I read in some places that 245 is the max for an 8” wheel… Rolling Eyes
~ No matter where you go......there you are ~
Michael E ~ Raceace24
NJ John
NJ John is offline
PostPosted: Tue Jul 09, 2024 4:33 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I would think maybe a 225/60 or 235/60, max. But, I can wait to see how they fit. Do you have stock fenders? And did you order them directly from US wheel?
Bruce
Bruce is offline
PostPosted: Tue Jul 09, 2024 11:21 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Raceace24 wrote:
...I’m wondering if a 245/60-15 or a 255/60 -15 would be better.
Not a chance. Not without a wider fender.
Years ago, I fitted 225/50/15s on an 8" wheel. I had to replace the forward bolt holding the TA to the spring plate with a flat head bolt. Then on the outside, I had to stretch the fender arch. This gave me about 1/8" clearance in both places.
Even though I had a tall geared trans to deal with the short tires, overall gearing was a bit too low for my liking. I looked and couldn't find a 225/55/15. Eventually I went with a 215/60.
Raceace24
PostPosted: Thu Jul 18, 2024 11:08 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Thanks for your input.
I called US Wheel and changed my order to a 7” wide wheel instead.
Probably going to go with a 215/60 tire.. Cool
NJ John
NJ John is offline
PostPosted: Thu Jul 18, 2024 12:25 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Seems more reasonable. I think those 7’s will fit stock fenders. Fingers crossed.
2type2
2type2 is offline
PostPosted: Thu Jul 25, 2024 7:32 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Running the 5x15 front, w /195/65-15 and the 7×15 rear with 235/60-15. These are really nice wheels and so far (5+yrs.) chrome still good. I have 3" wider fenders so I can't speak to stock clearance, but can certainly recommend these wheels.
"A life of peace and happiness depends on your own gratefulness"
NJ John
NJ John is offline
PostPosted: Thu Jul 25, 2024 8:09 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Pics please.
2type2
2type2 is offline
PostPosted: Fri Jul 26, 2024 8:37 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Only 71-
NJ John
NJ John is offline
PostPosted: Fri Jul 26, 2024 11:22 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Cool, thanks.
Raceace24
PostPosted: Tue Jul 30, 2024 4:33 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I’m running stock fenders and my 5.5” wheels have a lot of room.
Got the wheels recently and found two issues: 1) two hammer marks on the outer front edge of the wheel. They are sending me a replacement as we speak. 2) the center of the wheel (which would be under the hubcap in most cases) is a rough, non-polished chrome finish and I didn’t run hubcaps on the 5.5s that are in the car now… Evil or Very Mad
Guess I’m either going to have to live with the finish difference or put a set of black satin moons on them.. Rolling Eyes
NJ John
NJ John is offline
PostPosted: Tue Jul 30, 2024 8:38 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
The center doesn’t look that bad. I don’t run hub caps either.
Bruce
Bruce is offline
PostPosted: Wed Jul 31, 2024 1:11 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Paint it black?
What do they weigh?
Raceace24
PostPosted: Sat Aug 10, 2024 3:47 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I don’t know what they weight but frankly, they aren’t they much heavier than the 5.5s I’ve had in the car prior.
I got the 215/60-15s mounted and put them on my car.
They fit exactly the way I wished they would - snug up to the edge of the wheel well, but not rubbing !
They are perfect ! 👍🏼
NJ John
NJ John is offline
PostPosted: Sat Aug 10, 2024 10:09 pm    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
Looks really good. That offset should be on all VW wheels. I just may copy the rim and tire size.
Raceace24
PostPosted: Sun Aug 11, 2024 6:04 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I agree. The tires are pretty wide and most of it is inside the wheel well.
The look from the rear is perfect and I’m pretty sure this will increase my rear grip dramatically.
No clearance issues either - not too close to the spring arm and my rear disc brake setup has lots of room!
They honestly look like they were alway meant to be there!
NJ John
NJ John is offline
PostPosted: Thu Feb 13, 2025 8:17 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I see US Wheel isn’t listing the 7” and 8” stock chromies. Wonder if that’s temporary.
Raceace24
PostPosted: Sat Feb 15, 2025 10:19 am    Post subject: Re: US Wheel 15x7 and 15x8 Reply with quote
I’d call them to see. They were pretty responsive when I was dealing with them..
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
