What did you do to your Beetle this week?
Page: Previous  1, 2, 3 ... 320, 321, 322, 323, 324, 325  Next
WVDriver
WVDriver is offline
PostPosted: Mon Aug 19, 2024 9:26 am    Post subject: 63 VW Beetle Reply with quote
Thought I had an alternator issue because the idiot light was coming on periodically. Turned out that the idiot lights were wired up backwards. Corrected that problem but that left me with an oil pressure issue. Installed a new oil pressure relief valve and spring to fix that issue. One of the idiot light bulb holder electrical legs was broken, so I ordered a used speedometer off of ebay. The plastic portion on the ordered holder fell apart in my hand when I removed it but the electrical connector was good. I drilled out the rivet holding the connector in and transferred it to the plastic holder on my speedometer.
TOTSKI
TOTSKI is offline
PostPosted: Tue Aug 20, 2024 2:34 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I drove it to the beach. Perfect weather here at SF 😎🌞
slave1pilot
slave1pilot is offline
PostPosted: Tue Aug 20, 2024 3:37 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
far rider wrote:
Nice work. When you paint the car will you do interior and exterior at the same time?
Yes I did
can't really tell in the pic though
Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
indianpeaksjoe Premium Member
indianpeaksjoe is offline
PostPosted: Wed Aug 21, 2024 7:17 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I upgraded to KC Gravity LED headlights for Jeep TJs. They are bright and have a nicer pattern than the VintageCarLEDs I had before. The VCL headlights were not bad, but these are nicer. The VCL ones look more stock, but my baja is far from stock looking.
More pics here: https://robonza.com/beetle/index.php/2024/08/22/kc-7-gravity-led-headlights-on-66-beetle/
-Joe
Adventures in owning a 66 beetle
far rider Premium Member
far rider is offline
PostPosted: Thu Aug 22, 2024 6:57 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Used a cable, long enough to reach the far end of the tank , to Roto
rooter my ‘61 tank. You can see some of the crud and scale knocked off after one pass.
67 zenith blue sunroof
Contentment; when what you have is what you want.
PostPosted: Sun Aug 25, 2024 10:20 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Woohoo I got emergency lights set up using my flashers.
More pics here: https://robonza.com/beetle/index.php/2024/08/25/adding-emergency-flashers-to-66-beetle-baja-bug/
-Joe
trektider60
trektider60 is offline
PostPosted: Wed Aug 28, 2024 5:36 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Not many miles on the new carb; runs great on the road. Last two trips to town with a few different stops and the carb was flooded after setting 5 minutes. So I finally got a fuel pressure gauge and found 4.5 psi. Got the pressure down to 3.0 psi with the addition of 3 more gaskets. Seems much better now.
1960 Indiana Red T1
PostPosted: Sun Sep 01, 2024 7:27 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I loaded up the mountain bike and hit the trail.
-Joe
PostPosted: Sun Sep 01, 2024 11:21 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Cool pics with the MTB, sweet bike too
PostPosted: Sun Sep 01, 2024 6:05 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Thanks Everett. This is the furthest I drove the beetle since I (yes, totally me) caused a stalling issue with a mod I made incorrectly. So you know, the bike wasn't only for riding the trail, but possibly to ride home if it broke down Laughing
Everything went great, only peddled on the singletrack !
-Joe
PostPosted: Mon Sep 23, 2024 5:44 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Got it painted. I’ve been stressing but it came out pretty decent. I can only add- the work is in the prep. Hours and hours of sanding. Also I sprang for the Harbor freight black widow HTE gun- $180. But glad I did
PostPosted: Wed Sep 25, 2024 8:37 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Awesome work far rider.
I painted my lower fenders with bed liner, the rocks on my road are destroying them. So far this is working.
-Joe
PostPosted: Wed Sep 25, 2024 8:53 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I parked it the other day to walk out the next morning with oil leaking from the passenger side trans area. I tightened the hose clamps on the boots and hope that’ll fix it. Ordered new ones too, because I have a hunch that won’t work Smile
-Joe
PostPosted: Mon Oct 07, 2024 6:26 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
The hose clamp tightening did not help, but split boots from JBugs made for an easy fix.
More pics here: https://robonza.com/beetle/index.php/2024/10/07/new-boot-scootin-new-axle-boots-that-is/
-Joe
bandi
bandi is offline
PostPosted: Tue Oct 08, 2024 8:01 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Well, haven't had much time to work on my own Beetle(s) but I did realize the Fuchs wheels from my daughter's Playmobil Carrera 2.7RS fit on her Beetle.
I feel like this is important stuff.
If only they could bring out a 356 so I could put some slotted steelies on a Bug.
'60 Canadian Standard, '64 Bug, '66 Bug, '66 Bus, '69 Sunroof Bug, '71 Super, '72 Super, '73 Canadian Custom, '73 Super, '74 Love Bug, '83 Mexi Bug, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S. And some Fieros.
PostPosted: Wed Oct 16, 2024 12:14 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Ran a new wiring harness. Didn’t go smooth but it’s in.
PostPosted: Thu Oct 31, 2024 10:14 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Painted the gas tank. Used Max-Flex Victory blue satin. Closest I could find to a blue-grey. It’s actually a little lighter in color than it appears
AirHead1966
AirHead1966 is offline
PostPosted: Thu Nov 14, 2024 6:54 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Added a backup wire for the front hood latch release in case the primary wire ever fails or jams. The new wire is under the car, tucked away in the wheel well but can be pulled out through an existing drain hole when needed.
benthere7575
benthere7575 is offline
PostPosted: Mon Nov 18, 2024 1:06 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
rewired for 12v, but I can't find a diagram of how to wire the potentiometer that's mounted behind the speedo. I also can't find a diagram of how to wire the oil pressure gauge. It looks like the previous owners cut the wires to these devices and pulled the leads, so I can't even match wire to for the voltage reducers.
shum
shum is offline
PostPosted: Sun Nov 24, 2024 11:14 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Time to replace the original front shocks, only 57 years on these. Smile Nice Sunday project.
57 rag top, 67 bug, 73 Thing
70 Bronco U14, 73 Bronco U15
61 R69S/2 BMW, 73 R75/5 BMW
Page 321 of 325
