Steering Position Sensor & now Yaw Rate Sensor
Page: Previous  1, 2, 3
samba415
samba415 is offline
PostPosted: Fri Sep 13, 2024 4:47 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
From Dave Sheon's other thread:
https://docs.google.com/document/d/16R2XLPrQxe9ORBhStKrWIED6imh-Gm6dFoKgjBrlV3E/edit
Found that.... It's a start, but the "9am to 12pm" of the clock spring board is blown out a touch. BigfootEv's third pic in the thread is money on the detail but misses that area.
I've noticed the rebuild outfit in Germany (KFZ) I linked in the thread here has raised their rebuild prices. Seems they've caught on to this captive market. Wreckers here in NA are/were selling (when available) pulled ESP units for $650-$850 pricing with "coin-flip" results for the buyers. KFZ may have seen that.
Old stable: '63 Baja, '69 Square, '72 Bug, '65 & '67 Samba, '73 412 wagon & 2dr 4spd
Current: '04 Golf TDI, '03 Weekender
bigfoot_ev
bigfoot_ev is offline
PostPosted: Fri Sep 13, 2024 5:18 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Sorry, I didn't get a straight on picture before I glued the plastic in place. I was also going to link to dsheon's post. Maybe he has a higher resolution pic he could post instead of posting it via a google doc.
samba415
samba415 is offline
PostPosted: Fri Sep 13, 2024 5:26 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Zero need to apologize. I'll keep searching. When I find one, I'll post it and folks here can do for themselves.
vwplenty
vwplenty is offline
PostPosted: Sat Sep 14, 2024 10:00 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Here is a clear picture of the clockspring traces.
Cheers,
Robert
This one with a cover over the traces cut from a 3m electrical tape box of PP5 polypropylene.
dsheon
dsheon is offline
PostPosted: Wed Sep 18, 2024 12:07 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Bigfoot - wow thank you. My only question (for now). When you say to give two turns to the right and two to left, can you provide context for that? Am I to turn the little gear with the yellow paint twice in either direction before putting the painted part into the eye as you note, or is the the copper sensor? Just a little confused. Will try next to paste the photo directly here. Update: a friend with a multimeter has tested the traces and we can't find a problem! Not really sure what to do other than paint w nailpolish and insert the plastic ring (because wny not)
bigfoot_ev
PostPosted: Wed Sep 18, 2024 6:46 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
If you look at my last pic there are 2 pieces that must come apart. In the picture, I'm putting them back together to finish up. One piece is the clockspring, that is the lower right hand side of the picture. The other is the steering angle sense in the upper left. I'm specifically talking about the clockspring piece. When it is snapped back on top of the steering angle sensor and everything is placed back on the steering column and you are sitting in the drivers seat you will see the airbag plug and 2 pins that the steering wheel fits over. Those pins are what I discuss about turning 2 to the left and 2 to right. It is the clockspring piece and NOT the steering angle sensor that needs to be centered and have the equal turns left and right. If your traces are good then I agree, just put some protection in place and put it all back together.
But, the wheel you mention, which is part of the steering angle sensor does need to be in the correct position as well.
I have 2003. I think there are differences with these parts with other years but I only know my model year. And I believe the 2001-2003 are the same.
dsheon
dsheon is offline
PostPosted: Mon Sep 23, 2024 12:01 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Thanks for that explanation.
I would post a better photo but I have a guy working on the sensor/PCB using a multimeter to find any shorts. He says it's working perfectly though and can't find any issues.
I spoke with the mechanic, or had an exchange with him. He said there are no codes from the sensor - it wasn't working at all, completely dead.
I have a new theory. the Sensor "wheel" that aligns with the eye has a triangular shaped "wedge" on top that looks to have spongy material. I would describe the material as similar to the thin foam in a soft packing envelope.
That may have disintegrated a bit. You can kind of see it in my photo/google doc. When I opened the clockspring there was considerable dark dust/debris that could have come from that. And on the copper disk side there was a sticky smudge directly over it - as though it over heated and melted. I could see a finger print there - likely from when it was installed. I wonder if oil from a finger may have eventually accelerated some sort of burning. I have it all cleaned up but wonder if I should attempt to replace the remaining "foam" and if so what I should use. Any reactions to that? We will fix some of the traces that have slight damage though they still carry load. And I will insert the plastic ring.
dsheon
dsheon is offline
PostPosted: Wed Sep 25, 2024 3:42 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Hello,
Updating on my little steering angle sensor mystery.
The traces are all in tact and tested on multimeter.
However, the little wedge shaped pad that sits atop the sensor wheel and rubs against the copper ring has warn. I believe a fingerprint (probably from the factory) on the copper ring was perfectly aligned with the pad and over time oil from that fingerprint dissolved the pad. When I opened the spring there was a black smudge on the copper immediately where it meets the pad. And little pencil-erasure like shavings were inside the device.
