2type2 Samba Member
Joined: June 02, 2002 Posts: 1211 Location: SW Colorado
Posted: Thu Nov 07, 2024 9:48 am Post subject: BGW Beast Gone Wild Sedan Delivery. |
What a beaut, huh?!. Something to keep me busy this winter. I have always wanted a sedan delivery and this mimics a '40 Ford .Crusty interior, crusty exterior, but seems mechanically solid. More cosmetic than mechanical issues.
A few surprises left by the PO's, PO. Had been stored indoors 8 yrs then left outdoors 2 more plus. All rubber fuel line-- front to back- and it had a hot wire from battery to front accessory beams that was zip tied directly to it full length. Rat nest in tunnel, huge hole in tunnel, although functional -the directional arm is installed backward on right side. Overall a fair deal on a decent car. Hope to be ready to cruise by April.
_________________ "A life of peace and happiness depends on your own gratefulness" |
Ulu Samba Member
Posted: Thu Nov 07, 2024 12:49 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
That looks like a lot of fun.
How much is fiberglass? _________________ SS100 kit kar
1600cc DP |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3030 Location: HdG, MD & NJ
Posted: Thu Nov 07, 2024 2:10 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
I always thought those hoods looked cool, but went up hill. I would take a slice out.
Hopefully you’ll be cruising in the spring time! _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
EVfun  Samba Member
Posted: Thu Nov 07, 2024 3:44 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
That is a VERY cool project. I think a set of Rossi headlights would really work for the ‘40 Ford look. It appears to have been very well built originally. I’m looking forward to updates as you pull it back together.  _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
2type2 Samba Member
Posted: Thu Nov 07, 2024 4:13 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Appears-- to be. Whoever decided to begin this conversion never got to finish. While fully drivable, the engine is left exposed in the cabin! A bit too hot , noisy and smelly.Need to fabricate a "shelf and lifting door" to separate area from air cleaner down.No interior, need to replace og seats. Cheaper to retrofit seats than fix these. _________________ "A life of peace and happiness depends on your own gratefulness" |
Busstom Samba Member
Joined: November 23, 2014 Posts: 4585 Location: San Jose, CA
Posted: Thu Nov 07, 2024 10:57 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Is that the one that was in the classifieds here for a while?
If so, it looked like a fun tempting project, but I need another project like you-know-what.
The sky's the limit with that thing, first would be to separate the engine compartment from the cabin. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
| cory464 wrote: |
| if you aren't perfectly centered in the hole you will have issues when you tap it. |
oprn Samba Member
Joined: November 13, 2016 Posts: 15223 Location: Western Canada
Posted: Fri Nov 08, 2024 5:57 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
That is an awesome car! I always loved the ‘40 Ford hoods for the Beetle! _________________ Our cars get old, we get old but driving an old VW never gets old! |
texastomeh Samba Member
Joined: November 20, 2018 Posts: 305 Location: Dallas, TX
Posted: Fri Nov 08, 2024 11:52 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
COOOOOOL!!!
I like it!!!
Keep us post with LOTS of pictures!!
GOOD LUCK!! _________________ A new engine build won't solve ALL of life's problems - only those THAT REALLY MATTER!!!
GETTING old was GREAT - BEING old SUCKS!!
Too bad that the guys that know how to solve all of the WORLD's problems are too busy working on old Volkswagens!! |
2type2 Samba Member
Posted: Thu Nov 14, 2024 2:15 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Mismatched front fenders,ugh! Hoping to swap one to match the other to avoid buying two. Just want a match, not fussy. Not sure on id after searching pics. Notable differences in signal hole size, curvature , spaces from bottom of horn grill to bottom lip. Any ideas as on years? Holes below horn grills are n
ot always present? _________________ "A life of peace and happiness depends on your own gratefulness" |
finster Samba Member
Joined: May 26, 2012 Posts: 10542 Location: not far from the madding crowd
Posted: Sun Nov 17, 2024 8:00 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
| Ulu wrote: |
How much is fiberglass? |
this photo should answer your question:-
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
2type2 Samba Member
Posted: Sat Jan 11, 2025 4:45 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Been working on this beast, finally de-crusted and de-rusted, ready for real body work. Got a nice set up to block engine off but losing 4 upper vent straps in rear door due to lowering of engine box top.
Open to ideas, thinking I will need more air input via side vents or scoops near fenders. Late bay side vents molded in perhaps?
Posted: Mon Jan 13, 2025 10:30 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
in the uk these were sold by wizard who also made the roadster. they are mostly seen with a solid rear door so I suspect the advice was to cut circular holes in the inner fender for air like the speedster used.
but a bay bus vent could look good fitted above the waistline and ducted down inside... _________________ "we're here on Earth to fart around" kurt vonnegut
2type2 Samba Member
Posted: Mon Jan 13, 2025 1:09 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Gallery has a few pics of a bgw sd with late bay vents (user names is - Coughlin. Old post .My headache would be sourcing the chunks, not installing them Holes in well seems would put too much dirt/dust into engine bay. _________________ "A life of peace and happiness depends on your own gratefulness" |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3232 Location: Downingtown, PA
Posted: Mon Jan 13, 2025 2:33 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
| Are you going to run full tins with the bottom sealed? If no, don't worry too much about extra air getting in - plenty will. If yes, holes in the inner fender wells as suggested (covered with a screen, of course), or NACA ducts low on the fenders in front of the wheel well, ducted to the engine compartment. |
2type2 Samba Member
Posted: Mon Jan 13, 2025 3:21 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
NACA! Now we are getting into technical aeronautics. I may just fab some scoop thingies out of fiberglass, but it would be nice to have something period looking, somehow. Or making it looking like it had to be there. _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Tue Jan 14, 2025 3:49 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
here's how beutler did it in the 50s
GreeneHoosier Samba Member
Joined: August 16, 2004 Posts: 413 Location: Southern Indiana
Posted: Tue Jan 14, 2025 5:42 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
I have loved these since I was a kid in the 70's and 80's. Very cool. Good luck! _________________ 1974 Super Beetle
40 Years VW enthusiast! |
2type2 Samba Member
Posted: Tue Jan 21, 2025 4:48 pm Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Off comes this wondrous hand made oak dash cover.A PO had a fun time hacking the dash to fit a big screen TV or maybe a boom box? I've welded and putted it all back. Now the problem is that the fuel guage glass and cover was held on by the wood cover and a funky bent clip.
So do I need just an outside trim square to bend over it, or what piece? _________________ "A life of peace and happiness depends on your own gratefulness" |
2type2 Samba Member
Posted: Tue Feb 11, 2025 9:44 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Going through every system for my own sanity and safety. This is how PO left steering linkage. Since the tank has bad been replaced brand new, this should have been noticed. I've been working diligently on this beast, getting close to actual fish work on body and interior soon. So far all new brakes, metal line in tunnel, wiring fixes, built engine compartment,window regulator,clear intake preheat vlockage, clean/ paint/ check engine, new clutch, etc,etc.
I'm even gonna buy some castle nuts and proper bolts for this steering link.
oprn Samba Member
Posted: Wed Feb 12, 2025 4:25 am Post subject: Re: BGW Beast Gone Wild Sedan Delivery. |
Oh wow! We have all have seen some brain dead moves but this one is a real winner! _________________ Our cars get old, we get old but driving an old VW never gets old! |
