GL 4 or GL 5 - "Official Gear Lube Topic"
Page: Previous  1, 2, 3 ... 68, 69, 70, 71  Next
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Mon May 13, 2024 8:14 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I only had one finger smear of metal smug on the mag drain plug after 49'800 miles of off road and street driving. I would say the Valvoline did a damn good job. If your trans doesn't shift right its wore out, rebuilt wrong, bad shift bushing/coupler, not adjusted/shimmed right on the tunnel or adjust your clutch cable.
Wildthings
Wildthings is offline
PostPosted: Mon May 13, 2024 11:41 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I had a fresh rebuild that shifted just fine with a fill of GL-4 and after a break in period I did a drain and refill using the oil Gears is recommending, the shifting instantly went to crap so it got drained after only a few dozen miles, but wouldn't shift well again when refilled with GL-4, a route I had sadly been down before. I tried running Swepco 201, a 5W40 oil, then a Valvoline synthetic ATF, and finally a tractor hydraulic oil to get an acceptable shift. Its a bit noisier with the hydraulic oil in the box, but at least its not a PITA going through the gears. I forced in an extra quart of oil when I went to the hydraulic oil and suspect I will get a decent enough life out of the box that way.
Cusser
Cusser is offline
PostPosted: Tue May 14, 2024 7:02 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I just changed the gear oil in my 1971 VW, my 1988 Mazda truck, my 1998 Frontier, and my 2004 Frontier (all 4-cylinder, manual transmissions). I used Ultra1Plus GL-4 gear oil purchased through Amazon. Previously in my Mazda truck I used Sta-Lube GL-4 purchased at NAPA, but the Ultra1Plus is less expensive.
I also did the rear differential gear oil on those 3 trucks.
When I installed my rebuilt MoFoCo transmission into my 1970 VW back in 2018, I added the gear oil, but did not record which brand.
Wildthings
PostPosted: Thu May 16, 2024 3:28 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I would like to see how both the Sta-lube and the Ultra1plus did in standard wear test.
'64cal lookdub
1200 Deluxe
'64cal lookdub is offline
PostPosted: Sun Jul 14, 2024 8:50 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I recently filled one of my cars with cheapo $20 Supertech 80w90 GL5. I didn’t notice a shifting difference from the Sta Lube GL4. $85 a gallon for Sta Lube now is ridiculous.
scottyrocks
scottyrocks is offline
PostPosted: Mon Jul 15, 2024 6:39 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
The controversy seems to be the effects over time using the 'wrong' lube.
– D. Tartt, 'The Goldfinch'
'64cal lookdub
1200 Deluxe
PostPosted: Mon Jul 15, 2024 7:32 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Yea but a few have claimed their cars “instantly” shifted bad/worse with GL5.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jul 15, 2024 7:48 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Please list their names or quote their posts.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
oprn
oprn is offline
PostPosted: Mon Jul 15, 2024 8:07 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
After finding out that Ford used ATF in the Escort manual gear box I swapped the gear lube out in my Rabbit for ATF. I did it in the winter and the result was instantaneous. It shifted just like summer! The second thing was that the engine no longer had a tendency to stall on cold start up when letting the clutch out for the first time in the morning.
Initially I was going to change back to regular gear oil for summer but I never did. I beat on that transaxle for the next 6 years with 15+ psi of boost and as far as I know there was no issues. The transaxle has not been out yet for any reason.
I am not sure if ATF would work with our Hypoid final drive gears in air cooled VWs. I have not tried it.
Mr. 010
Glenn is offline
PostPosted: Mon Jul 15, 2024 8:18 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
My 84 Accord used ATF in the manual gearbox.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
'64cal lookdub
1200 Deluxe
PostPosted: Mon Jul 15, 2024 9:38 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Waste of time, my point was I put GL5 in after draining GL4 and it shifted exactly the same.
Mr. 010
Glenn is offline
PostPosted: Mon Jul 15, 2024 12:50 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Great... I found that out 15 years ago. Welcome to the club.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bruce
Bruce is offline
PostPosted: Fri Jul 26, 2024 3:37 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Only one guy made that claim.
Bruce
Bruce is offline
PostPosted: Fri Jul 26, 2024 3:39 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
You can say the same thing when you switch from 80W-90 to 75W-90. One of my transmissions has 70W-85 in it.
Cusser
Cusser is offline
PostPosted: Fri Jul 26, 2024 6:59 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
My 1975 Chevy Luv used 30W engine oil in its manual transmission.
Mr. 010
Glenn is offline
PostPosted: Fri Jul 26, 2024 7:46 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Let's stone him.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
PostPosted: Fri Jul 26, 2024 9:02 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Let's stone him.
I have made that claim as have others, way more than one. What I am still waiting on is for Bruce to show me a gear set that was harmed by a GL-4 that is recommended for use in a transaxle with low offset hypoid gears.
Mr. 010
Glenn is offline
PostPosted: Fri Jul 26, 2024 9:22 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Let's stone him.
Generally when a product is superseded the old product doesn't instantly become obsolete.
For example, most spark plug manufacturers have switched to resistor spark plugs. Using non-resistor plugs will not harm the engine.
Use whatever you like... doesn't matter to me.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
PostPosted: Fri Jul 26, 2024 2:42 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Glenn wrote:
Let's stone him.
VW recognized that a GL-5 oil, like what they used in the final drives of the automatics could cause problems with the synchros in the manual gear boxes and thus specced GL-4. An oil that carries a GL4 & Gl-5 oil is a GL-5 oil for all intents and purposes and today may well carry a MT-1 rating indicating they are designed for non sychronized gear boxes and should not be used in a sychronized box.
As I have posted before, today's GL-4 oils give similar 4 ball wear test results to what comparably priced GL-5 oils do, so there is little or nothing to be gained by running a GL-5 oil.
oprn
oprn is offline
PostPosted: Fri Jul 26, 2024 3:54 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
No I don't think that is entirely true. There may be a small noticeable difference but in my case the change was huge. ATF is a completely different animal from 75w90! Living on the coast as you do perhaps you have never felt how stiff transmission oil can get in the winter.
Page 69 of 71