Photos - see the second page at about 1 o'clock you can see the smudge. I cleaned it with rubbing alcohol but on page 1 you can see the pad looks warn.
https://docs.google.com/document/d/16R2XLPrQxe9ORBhStKrWIED6imh-Gm6dFoKgjBrlV3E/edit?usp=sharing
Does anyone by any chance know if that pad conducts electricity and/or have suggestions for material to use to replace it? Or maybe go without it and I suspect the device will be louder? Given the traces were solid this explanation - that the pad was sticking/melting over time due to a fingerprint, while unusual, seems possible. Thoughts?
owokie
owokie is offline
PostPosted: Thu Sep 26, 2024 8:15 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
dsheon wrote:
Hello,
No. You're wasting your time without pulling the damn code. Even if the entire unit is dead, vag-com will tell you that with a "no comms" code.
dsheon
dsheon is offline
PostPosted: Thu Sep 26, 2024 10:37 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
I appreciate that but here's the situation. A friend who built circuits for Apple has the devices and is going through it - so I can't put it in the van and get a code at present. And when I ask my mechanic for the code they saw, I am told the sensor is "completely dead" - not exactly answering my question. In fairness, it's been a year since they did that diagnosis. But it's interesting I've been driving on it dead for a year and there is no sign of traces warn; and extensive multimeter testing comes back that everything is fine.
I'll take it back soon and we'll plug it in and see if they get a code. I have an OBD Fusion and got no codes when everything was assembled. Horn worked and no airbag notice.
So I do think that melted pad on the sensor makes sense but we'll try again and get the code if any from the mechanic. He told me "we've seen this before, you either need to replace it or use the online hack from Samba."
owokie
owokie is offline
PostPosted: Fri Sep 27, 2024 6:39 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
OBDEleven. Get that (or rosstech, or whatever), plug it in, pull codes after you put your van back together. Don't be afraid of the airbag when your batt is disconnected. Try the ABS unit you picked up. If that doesn't work and you're stuck without codes giving you a better idea, I'll send you my spare clockspring and you can see if that works. $100 says it has nothing to do with that tiny indicator wheel.
dsheon
dsheon is offline
PostPosted: Sun Sep 29, 2024 10:56 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
[quote="owokie"]
I won't take the bet - and if I were comfortable taking the airbag on and off I'd do this - but I'm just not that mechanical. I have an update though as my friend who used to build circuits for Apple is done with the device. He said every aspect was tested and did fine. Two of the three soldered points at the mouth of the device (where it opens) however just didn't seem stable to him so he touched those up.
Given the mechanic reported the device was dead, we also focused on all the pins for the airbag, horn, and power and cleaned those. I'll put in the ring anyway even though the traces looked great - why not - and it goes back to the shop next week. I've added updated photos in the google dock.
Also where I thought the wheel had foam on it that maybe decomposed and caused the shavings - that's obviously a magnet on further review not foam. ANd the magnet works fine. Thanks all for your review/guidance and hopefully this will help someone else.
dsheon
dsheon is offline
PostPosted: Fri Oct 11, 2024 11:41 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Gave my highly tested sensor to the mechanic to reinstall, as I don't have those skills. He did all the turns to the left/right and lined it up. They say the part is no good.
Despite testing every trace and solder joint w multimeter - all good.
It shows 0000 so it's reading initially but won't take any codes and doesn't change when the wheel is turned. He thinks its the actual sensor and that it's just failing now. So it's important to pass on that these can go bad and have nothing to do with traces being worn out.
Endopotential
Endopotential is offline
PostPosted: Tue Dec 24, 2024 10:20 pm    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
First off, big thanks to @bigfoot_ev for holding my hand and talking me through this process. A couple things I learned, to add for whoever else follows:
- If like me, you've never worked on taking a steering wheel apart before, I found it hard to turn the wheel on a concrete driveway with the battery disconnected and the power steering pump nonfunctional. So lift up the front end with some jack stands and it's easy.
- Taking the clockspring off of the SAS/steering angle sensor is easy by prying up on the plastic tabs
- To be paranoid, as soon as the clockspring comes off, put a piece of tape around the perimeter so that it can't turn on itself and throw things off
- But removing the SAS from the steering column had me stumped for a bit.
Don't pry straight up as in the first picture, or you'll break the tab. If you look real closely, each tab sits very flush with shelf below it. Wedge a small screwdriver blade into the gap FROM THE SIDE for each of the two tabs on top, and the SAS slides off easily
- About that black cogwheel with the magnet and yellow paint marking, does anyone know what it does or how it functions?
It cog teeth don't seem to mate to anything, and that magnet throws off the balance point such that I had trouble keeping it at the 12 o'clock position during the reassembly process. I ended up using a small but very strong magnet on the outside to keep that cog in place during reassembly, then removed the magnet. Maybe the clockspring has a magnet in it to pair up with the cog?
At 130k miles, my circuit board thankfully still looked pristine. Hopefully this will be good preventative maintenance. I would get a random ABS/traction control dash light from out of the blue sometimes. Curious to see if it will go away after this.
BTW I didn't need VCDS or any reprogramming/alignment after this process, and van seems to steer just fine during the 3 mile test drive.
swimrr
swimrr is offline
PostPosted: Thu Jan 09, 2025 10:17 am    Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor Reply with quote
Just a quick shout out to everyone who posted the amazing information in this thread. I'm contemplating taking out my dash to preemptively replace the heater core and have always read that one has to be careful with the clock spring. Knowing that there are fixes and workarounds out there and a still active group forum is very encouraging.
Thanks everyone!!!
Page 3 of 3
