JeffRens Samba Member
Joined: August 25, 2012 Posts: 267 Location: Mishawaka, IN
Posted: Fri Jan 04, 2013 3:04 pm Post subject: Polar Silver Paint |
| Trying to find a local supplier for polar silver paint for my 56 Oval restoration. Any advice on brand of paint and where to find it? Suppliers can find the original L324 but I would really like a base coat/clear coat kind of thing ... I like the thought of metalflake maybe too. They don't have the PPG 31549 listed anymore Thanks for any help as always....Jeff |
Scott13 Samba Member
Joined: February 17, 2004 Posts: 76 Location: Hartland, WI
Posted: Fri Jan 04, 2013 5:58 pm Post subject: |
Here is the rundown I used...
Spies Hecker HS Vario Surfacer Gray (Sealer).............3.5L can
Spies Hecker 1957 VW L324 Base Coat 293/295.........2 gallons
Spies Hecker Clear Coat 8180......................................5L can
The original color has a very fine metalic in it, as does this paint. Hardeners and reducers are also required. Be prepared to shell out about
$2000 though.
I bought this from my local auto paint supply store that sells PPG and
DuPont. I painted the entire car inside and out and used half of the
sealer(1 coat), 1 3/4 gallons of base(3 coats) and the entire 5L can of
clear(4 coats). This paint laid down very nice and 3 days later, wet sanded
and buffed. This is only the 3rd car I ever painted and had very little
problems with it. I also had an original painted door hinge screw and it
matches perfectly.
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1467 Location: San Carlos, CA
Posted: Fri Jan 04, 2013 6:48 pm Post subject: |
BTW, do you have any idea how much more would Glasurit paint cost? 1k? 2k?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Fri Jan 04, 2013 7:39 pm Post subject: |
| Nope. I never looked into Glasurit. |
bro2539 Samba Member
Joined: May 03, 2004 Posts: 414 Location: fort worth, texas
Posted: Fri Jan 04, 2013 7:40 pm Post subject: |
| beautiful job on the paint! |
Posted: Fri Jan 04, 2013 7:48 pm Post subject: |
| Thanks, Bro. |
L378 Samba Member
| gimmesomeshelter wrote: |
Cheers,
Paul |
From the first post in this thread about STRATOS silver http://www.thesamba.com/vw/forum/viewtopic.php?t=533365
| Quote: |
Sounds like a lot of people have had problems with this, and I have as well. Hopefully this will help people a little more.
This is my experience calling around to different places. This information and these prices reflect the cost of a gallon of L227 in BASECOAT and does NOT include reducer or the clearcoat/hardener.
PPG - As was said in other posts, the paint code is 31550, although this doesn't really help them at the store. There are apparently 200 different colors that are all 31550 (go figure). If they call the color library they will be helped, though. They told me they couldn't make it in OMNI (their cheaper line), although someone else said they got it in that. Anyway, it's available in two different forumals, one for about $425/gallon and one for $450/gallon.
Dupont - Their paint code is 102954A (they had to call for it). They can't make it in Nason (their cheaper line). It's $425/gallon.
Sherwin-Williams - Couldn't help at all.
NAPA - Couldn't help at all.
tcpglobal.com - No real code, just ask for L227 Strato Silver. It's by far the best price at $200/gallon.
Glasurit - Like tcpglobal, there's no special code for them. He found it right away by searching for L227 Strato Silver. Price is $615/gallon.
If anyone has other suggestions on where to get this paint, or anything else to add, please do so! Good luck.
Dan
1961 Beetle w/ 23,000 original miles
1963 Sunroof Beetle x2
1964 Sunroof Beetle
Red Barn Restorations
Trevor P Samba Member
Joined: January 21, 2004 Posts: 904 Location: Saskatoon, SK, Canada
Posted: Fri Jan 04, 2013 10:08 pm Post subject: |
I have a mix formula for the base/clear in Sikkens that is pretty close if you need. I assume you guys still use solvent based paints down there. Here they are no longer allowed to be sold due to very strict VOC laws. Be aware that this color is a pain in the ass to match to (don't ask me how I know)
_________________ 53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1924 Location: Fontana
Posted: Tue Oct 01, 2024 8:22 pm Post subject: Re: Polar Silver Paint |
Any updates on this paint code I looked at the current internet looks light gray but in pics u can see the metallic s and a bronze tint? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
67ctbug Samba Member
Posted: Wed Oct 02, 2024 7:21 pm Post subject: Re: Polar Silver Paint |
You'll never be able to judge the color off of your phone. Just go to your paint jobber and give them the code for Polar Silver and they should be able to pull it up. If it's not in the system, they can scan an original piece and make it or have the lab make a service formula from it. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
| KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
| mukluk wrote: |
| He's fine, just waiting for the dragon in winklepickers to move out of his lane. |
a57oval Samba Member
Joined: September 28, 2003 Posts: 207 Location: West Seattle, WA
Posted: Thu Oct 03, 2024 4:21 am Post subject: Re: Polar Silver Paint |
I have a Polar Silver 57. I was fortunate enough to have access to a Glasurit mixing bank and spent about 14 hours dialing in a formula for my car in Glasurit 55 Line which is a basecoat/ clearcoat.
I did mutiple sprayouts after each alteration of the formula to verify it was very accurate. I used an inner door jamb as reference to match the color.
I consider the match very accurate to the original paint.
Peter
