Robert's 1971 411 restoration project!
Aztecducky
Aztecducky is offline
PostPosted: Mon Aug 12, 2024 6:56 am    Post subject: Robert's 1971 411 restoration project! Reply with quote
Hello everyone!
I've always liked aircoolers, but never owned one until a few weeks ago. I picked up this 1971 411 wagon from a friend. It has been sitting in a field in Texas since 1987 or 1988. I have started to dig into the car and get replacement parts. The body is in great shape, the front fascia and the front of the spare tire well has some perforating rust but not too bad. The floorboard where the battery goes under the driver's seat is gone, but the rest of the car (and chassis) is solid. Suspension moves freely, shocks are in working order and pass a jounce test with flying colors. To my surprise, the wheels and brakes were not seized and the vehicle rolled freely on and off my trailer. There are tons of issues with the car, mainly the entire interior upholstery.
I will be manual swapping this car, and have already purchased the pedals, clutch master cylinder, and the elusive 004 transmission itself. I am still in need of the rest of the parts, mainly shifter, shift linkages, and related parts. I have a member now looking through his collection for a complete 210mm clutch kit and flywheel.
I have started to dig into the car, changing fluids, window seals, etc. The 3 speed transmission looked surprisingly beautiful inside, and the fluid was used but not too dark. I have removed the injectors to test them, and 3 of the 4 seem to be operating properly. The 4th does not click when power is appli!ed, but the resistance seems to be close to the other 3. I am hoping that cleaning it out with gasoline will free it up! I would like to retain the EFI, but if all of the parts need to be replaced, I'm most likely going to go with a carburetor conversion as some of the parts are incredibly expensive. The fuel tank will be removed soon and brought to a local shop to be cleaned out and re-sealed. The engine might need a complete rebuild, but I will be trying to get it running as is just to see if I can. If it needs a rebuild, I am not sure if I should rebuild it as a stock 1.7, or build a hot rodded engine or something along the lines of a 1.8 or 2.0. Any input is appreciated!
Moving on to the interior, I have already picked up a lot of parts fron the fine folk here at The Samba, as well as the go-to websites like CIP1 and WCM. I have not found any source for seat upholstery, and will most likely have a local upholstery shop rebuild the seats for me. The dash needs to be repaired or replaced pretty badly, it needs a new steering wheel (I'd like to keep it OEM or OEM style.) It needs all of the interior panels (hatch panels, door panels, rear seat side panels, etc.) as the main structures are curling up and are not reusable. Are there any sources for the panels, or am I going to have to cut them out of OSB myself and cover them with vinyl? Is there a source for pre-formed heat seam vinyl, or am I better off sewing patterns into the vinyl before attaching them to the backing? I am also in need of the rubber pieces that hold the metal panel clips in place as they are turning to dust, as well as the hatch hinge beauty covers for the same reason.
Any pictures of intact/original/restored 411 interiors would be greatly appreciated and a huge help in this restoration project! I will be posting pictures of my progress here. This car is a fun project for me and will be a keeper so I'm not too concerned with the value vs money in.
Thank you all, I'm looking forward to the great advice I'm sure I'll get here!
raygreenwood
raygreenwood is offline
PostPosted: Mon Aug 12, 2024 11:54 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Congrats!
I will help all I can!
I need to tell you this now though, while the suspension moves freely (pretty common)....there will be nothing that is driveable on it. Trust me.
Hopefully the ball joints are not rusted. Those can be saved if we can find boots for them. They are unobtanium except for NOS. There will besome bushing work to be done and we have solutions for struts and shocks. Tie rods are available. You can rebuild the centerlink in about 2 hours with about $30 in parts. I have a how-to in this forum for that.
You will need new strut bushings and also get rid of the bonded rubber centerlink bushing and install a solid bronze one. Same price and available new.
The brakes are not hard to do. Rebuild the clutch master cylinder while you can. Rebuild the calipers. Kits are available at PMB performance and they have the caliper half seals in their kits.
