What did you do to your Beetle this week?
Page: Previous  1, 2, 3 ... 319, 320, 321, 322, 323  Next
bandi
bandi is offline
PostPosted: Wed Jun 26, 2024 6:19 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
indianpeaksjoe wrote:
Bandi that is awesome!
-Joe
Thank you! I love your car. I *really* need to build a Baja some day.
'60 Canadian Standard, '64 Bug, '66 Bug, '66 Bus, '69 Sunroof Bug, '71 Super, '72 Super, '73 Canadian Custom, '73 Super, '74 Love Bug, '83 Mexi Bug, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S. And some Fieros.
scottyrocks
scottyrocks is offline
PostPosted: Sat Jun 29, 2024 2:54 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Today - wash, clay, buff, wax.
– D. Tartt, 'The Goldfinch'
WVDriver
WVDriver is offline
PostPosted: Sun Jun 30, 2024 11:27 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Added powder coated rims with whitewall tires to my 63 beetle.
indianpeaksjoe
indianpeaksjoe is offline
PostPosted: Mon Jul 01, 2024 6:56 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Looking sharp WVDriver!
I installed a Super Beetle Solutions cut off switch in my beetle. Wow it is nice.
More pics of the install https://robonza.com/beetle/index.php/2024/07/01/installing-a-super-beetle-solutions-cut-off-switch/
-Joe
Adventures in owning a 66 beetle
far rider Premium Member
far rider is offline
PostPosted: Tue Jul 09, 2024 9:24 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Decided to add hood springs to my 61 ragtop
67 zenith blue sunroof
Contentment; when what you have is what you want.
indianpeaksjoe
PostPosted: Sat Jul 20, 2024 9:40 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I finally got around to replacing my turn signal lever. It was pretty quick even though I had two wires left over, and unlike Ikea furniture I am not sure if that is a good thing. Everything works so I'll call it good Laughing
More pics and what not here: https://robonza.com/beetle/index.php/2024/07/20/replacing-the-beetle-turn-signal-lever/
-Joe
MrGoodtunes
MrGoodtunes is offline
PostPosted: Sat Jul 20, 2024 6:53 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I finally got around to replacing my turn signal lever. It was pretty quick even though I had two wires left over, and unlike Ikea furniture I am not sure if that is a good thing. Everything works ...
Everything, like even the dimmer button at end of signal stalk? That's probably what the 2 leftover wires are for.
indianpeaksjoe
PostPosted: Sat Jul 20, 2024 7:09 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Ooh, good guess. On my 66 the dimmer is on the dash as part of the head light pull. This lever and the old one did not have a dimmer. The two remaining were, according to the JBugs tech tips for ground and headlight relay.
-Joe
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Sat Jul 20, 2024 8:09 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Thumbs Up Yup ... that's pretty much my criteria for calling it a day! Laughing
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
MrGoodtunes
PostPosted: Sun Jul 21, 2024 8:51 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
... The two remaining were, according to the JBugs tech tips for ground and headlight relay.
Right then, brown for ground and brown with white stripe for headlight dimmer relay. So you get your choice; operate dimmer relay by squeezing end of turn signal stalk, or touch button on your dash control.
Note that the stalk button is normally open. It does nothing until squeezed, making momentary contact, which activates the dimmer relay (i.e. changes dim to bright or bright to dim, depending upon where lights were when contact was made). IDK how your dash button is setup, tho.
indianpeaksjoe
PostPosted: Sun Jul 21, 2024 10:33 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Oh, like high beam/low beam, sorry I thought you meant the inside light dimmer. I have a foot button down by the clutch pedal. I hit by accident all the time Smile
I'll check it out.
MrGoodtunes
PostPosted: Mon Jul 22, 2024 7:17 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
... I thought you meant the inside light dimmer. I have a foot button down by the clutch pedal ...
Aah sorry, I shoulda consider'd that possibility & been clearer. Anyway, the foot headlight dimmer switches I'm familliar with are heavy duty enough to toggle between brights & dims without a relay. So, you may need a relay in order to make use of the cute little button at end of turnsignal stalk. If you don't have such a relay, there's one here:
https://www.thesamba.com/vw/classifieds/detail.php?id=1121340
indianpeaksjoe
PostPosted: Thu Jul 25, 2024 7:26 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
The Baja has advantages having the engine just hanging out. Working on it is a breeze. The disadvantage is it can look messy. I cut a new coil wire and used some Jegs wire doodads to make it look a little less disorganized.
WVDriver
WVDriver is offline
PostPosted: Fri Jul 26, 2024 7:45 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
These items actually took place over several weeks.
1. Cleaned transaxle and inserted 4 Weedle Industry plugs.
2. Removed headlights and painted headlight buckets. Installed new headlight drains, parking light bulbs, parking light bulb holders, and headlight rings.
3. Installed new taillight lenses. Installed nutsert on driver's side taillight.
4. Installed front and rear bumpers.
5. Installed new running boards.
kvasilak
kvasilak is offline
PostPosted: Sun Jul 28, 2024 7:45 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
-Joe
Uh, you installed the cutoff on the wrong side.
You should always cut the negative side.
Replace the ground strap with a cable, easy
indianpeaksjoe
PostPosted: Tue Jul 30, 2024 6:45 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
-Joe
Their product is designed to go on the positive side. I don't think it has to be done one way or the other. HotVWs installed it on the positive side as well: https://static1.squarespace.com/static/5f65d253b91...ov2014.pdf
-Joe
indianpeaksjoe
PostPosted: Tue Jul 30, 2024 6:47 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Finally got around to wrapping the exhaust to keep the heat down. All those years of working in bike shops wrapping road bike handlebars paid off Very Happy
-Joe
slave1pilot
slave1pilot is offline
PostPosted: Tue Aug 06, 2024 2:31 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Sprayed Epoxy primer on the body
Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
PostPosted: Tue Aug 13, 2024 6:38 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Nice work. When you paint the car will you do interior and exterior at the same time?
indianpeaksjoe
PostPosted: Sun Aug 18, 2024 7:38 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I did three projects this week.
- installed EMPI 3 point seatbelts.
https://robonza.com/beetle/index.php/2024/08/17/installing-3-point-seat-belts-on-a-66-beetle/
- installed a new muffler.
https://robonza.com/beetle/index.php/2024/08/17/installing-a-new-empi-muffler/
- small thing, but put swapped out some old crusty nuts and bolts for rivnuts on my coil bracket
https://robonza.com/beetle/index.php/2024/08/19/co...fe-easier/
And a few fun cruises.
-Joe
Page 320 of 323
