Air Duct Seals?
foil
foil is offline
PostPosted: Fri Nov 01, 2024 10:33 am    Post subject: Air Duct Seals? Reply with quote
I removed my air ducts from the front of my 1972 Bus, doesn't look like the seals are made for this anymore. So what are you guys using as a replacement?
dodger tom Premium Member
dodger tom is offline
PostPosted: Fri Nov 01, 2024 10:45 am    Post subject: Re: Air Duct Seals? Reply with quote
you mean these?
https://www.thesamba.com/vw/forum/viewtopic.php?t=683092
Wildthings
Wildthings is offline
PostPosted: Fri Nov 01, 2024 1:48 pm    Post subject: Re: Air Duct Seals? Reply with quote
Lots of ducts and seals on these old rig, so you need to be more specific.
foil
foil is offline
PostPosted: Fri Nov 01, 2024 3:45 pm    Post subject: Re: Air Duct Seals? Reply with quote
I've tired to upload pics, I hate the way you have to upload these photos. I can't find the pics I've tired to upload.
They are the metal halves on the intake box. They attach to the front of the bus that goes to the doors some people cap them and some run the door ducts to the back of the bus. These are the ones in front of the door and the air tubes also attach to the them on the top.
busdaddy
busdaddy is offline
PostPosted: Fri Nov 01, 2024 4:12 pm    Post subject: Re: Air Duct Seals? Reply with quote
These?: https://www.thesamba.com/vw/classifieds/detail.php?id=2711409
Слава Україні!
foil
foil is offline
PostPosted: Thu Jun 19, 2025 1:30 am    Post subject: Re: Air Duct Seals? Reply with quote
yes, Busdaddy those are the ones. I tried to buy some marine seals from lowes but that didn't work too well.[/quote]
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jun 19, 2025 7:19 am    Post subject: Re: Air Duct Seals? Reply with quote
make your own from a thin sheet of foam or buy used ones from someone like TheBusco.
kreemoweet
kreemoweet is offline
PostPosted: Thu Jun 19, 2025 7:29 am    Post subject: Re: Air Duct Seals? Reply with quote
The seals are just thin strips of foam, exactly like common door/window seals sold at any hardware store. You just cut into pieces to fit and stick 'em on.
'67 bug: seized by the authorities