Right now, today, I am finishing up the details to rebuild about five type 4 master cylinders. These will be "forever cylinders"....nickel plated bores back to factory size and coated with master series silver on the outside.
I am also doing 3-4 clutch master cylinders the same way and about 8 clutch slaves for the late 44.5mm slave size.
DO NOT...have the tank sealed on the inside. Have it boiled out and treat it with phosphoric acid and its far better.
That will be a cool car eventually...hopefully. Ray
Aztecducky
PostPosted: Mon Aug 12, 2024 6:32 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
raygreenwood wrote:
Congrats!
Ray, I really really appreciate all the good info! I have purchased every part that is available new for the brakes, and plan on rebuilding the calipers as I have purchased those caliper rebuild kits! Master cylinder will need rebuilt I'm sure, or if you are selling one of your "forever" master cylinders I would definitely be interested. I just received today the brand new clutch master cylinder. It is still wrapped in the factory wax paper and appears to have never been unsealed. It feels great and the rubber bellows are in fantastic shape.
I'd definitely be interested in a full suspension refresh, I hate when my cars have sloppy suspension bushings. Do you have write ups on here for all of these fixes? Bushing replacements, shock replacements, etc.? Is revitalizing the fuel tank a DIY project or should I take it to a professional? It doesn't look that bad inside from what I can see, there is some rust at the bottom but mostly what I see is still coated/painted and not rusty.
The ball joints appear to be in great shape, I am currently finding, buying, and replacing every rubber component that I can, so I will definitely get some new boots for them. I plan on purchasing some more window seals from WCM and chopping them up to do the side window seals as well.
I have started to look into the electrical system before hooking up a battery, and have ordered a good condition used fuse/relay block as mine is TOAST. I have also replaced the ignition lock cylinder and the ignition switch as the car came with no keys and I read that the switch falls apart due to time, which mine had done. I believe I found the reason why it was parked, the starter solenoid is missing and all the wires that hook up to it are dangling. The starter has one nut missing on the bottom, but the top bolt is still bolted down tight. I believe the previous previous owner got frustrated not being able to get to the upper starter bolt and gave up on the car, as everything else is still on the car and appeared to be in working order before it was left to the elements.
Any tips on what to keep vs what to get rid of? Such as the gasoline heater, EFI system, etc?
Here are a few interior pics. I know it's super crispy, but I'm not concerned with upholstery as that can all be re-done. The seats actually move freely after lubricating them, and it appears that the heater channels are free as well. Do you have any sources for the fuel door cable? It snapped where it retains the fuel door. I also need to figure out what the hood release lever inside the glovebox is supposed to be screwed into as the back screw and quick nut are there, but not actually attached to anything.
I will continue to update this thread as I make more progress on the car and when I have any more questions.
oprn
oprn is online now
PostPosted: Tue Aug 13, 2024 6:48 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Mine is the same color but older and... sorry to say for your sake... not nearly as rough inside. It was running a few years back so I am confident it will run again. Someone smashed the right door glass and 1/4 glass out though. Seat belts are all missing too.
Aztecducky
PostPosted: Sun Sep 22, 2024 11:47 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
So it's finally cooled down some here in Texas (only been in the mid 90s all week) and I've make some good progress on my 411!!
First off, I cleaned everything up. Vacuumed the carpets, seats, engine bay, etc.
I ordered a ton of parts, everything I could find that the car needed, and bought a lot of small parts from my local aircooled place (matched up with pictures or bringing the old, broken parts in). I also ordered new wheels and tires.
I got underneath the car and it seems like I figured out why the previous owner parked it 36-37 years ago: the starter was almost off. The solenoid was missing, all the wires were dangling, and the lower nut was removed. I assume they couldn't figure out how to remove the upper bolt (I couldn't either, but figured it out thanks to the 3 shop manuals I bought). I ordered a new starter to replace it.
While waiting for the new starter, I got to work on the rear brakes. I replaced every component inside the drum, and put them back together. I removed one of the headlights to get the hood open as the cable was broken. Finally getting it open, some things were in surprisingly good shape. Unfortunately the hood is rotted out where the latch bolts to it, so I will need a new hood. I removed the front calipers and will be rebuilding them in the next few days.
Then I did a transmission service. To my surprise, the automatic transmission didn't seem to be leaking, and the inside of the transmission was beautiful! The transmission fluid was a nice reddish brown, nothing concerning at all.
I got the rear windows seal from West Coast Metric and replaced it. I have since ordered the front window seal, and a rear window seal for a 71-ish Beetle to see if I can make that work to seal the side windows.
I replaced the entire ignition system, and fogged the engine with some Sta-Bil fogger. Unfortunately, the rear (front? Its closest to the back bumper) left cylinder looks like the valve was left open as it looked pretty rusty inside. That's a problem for later me.
I pulled the injectors, and found that 3 of the 4 were functioning as intended when powered up. They pass air through them when energized and are sealed when they are at rest. I soaked the end of the other injector in gasoline, but it seems to still be stuck. The resistance figure is consistent with the other 3 injectors (3.8-4.3 ohms). Anything else I should try before I buy a new injector?
I then started to get the car's electrical system repaired as best as I could. Fortunately, most of it was still there and unaltered. I replaced the fuse box and all the relays and fuses on it. Using the wiring diagram, I made sure every wire was in its proper place. I replaced all the exterior bulbs save for the headlights. I have 3 relays in the fuse box, but there are two more slots with wiring going to them. I am not sure if there is another relay I am missing, I believe the door buzzer fills one of those slots.
After triple checking all the wiring, it was time to give the car battery power for the first time since 1987 or 1988!
I replaced the ground cable, put the battery on the ground under the floorboard where it should be, and hooked the terminals up. This hole will be repaired of course. Turning the key, I started checking everything I could. The headlights, taillights, and marker lights work! The hazard switch lights up, but the hazards and turn signals flash very strangely, extremely quickly (way faster than your typical "bulb out" flash) or sometimes not at all. I suspect that the used flasher relay I put in is bad. The wipers work, on both speeds too! The interior lights flicker when turning the dimmer switch, but don't light up strongly. I suspect the dimmer switch is bad. Turning on the blower motor/heater (not the gas heater), the switch lights up but the blower motor does not turn or make any noise. The high beam switch and turn signal switch both function. The turn signal indicator on the instrument cluster does light up, as well as the generator light.
Turning the key to the start position, nothing happened. I took off the shifter bezel and found that the metal piece that is supposed to contact the neutral safety switch was not springing out. I checked the resistances, and bypassed the switch to get power to the starter. Unfortunately, the starter clunked but did not turn the engine over. It is completely locked up, not surprising though due to the time it had been sitting outside in a field. I'm going to soak the cylinders in ATF and try again in a few days. If that doesn't fix it, I'll pull the engine and rebuild it!
I am currently on the hunt for the rest of the parts to manual swap this car. I have the pedals, clutch master cylinder, and the 004 transmission. I purchased a 210mm clutch disc, pressure plate, and flywheel but unfortunately the clutch disc has the larger, standard aircooled splines and not the 004 size splines. I need the shifter assembly and all linkages as well as a proper sized clutch setup and flywheel.
Thanks for checking out my project!
raygreenwood
PostPosted: Thu Sep 26, 2024 9:31 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Good work! Thanks for saving another one. Ask questions if you need to and we will help all we can!
Ray
Aztecducky
PostPosted: Thu Oct 24, 2024 2:43 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Ray
So I have started working on dealing with the engine. I have it soaking in a 50/50 mix of acetone and ATF to remove the rust. So far, it's looking pretty good! Is there an easy way to bar the engine over manually, or is the best spot going underneath using the starter teeth? The rust is being knocked off surprisingly well by the mixture and the pistons and cylinders definitely look serviceable.
3 of the 4 injectors function, and I purchased a 4th to complete the set. Once I get the engine turning over, I need to check function of the rest of fuel system. It will be getting all new rubber lines and clamps to prevent fuel leaks.
When I jacked up the driver's front corner, I noticed a TON of play in the ball joint. The passenger side front ball joint has zero play. I managed to find some NOS ball joints for the car and will be installing them soon. They're the fully cast style which don't have the nuts welded in place, instead the entire body is threaded. They are made by MOOG and the boxes are stamped 1986, part number K 9037.
I managed to find a complete factory/dealership manual set on ebay and it has helped me out a ton with this car. Where can I find a PDF (or physical copy) of a parts book? There are so many interior and other parts that I need to replace and knowing the part numbers for these would make everything so much easier!!
Thanks again!
Aztecducky
PostPosted: Thu Oct 24, 2024 5:25 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
So, a little update on these ball joints. I have removed them from the package to inspect the condition and make sure they're correct. The seller on ebay did list them as fitting my 411. I haven't installed them yet, but the shape and size look correct for a Type 4.
The rubber boots are in remarkably good shape, even when pulling at the extra part sticking up out of the retaining rings with my fingernail I couldn't get it to peel, crack, or tear. The ball joints are MOOG part number K9037. The other box did not have the rest of the label torn off, and there are no numbers after that, I just happened to get a picture of the torn label instead of the intact one. I have not been able to find them in any online MOOG parts catalogs, not even the vintage ones available for download. The box says "same as KF 45" and "Made in Germany"
The box is dated 1986:
Now for the very strange part. In both of the boxes there was this tag, which appears to have some sort of adhesive on the back. It seems like an OEM VW parts box label, complete with the part number of the ball joints themselves and "1 Gelenk" which is German for "1 Joint".
I am not sure if MOOG was an OEM for VW at one point, or if they got these from VW's OEM manufacturer and re-boxed them as their own (I'm leaning towards the latter). Here's the tag:
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Fri Oct 25, 2024 2:47 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Wow. You really have your work cut out for you.
raygreenwood
PostPosted: Fri Oct 25, 2024 5:46 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Sorry for the delay in answering.
Yes, those are correct for vw 411 and 412. I have never seen one in a MOOG box. That does not mean that they were actually produced by Moog. That symbol on the rubber boot between the numbers is a manufacturers trade mark and I cannot for the life of me remember who they were. Oh.....wait....I believe that is an "Ocap" logo. An Italian company that made OEM ball joints and tie rod ends.
But.....you need to show us two more pictures please. Look on the inside of the back of the joint. Is it completely cast iron or is there a swaged on steel cap?
The steel cap versions which had a spring inside similar to many other ball joints and tie rod ends ....was likely made by Ocap. The later all cast parts....I believe....were made by TRW.....and TRW is owned by Moog (Federal Mogul).
If your joint is fully cast....with no cap inside and I believe it is....the boot having an Ocap logo simply means they are all using the same boot which they do and are just using Ocap boots.
So.....we also need you to unscrew the nut and take a picture of the end of the threaded stud. From the part #, you should see a small dimple on the end with a line intersecting it.
The part # you have....if that piece of paper is correct....411 412 165 E...means that they are special "eccentric" ball joints used for correcting the castor angle on the car. The normal part # is 411 412 165 C.
They will work just fine but you need to put a wrench on the end and orient the engraved line to straight forward for 0 additional castor.
But....these are a very good thing to have. The 411 and 412 are notorious for having n9t enough castor from the factory. The lower subframe has an adjusting feature to allow you to equalize the existing castor between left and right sides but it does not give you any extra castor. These joints should give you somewhere around an extra degree.
Other things you need to do. I learned long ago why these ball joints have a built in hole in one side (inner side). It's a weep hole because water leaks between the joints where the strut tube is bolted to the steering knuckle above it. It causes massive rust in the long run....insuring you will need a prybar and 5 lbs hammer to take things apart.
So....I have been putting gaskets between strut and steering knuckle and steering knuckle and ball joint. When you are ready I will explain the simple way to do this.
Once that space in the back of the balljoint is sealed.....put a grease fitting in it. Then drill a 1/8" hole dead center in the back of the joint inside of that cavity. So once it's bolted together and sealed up you can pump the joint full of grease so it will last pretty much forever. You need to do this because these joints are rare.
I will post pictures of how the eccentric joints work in the am.
Ray
raygreenwood
PostPosted: Sun Oct 27, 2024 11:52 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
I almost forgot I did this thread.
There is a ton of ball joint tech in this thread and also some aftermarket boot part #'s and also part of what you need to know to make these joints "greasable"...and details of the eccentric adjustment joints like your part # says you have.
https://www.thesamba.com/vw/forum/viewtopic.php?t=635836&highlight
By the way....6 years down the line...those aftermarket ball joint boots I bought from Howe racing, while staying installed on the joints, in my garage and out of sunlight and weather except for freezing cold....rotted away.
Yes, its probably because they are neoprene instead of voton but also its most probably the grease that was in it.
also by the way and I had completely forgotten before I went back through that thread...that symbol that looked to me to suggest "Ocap" in Italy...is actually the logo for ECO which is Ehrenreich ...which is TRW.
Ray
Aztecducky
PostPosted: Sun Oct 27, 2024 7:08 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Hello Ray,
I really appreciate the knowledge. I'm assuming installing the gasket just involves cutting one out yourself, which i have done on many projects in the past. Should the gasket material be rubber?
The ball joints are fully cast, even on the bottom. There is also a dimple/line on the top for caster alignment indication. I remember seeing your thread about the ball joints a month ago or so. Good information there! I will definitely be installing grease zerks and drilling a hole in the bottom to keep them greased properly.
I wonder why there were what appears to be OEM labels in the boxes with the ball joints.
Aztecducky
PostPosted: Sun Oct 27, 2024 7:16 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
For sure, but I view it as a fun challenge. Rear brakes are ready. Front calipers are off and I will be rebuilding them soon. Master cylinder will be rebuilding using Ray's fantastic how-to and a Type 3 dual system master cylinder rebuild kit. Electrical is mostly finished, besides EFI stuff since the motor is locked up still. Hopefully it will break free tomorrow, it's starting to become very clean on the inside now.
Next will be a test of the ignition system. It has all new parts but with it locked up, I can't set the points gap properly. I approximated it for the time being. My fuel pump isn't pumping, and I still need to get the fuel tank cleaned out, which I now know involves dropping the entire front subframe out of the car. I may just run multiple clear fuel filters in a row until it clears up, the tank is not very rusty at all, just a bit of surface rust in the bottom 1.5" or so. The rest of the tank is still nice and clean.
VWNOS.com
PostPosted: Sun Oct 27, 2024 8:11 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
You can run through fuel filters quite quickly if you have anything in the tank including rust. I had a similar situation with a Beetle of mine. It was a new tank that sat in the car for years empty while restoring it. I ended up replacing the tank as the filters kept clogging rather quickly.
raygreenwood
PostPosted: Sun Oct 27, 2024 9:52 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Aztecducky wrote:
Hello Ray,
The gaskets work really well but you need to use gasket paper that is as thin and hard as you can get it. I can give you a part # that NAPA readily carrikes for 1/32", fuel proof gasket paper.
But hold off....give me a day and I can show you a better way than gaskets.
At one point in time I used RTV to seal with the object is that most RTV is too soft to resist the greasing pressure and you tyoically get it on too quick. The surfaces of the top and bottom of the steering knuckle are machined very precisely. The ball joitn flange is a little less so. With about 2 minutes of lapping the joint on a flat surface (I use glass) with 600-800 grit paper to make ure you have no big grooves is all it takes.
Then coat the face of the ball joint flange and top and bottom of the steering knuckle with a thin coat of Motoseal or Yamabond and let them dry. Then give them another coat and let them dry.
Since they are ~65% solvent, this gives you about 0.0015" to 0.002" maximum thhickness for sealing and that is all it takes.
The problem with using gaskets I have found is that they have to be thin and hard or the bolt tension after a while flattens the gasket out and the bolts get loose.
Ray
Pepperbilly
Pepperbilly is offline
PostPosted: Wed Oct 30, 2024 11:53 am    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
I wish you all the best in this very ambitious project. I restored my mom's 412 wagon "Goldie" and it has turned out really nice.
You really have to place close attention to your fuel system. I pulled the gas tank and completely cleaned it inside and out. I did not have any rust really but residue from old gas lined the inside from sitting with a half a tank for over 20 years. The goal is to get it as immaculate inside as possible.
I tried to save my old fuel injectors by having them cleaned and flow tested. Problem was when I thought I had everything really clean I still had residue/contamination and plugged my injectors. This was even after a couple of filter changes. You can see in one of my threads the photo of a filter I cut apart. Very fine residue still existed. I had to take the top off the fuel tank to search for the additional contamination. I certainly found a fine silty layer at the tank bottom. I had to drain the tank again and suck this stuff out with a vacuum suction on a shop vac.
I went ahead and purchased new SMP injectors from Rock Auto. I wanted to stick with original types but made the decision to go with the SMPs after reading favorable reviews. I am glad I did. These injectors work so nicely and they are new. I feel you are taking a big risk with the old Bosch. They are old and the bodies can potentially leak gas.
As a precaution I have changed out my fuel filter a few times in the 1st 1000 miles. Gives me peace of mind. Hope this helps.
Bill
Aztecducky
PostPosted: Mon Nov 11, 2024 6:09 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Bill, thank you!! I really appreciate the insight. I will definitely be thoroughly cleaning the tank out and replacing all the fuel lines. I will pay very close attention to the injectors themselves and ensure they are not leaking fuel. I'm hoping to have the car running and driving by the end of this year. We will see how that goes!
To drop the fuel tank, the front subframe needs to be removed correct?
Pepperbilly
PostPosted: Mon Nov 11, 2024 8:19 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Yes, you do have to drop the subframe. You also have to disconnect the filler hose which involves removing the black metal plugs that are under the frunk carpeting. Maybe you can start by taking the fuel sending unit out and looking into the tank to assess the condition.
Bill
raygreenwood
PostPosted: Tue Nov 12, 2024 1:50 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Bill
Yes, as Pepperbilly notes....you have to remove the subframe.
I want to inform you of a couple of items. In the process of removing the subframe to get the fuel tank out....which is not that hard of a job really....there are a few things you will have to take loose.
Most of these items REALLY need to be refurbished anyway and with a few of them, it can slightly mess them up anyway primarily because of their age and miles and rust and weathering.
So it starts like this:
Put chocks behind the rear wheels, jack the front hweels up about 4" off the ground with wheels on. Put jack stands underneath those little dome shaped things at the rear of each fender.
Remove the front wheels. Remove your fuel pump, fuel filter, lines and the damper to get them out of the way
1. Remove the steering gear, meaning tie rods and centerlink. Getting new correct inner, bent 9* tie rod ends can be a chore so lets leave the inner tie rod ends attached to the center link for now.
We will remove the outer tie rod ends from the steering knuckle on each side. To do this, get a tie rod "pickle fork" and remove the nuts from the outer tie rod ends at the steering knuckle.
BEFORE YOU DO THIS....make sure your car is where you need it to be for the whole work process and jacked up with the wheels removed.
Pop the outer tie rod ends out of the steering knuckles.
2. On the passenger side you can do one of two things. Either remove the three bolts from the outer firewall side that hold the idler arm brackt to the chassis and just leave it connected to the centerlink. To do this, take the nut off of the bolt that holds the arm onto the bracket and let the arm drop off. If the big bolt just spins.....there is a trick to getting this loose that I will straighten out for you later. If that happens, for now, take the whole bracket off.
On the steering box side, lets leave that in the car for the moment. Take a pickle fork and 3 lb hand sledge hammer and take the center tie rod loose from the pitman arm.
3. since you have the ball joints off, you "can" just leave the struts attached to their mount in the chassis. If you already have them out along with the steering knuckle thats even better.
Since you need to remove the the outer tierod ends from the steering knuckle, one of the best ways to keep this altogether for the moment is to re-install your new or old ball joints underneath the steering knuckle and strut and if the old ball joints have already been popped out of the control arms....just remove the top three nuts on each strut with the steering knuckle, ball yoints and struts still together as a unit....support them with a jack underneath the ball joint (NOT under the rotor).
