Bug Buckets in Ghia
jtbuck
jtbuck is offline
PostPosted: Mon Oct 14, 2024 6:04 am    Post subject: Bug Buckets in Ghia Reply with quote
Any post on how to put the 66 VW headlight buckets in the Ghia's??
onwardtothestars Premium Member
onwardtothestars is offline
PostPosted: Mon Oct 14, 2024 7:49 am    Post subject: Re: Bug Buckets in Ghia Reply with quote
Popcorn If you want a porsche, buy a porsche
Beetle, Ghia, Vanagon Syncro, and more
jtbuck
jtbuck is offline
PostPosted: Mon Oct 14, 2024 8:55 am    Post subject: Re: Bug Buckets in Ghia Reply with quote
What I didn't ask was for some smart a$$ answer.. It's my car and if I choose to put these headlights in why would you care....?????
PostPosted: Mon Oct 14, 2024 9:24 am    Post subject: Re: Bug Buckets in Ghia Reply with quote
It’s yours. Do as you will.
Use the search luke!
https://www.thesamba.com/vw/forum/viewtopic.php?t=160903&highlight=beetle+headlights
iowegian Premium Member
Samba Curmudgeon
iowegian is online now
PostPosted: Mon Oct 14, 2024 9:50 am    Post subject: Re: Bug Buckets in Ghia Reply with quote
quote="onwardtothestars"]
https://www.thesamba.com/vw/forum/viewtopic.php?t=160903&highlight=beetle+headlights[/quote]
In that thread 10 years ago I said:
"Type II units work much better. Just whack 'em out of the front of an old bus and rotate them 90 degrees. Plenty of extra sheet metal to cut "darts" in so you can bend back and blend into the Ghia fender. And, yes--------I've done it."
My son's car in Rocky Mountain Motorworks' ads in 1999.
Evil_Fiz
Evil_Fiz is offline
PostPosted: Mon Oct 14, 2024 4:41 pm    Post subject: Re: Bug Buckets in Ghia Reply with quote
I like the way the slanted lights look on a Ghia. The only part of the conversion that puts me off is how the front end looks like a ham cut on the bias when viewed from the side. Reshaping the lower portion of the wing to continue the slant and transition into a more vertical descent would provide the finishing touch.
This is not meant to be a knock on your choice, but rather an option to get the best out of your project.
Emil
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
