Sliding door rubbing tire
Smileydude
Smileydude is offline
PostPosted: Mon Jul 29, 2024 9:32 pm    Post subject: Sliding door rubbing tire Reply with quote
I have the gowesty lift, tires and rims.
Plus a burley rear disk brake kit.
I seem to have a slight rub on the tire walls from the sliding door now.
Is this normal? Any simple fixes?
E1
E1 is offline
PostPosted: Mon Jul 29, 2024 9:43 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
Too-wide of wheel offset?
(We have same wheels, I think, they take 215/65-16)
Is the overall track width from brake disc face to disc face same as stock?
(It almost has to be)
Combo of both?
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s
1988M5
1988M5 is offline
PostPosted: Mon Jul 29, 2024 10:33 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
https://www.rhoen-bull.de/Other/door-bail-extension::22.html
1991 tin top GL
Some BMWs.
MarkWard
MarkWard is offline
PostPosted: Tue Jul 30, 2024 5:11 am    Post subject: Re: Sliding door rubbing tire Reply with quote
I purchased GW 16 alloys when I first put our van on the road. They bolted right up. The one measurement I had overlooked was the sliding door. It was close, but cleared the tire. Whew.
Anyhow, adding a brake disc in place of a drum does space the wheel further out. Didn’t click on the link, but I recall there was a do hickie that kicks the rear out somehow.
boxer74
boxer74 is offline
PostPosted: Tue Jul 30, 2024 6:21 am    Post subject: Re: Sliding door rubbing tire Reply with quote
Rear disc kits space wheels out an additional 4mm compared to stock drums. That coupled with your GW wheels that have an ET23 offset are the problem.
If it were me, I'd get different wheels. Talk to Chris at T3 for recommendations on offset, etc.
74 Super
84 Westy
MarkWard
MarkWard is offline
PostPosted: Tue Jul 30, 2024 7:22 am    Post subject: Re: Sliding door rubbing tire Reply with quote
Also, rear disc conversions may require longer wheel lug studs. Did you replace those?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Jul 30, 2024 7:24 am    Post subject: Re: Sliding door rubbing tire Reply with quote
The needless 7.5 width of the GW wheels makes it even worse.
Too bad we can't get 6" or 6.5" wheels in 16" with ET30-37.
Mark
Wellington
Wellington is offline
PostPosted: Tue Jul 30, 2024 11:49 am    Post subject: Re: Sliding door rubbing tire Reply with quote
you can
2010 Tiguan
crazyvwvanman
PostPosted: Tue Jul 30, 2024 12:48 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
Center bore too small.
Mark
PDXWesty
PDXWesty is offline
PostPosted: Tue Jul 30, 2024 12:59 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
Discussed here: https://www.thesamba.com/vw/forum/viewtopic.php?t=663892
Buy extra hinges here: https://www.thesamba.com/vw/classifieds/search.php...ton=Search
89 Westy 2.1 Auto
Wellington
PostPosted: Tue Jul 30, 2024 1:06 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
The Tiguan alloy wheel does need the center bore opened very slightly.
Very easy to do.
That one operation gives you a perfect bolt on wheel, with a center cap that fits, and a factory VW wheel, not an aftermarket Chinese wheel prone to cracking.
danfromsyr
danfromsyr is offline
PostPosted: Tue Jul 30, 2024 1:23 pm    Post subject: Re: Sliding door rubbing tire Reply with quote
some have used a router to open up the center of an aluminum rim.. should be able to find that in a search
I went this route.. a 65mm step drill
https://www.amazon.com/OCGIG-6-65mm-Spiral-Groove-Titanium/dp/B075K5TLN2
Abscate wrote:
