90 Amps load test at alternator post
harvgwen
harvgwen is offline
PostPosted: Sun Oct 20, 2024 7:36 pm    Post subject: Re: 90 Amps load test at alternator post Reply with quote
And, I’m probably stating the obvious, when checking for voltage drops across each segment (as in your above diagram) it needs to be done while under the 90A load to be meaningful.
1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia
Sodo
Sodo is offline
PostPosted: Sun Oct 20, 2024 7:45 pm    Post subject: Re: 90 Amps load test at alternator post Reply with quote
But Harv..... wouldn't a load test under "no load" still be "a load" of sorts? Wink
(A load of crap)
"Under load" is KEY here.
Using "the starter" is a PITA compared to a specialized 90A tool. (in this case $19.95)
Starter could be intermittent, and varying amperage.
It's noisy and moves stuff, rolls the van off your ramps, wraps up your voltmeter leads in the belts.
With modern, specialized uses for existing tooling Wink
we can do the test with a consistent 90A for more certain diagnosis.
And its easier to learn "the voltage drop test".
....KTMs, GasGas, SPOT mtb
harvgwen
harvgwen is offline
PostPosted: Sun Oct 20, 2024 8:48 pm    Post subject: Re: 90 Amps load test at alternator post Reply with quote
I agree, a load tester is much better than using the starter. In my case, I don’t have one.
The voltage drop test does need to be done under load. If a contact is quite corroded for example, the minuscule amount of current that the volt meter uses might not notice the corrosion at all, while 90A will have trouble passing through it. Maybe envision a thick ground cable that has a section so worn through that there are only a few wires still intact. A small dash light bulb may still work just fine and your volt meter may read almost no voltage drop, but if you try turning your starter through that worn cable, your voltage drop will be huge.
fxr
fxr is offline
PostPosted: Mon Oct 21, 2024 2:12 pm    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Personally I'd use a separate voltmeter while using the '90A' load tester - there may well be some voltage drop across its crocodile clips which you need to discount. That voltage drop could be variable as well, even if the 90A current is fairly consistent.
Jim Crowther
Vespa GTS 300
Sodo
Sodo is offline
PostPosted: Mon Oct 21, 2024 6:36 pm    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Me too!
OK I did it.
Looks like my battery ground cable from 1990 isn't doing so great (0.234v = 1.9% loss in only 7 inches).
But it LOOKS good.
And the connection to the chassis is clean.
My (newish) alternator ground cable doesn't look so great either (1.5% loss).
But my FAT 10.5 foot battery cable and the 3ga to the alternator looks pretty good.
I wasn't regimented on the connection points (lugs or strands etc etc.)
But anyway it adds up to about 0.7volts of wire drops and 1.0v right at the battery.
harvgwen
harvgwen is offline
PostPosted: Tue Oct 22, 2024 6:39 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Oh wow! I would not have guessed that short nice looking ground cable would have caused that much loss. My question here is if your seat rail (where your red lead is connected) is a good ground. Or maybe we all need heavier battery ground cables.
AlfromNH
AlfromNH is offline
PostPosted: Tue Oct 22, 2024 7:29 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
What if you put the red lead on the shiny metal right next the ground lug?
‘88 2wd Auto Westy project
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2024 8:01 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Al good question !
Less reliance upon "connection quality" is a feature of the "voltage drop test".
The voltmeter is using microamps (?? FXR is that true? Maybe milliamps??) and reading voltage (like pressure), not current (flow).
The distance
-between the seat rail and the shiny spot-
becomes immaterial with such low current.
It's the pressure.
If I was trying to measure the 90Amps current across that (caused by the HarborFreight load tester) there could be a difference due to the different "surface conditions". But notsomuch with voltage.
What your Qs merit....is a "voltage drop test" with the ground strap unbolted from the van and the full 90A thru the strap ALONE.
Harv, note part of this circuit goes thru 30 inches of 3ga cable (v drop test3) enroute to the Load Tester. This suggests 3ga cable is sufficient. I will re-measure vdrop3 and we'll see.
Harv and Al, were you guys on TheSamba 10 years ago? This here is like classic Samba 10 years ago (pre Facebook) when members would get outta bed and run out to the garage in skivvies to get a bolt length (etc) for another member in a bind.
E1
E1 is offline
PostPosted: Tue Oct 22, 2024 8:27 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Some of us still do that, even if without the garage. Wink
Seeing more clarity a comin’ in this thread, Tom… Well Done.
Are you thinking of making a larger ground?
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Oct 22, 2024 8:30 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Instead of assuming why not measure some more?
Put the tip of both meter probes into the strands of the negative cable, as close to each end of the cable without touching the terminal ends of the cable.
That should tell the drop due to that 7 inches of cable.
How much?
Then with a probe still in the end of the strands near the battery put the other probe at the battery post center.
How much?
Then the other end of the strands and the body metal right next the the bolt.
How much?
On and on to see if there is a bad crimped connection or bolted connection, or what.
Mark
Sodo wrote:
Looks like my battery ground cable from 1990 isn't doing so great (1.9% loss in only 7 inches).
But it LOOKS good.
MarkWard
MarkWard is offline
PostPosted: Tue Oct 22, 2024 9:11 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
The battery end in that picture looks very distorted and it appears to not be fully down on the terminal. In my years, I have seen many voltage drops through the battery clamps. The posts get oxidized and in this case disimilar metals. I have a battery brush tool for this purpose. You would not believe how many vehicles over the years I have fixed.
If I had a 40 year old vanagon with the starting battery under the front seat, I'd probably just run a long ground cable like the positve cable right to the engine starter. That's your biggest load. Everything else can with in reason work with some drop.
I was helping someone at the VW GTG with a slow crank on a new battery they purchased on the way to the GTG. I found that there was a voltage drop through the actual chassis. I guess over the years, the spot welded panels just weren't in the mood to pass current any more. So they could get home, they had a long set of jumper cables and I showed them how to temporarily connect the starting ground to the engine case. I suggested when they got home that they have their mechanic run a new cable as above.
E1
E1 is offline
PostPosted: Tue Oct 22, 2024 9:23 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Great info, Mark!
So… instead of removing the transaxle ground and replacing that with a longer starter-to-frame ground, is what you’re saying?:
— Still remove transaxle-to-frame ground?
— *And* run a long, single (battery gauge-sized) ground cable directly from starter to battery negative?
This makes massive sense… eliminates two ground points... and still supports Sodo’s adept theory that using the tranny as a ground is a really bad idea.
Is that additional length at all detrimental in terms of increasing resistance from the longer overall path?
Or is that more than compensated for by using a larger-gauge cable as logic might indicate?
MarkWard
MarkWard is offline
PostPosted: Tue Oct 22, 2024 9:44 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
The chassis still needs a ground for everything else, so the transmission ground would remain. You could also add an 8 gauge or so wire from the battery negative to the original ground location for the normal chassis loads. I'm not saying this is necessary, only sharing something I came across this year.
At a VW GTG, you can imagine how many experts looked at this problem. I usually hang back in those situations. After the crowd dispersed, I got involved. I carry a spare transmission ground that I added, not replaced. I also redid the battery ground. Still I was getting about a volt or so drop across the chassis. It was an 80 air cooled with new paint. My assumption was the spot welds just couldn't pass the current any more.
E1
E1 is offline
PostPosted: Tue Oct 22, 2024 10:00 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Awesome.
Our battery ground is the “belt style,” which is probably okay, but I don’t know.
My factual knowledge is a bit scarce on this point, but I personally try to have my grounds touching sanded and brushed metal, with a spot of dielectric grease to delay future rust — as opposed to wondering what effect paint has on contacts.
THANKS!
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2024 10:11 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Paint is an insulator.
With paint, the current goes
    from the lug to the bolt
    then
    bolt to the (welded to chassis) thread.
That's a series connection (a daisy-chain) of two jumps, and the resistance is "additive" thus the vDrop is higher.
Thass' why I say eliminate all those bolt-to-case-to-bolt-to-case-to-bolt etc across the gearbox and bypass ALL of them with one copper cable.
You want the electricity to go from the lug direct to the chassis (one jump).
Soldering the lug to the chassis could be better, but somewhat difficult.
If you MINIMIZE the count of jumps, it can be "real GOOD".
I highly DOUBT that welds degrade and the chassis itself becomes resistive.
It's ALL about the connections TO the chassis.
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2024 10:12 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
... Mark says....hopelessly ensnared within my TRAP! (heh)
As you can see the strands are good, with only 0.020v loss.
The biggest Vdrop (0.121v) being the *series* of connections from the strands across the interface, in the crimp, to the battery post.
The other VDrop in the other post above, was 0.234v on the whole segment.
And there are 'variations' in each measurement. I'm only showing ONE in the microsecond of the pic.
And battery voltage drops over the (short) time that its outputting the 90A load.
....then another Mark pigpiles on
I've done a few battery clamps too...over 6 decades too,
and kinda know if its gonna perform.
But this one has been exercised about 10 times in the last 2 days and is wearying.... Shocked
And since we've got the eqpt setup to do more than "assume"....
(segue to etymology of the word: "making an Ass outta U and Me")
But note too that the battery voltage shows 9.4v now. The battery is only 1 year old. Also trying to do this task while holding probes and taking pics with my third hand takes more time, maybe I'm pressing the 90Amps too long.
Now wait just a minute....
.....who's caught in whose trap? Wink
fxr
fxr is offline
PostPosted: Tue Oct 22, 2024 10:16 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Microamps is correct for most digital voltmeters - nanoamps for the high-end ones.
A direct cable from battery negative to starter cannot be a bad thing!
Jim Crowther
Vespa GTS 300
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2024 10:31 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Certainly, but with "vDrop test skillz", the effect could be compared the chassis ground BEFORE installation,
and then a feller would KNOW whether it's worth the effort.
Direct negative would be less maintenance I suppose, if routed smartly.
Hopefully NOT going one-step-backwards & connecting it to the FRONT of the gearbox.
I guy could test a jumpercable clamped from the battery neg to the starter mounting bolt and see if it cranks faster.
(or unclamp the connection and measure the volts across it).
And evaluate the tasks of chasing down all the drops
.vs
bypassing all of it with one direct cable.
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2024 10:40 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
Very definitely the alternator and the starter need high-current grounding.
The highest on the whole van.
But the gearbox has NO need for grounding because it has no electric machinery.
It can be damaged by electricity and logically should be isolated from any electricity.
But that's difficult to do.
And it's works well for the first 20 years.
VW knows this, why do you think they put two wires to the reverse switch instead of "grounding it to the gearbox"?
VW has "their designs....." I can assure you (like the lifetime fluids thing).
Best to try to isolate the gearbox from electricity (if you're an antiquer) especially if the gearbox is stored outside in a wet environment.
Remove (but relocate) that forward ground like a bad memory.
Think of it making the pile of magnetic black mud on the gearbox magnet from of your bearing surfaces
as the gearbox path degraded over time (years 20-35?).
If you feel better having TWO starter grounds, add a backup ground to the OTHER starter mount bolt.
Or oversize your new (added) alternator ground to perform starter ground duty.
You cannot really isolate it, but it costs only $15 each to put the best grounds you can
from each large electrical machine
that is capable of putting the gearbox at risk of electrical damage.
I've seen people (and members) spend 6-8 times $15 .... $9-120 just on on one oil change !
....pursuing a fraction of the benefit.
MarkWard
MarkWard is offline
PostPosted: Tue Oct 22, 2024 10:46 am    Post subject: Re: 90 Amps load test at alternator post Reply with quote
I would have agreed about the chassis not being the resistance in the ground circuit, but I did the starter voltage drop test a few different ways. Same results.
In fact, I honestly did not think it would start. The only way it would start was if a jumper cable was connected from the battery negative post and the engine case. Easiest access. Once it started you could remove the jumper cable.
Anyhow, I don't have these issues with our van. The battery is where it should be, next to the starter and alternator. Battery is grounded right to the block and the alternator has an additional ground added. Wink
Also, how is it 40 year old spot welds can't be the problem, but somehow grounding the engine using a transmission case bolt causes the current to flow through oily bearing surfaces easier? Asking for a friend. Wink
Page 2 of 4