Disconnect the brake lines from the calipers and just leave the calipers attached to the steering knuckle. When the three top nuts are removed, lower the whol strut unit down and pull it out.
Now you are down to the subframe with the controll arms still attached. The subframe weight maybe 20 lbs. The control arms are about 15- 20 lbs each.....not too heavy.
VERY IMPORTANT PART:
Your subframe has three large vertical bolts holding it on. You car also has a good amount of rust???
Its common that these three bolts are rusted a bit....you MUST NOT seize them or strip them.
These three bolts are screwing into a "T" shaped not in a slot inside of the body. Its a captive nut. This is what allows moving the subframe around for alignment. The chances are very high that one or both of the outer bolts will seize up. Thats bad. Not unfixable...but bad.
So.....look at this picture....This is my car with the suspension and fuel tank out for undercoating.
The three red circles show what the three bolts are screwing into. I wish I had known what I am about to tell you about 30 years ago when I screwed one of these up.
See the green arrow pointing to a green dot? There is a chamber underneath that spot where the bolt goes up into. You want to drill a 3/16" hole right where that green dot is on each side of the car.
Also in the rear where the third bolt is...drill a 3/16" hole there as well.
Being careful with no fuel around, take a propane torch and heat all three bolts to maybe 400-500 F. Not too hot. Keep an extinguisher handy in case undercoating starts to burn. Then...take a good quality penetrating oil like PB blaster or 50/50 ATF and acetone....and sprya it into the three holes you drilled. Just flood everything.
Then take your 3 lb sledge hammebr and whack all three bolts several times hard. Let it sit overnight. Then take a breaker bar and try to loosen these three bolts. If it takes more than about 60-70 lbs...whack them again and spray more penetrating oil in.
Personally, I crack them open so they move about 1-3 turns .if they get tight...spray in the PB blaster and then tighten them back down ...whack on them....and try it again, Repeat until they come out.
Later....you can plug the three holes with button head screws. I said 3/16" so you can keep them small enough to tap for 6mm screws.
On the other hand if you screw one of these up.....you will know it. If it jams up it will twist the T-nut out of the chassis and the bolt cannot be removed by any means.
In this case, that 3/16" hole will be the pilot hole to use a 1.25" holesaw to open a hole from the outside. You can grasp the T-nut with pliers or jam it tight with a breaker bar while you unscrew the bolt. Then....remove the T-nut and put in a flange hex nut. The holesaw holeshould be big enough for a wrench to reach through.
Hopefully you will not need this fix like I did on my 411 wagon. I sawed the bolt head odd underneath and pulled the whole bolt shaft and T-nut out through the hole I cut.
When you get the subframe off....come back and talk to us.
As Pepperbilly noted, pull the carpet away. up on the deck. You will remove all of the black covers. The two big round ones cover fuel vent lines and the wire for the sending unit. You can take tehsending unit out now or just pull the wire for now. The small oval one covers the locking tab and bolt that holds the tank in.
There are...IIRC...four 10mm studs with nuts down on the bottom corner of the tank. Rmove all of this and take the fuel hose loose...and the tank should come out toward the right side because you left thesteering box in place.
Ray
Aztecducky
PostPosted: Thu Nov 21, 2024 11:42 pm    Post subject: Re: Robert's 1971 411 restoration project! Reply with quote
Ray,
I really appreciate the detailed write up. I've had some experience repairing/replacing captive nuts that were broken loose on my 1998 Forester. I was installing a lift kit and two of the subframe bolts broke their captive nuts free. That car spent the first 150k miles of its life in New Jersey so it had some bad rust. The 411 seems to only have surface rust save for the floorboards, everything I've done so far has been very easy fortunately. I will be careful with those subframe bolts. That picture with it removed helps a lot, now I know what I'm up against and that I need to be careful.
I will be trying to tackle this job and getting the engine free this weekend. I will keep this thread updated!
