fridge replacement projects - post here
Page: Previous  1, 2, 3 ... 34, 35, 36, 37  Next
scotty timmerman
scotty timmerman is offline
PostPosted: Tue Sep 17, 2024 1:31 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Has anyone used this bodega RV refrigerator? The dimensions look like it would fit in the stock location.
https://www.amazon.com/BODEGA-%E3%80%90Upgraded%E3...amp;sr=8-1
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
grandfatherjim
grandfatherjim is offline
PostPosted: Tue Nov 26, 2024 7:06 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Somewhere, can’t find it, maybe not the Samba, there’s a thread where a guy was showing his cabinet work and there’s a Bodega in one of the pics. This got me looking into them and I wrote their “customer service” to see if I could find out typical power consumption vs. specified, which I assume to be worst case. Not surprisingly they couldn’t understand let alone answer my question but I did get out of them that the Eco mode consumes about 80% of the regular mode.
I’m talking about their 45L model here, which is rated at 60 watts. I wrote them because I thought this must be a cover your butt rating (seems high). Here is their response:
“The maximum power of this refrigerator is 60 W. The power of the refrigerator fluctuates, approximately between 55-60 W. This fluctuation is based on the ambient temperature and other factors. This fluctuation depends on other factors such as ambient temperature.”
I’d really like to find out what people’s real life experiences are.
Edit: I should add, yes indeed I’m looking for a lower cost fridge, but my bigger concern is power consumption. We run a CPAP now so I need to conserve power wherever possible everywhere else.
shagginwagon83 Premium Member
shagginwagon83 is offline
PostPosted: Tue Nov 26, 2024 8:17 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Corwyn wrote:
Vitrifrigo C50i. In like a glove! Perfect size, easy install. Super quiet. 3 hours after wiring it up, I have ice cubes! Very Happy
This is a great size. I am rocking the CFX3 55IM portable Dometic unit with about the same capacity. However, it is a pretty large unit to have in the middle of your living room.
Corwyn how was the install? Did you have to remove the whole galley or were you able to install in place.
Instagram: @joannthevan
Rorke
Rorke is offline
PostPosted: Wed Nov 27, 2024 8:22 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Corwyn and Brandon,
How does this unit compare sizewise to the TF49 and the TF65? Thanks
PostPosted: Wed Nov 27, 2024 9:12 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Vitrifrigo C50i:
- Height: 25 inches
- Width: 15.6 inches
- Depth: 13.6 inches (flush-mounted) or 15.2 inches otherwise
- Capacity: 50 liters
TruckFridge TF49:
- Height: 20.5 inches
- Width: 15 inches
- Depth: 17.5 inches
- Capacity: 49 liters
TruckFridge TF65:
- Height: 21 inches
- Width: 17.75 inches
- Depth: 18.5 inches
- Capacity: 65 liters
Summary:
- The Vitrifrigo C50i is taller but narrower and shallower than both TruckFridge models.
- It offers a similar capacity to the TF49 but with a different form factor.
jimf909
jimf909 is offline
PostPosted: Wed Nov 27, 2024 9:29 am    Post subject: Re: fridge replacement projects - post here Reply with quote
^^^ Interesting. This is similar to a normal depth house fridge compared to a cabinet-depth (about 6" shallower) fridge: a normal fridge is so deep that stuff gets lost in the back. I find it hard to get stuff out of the back of my VF51 (same as the TF49) and would appreciate a taller, shallower fridge. Maybe the VFC50i is the new best choice.
- Jim
Butcher wrote:
Guilty as charged.
Corwyn Premium Member
Corwyn is offline
PostPosted: Wed Nov 27, 2024 2:21 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
The fridge is a perfect fit.
1. Remove the entire cabinet fascia where the fridge was
2. Wire up the new fridge
3. Screw the frame to the fridge
4. Place the fridge in the cabinet
5. Screw the frame to the cabinet sides, securing it in the van.
The only destruction I did was to notch the cabinet edge on the left side all the way to the floor so the frame fit flush. I doesn't stick out like the TF does.
The compressor is on the bottom, outboard so it is really quiet. It draws a lot less than my ARB 50 did.
It is actually a 12/240v dorm fridge with feet.
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
Rorke
Rorke is offline
PostPosted: Thu Nov 28, 2024 10:16 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Thank you for the dimensions Brandon.
My older vitifrigo model (nearly identical to the TF49) sits so deep behind the stock fascia that it needed to be notched. Moreover, the fridge compressor needed tricky modification to route the city plumbing and new air compressor port.
When / if this dies, I intend to fit a TF65 behind the original fascia, which may be less work than my current set up.
- cabinet would need to be mounted two inches off the side to provide a deeper recess.
- Top and sides would need to be extended accordingly (I have the GW melamine already)
- The stock seam between the fridge side and cabinet/drawer side needs to move forward (to the right if looking at cabinet). This would be the “hinge” and the whole fridge door/new face would be the door cover.
- The door latch needs an appropriate solution. I don’t trust the magnetic seal alone.
MarkWard
MarkWard is offline
PostPosted: Fri Nov 29, 2024 3:30 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Recent install of a Dometic NRX 50C. The freezer is removable and you an add a shelf. I'm still deciding if I am happy with it. Uses about an amp an hour overall. It's quiet and it fit without cutting the stock cabinet. Top filler might become another drawer. My only complaint is condensation never clears up. I don't know how the moisture is getting in. Seal seems fine. Just may need to put some things in plastic bags that you'd prefer to keep dry.
https://www.dometic.com/en-us/outdoor/boat/boat-re...9620001829
metahacker
metahacker is offline
PostPosted: Tue Feb 04, 2025 10:58 am    Post subject: Re: fridge replacement projects - post here Reply with quote
has anyone tried swapping panels side-to-side like this guy?
kinda looks like he has a 65L fridge in there on the left, with the stock drawer on top, e.g. from moving the right side over to the left
then has the large factory fridge door moved over to the right for a bigger cabinet
seems pretty ideal (and very logical from a design perspective)?
albeit looks a tight fit.
can't say i love how the right cabinet interior is setup as-is ... but seems easily improved upon with a scandvik drain, a little more careful routing, and some interior shelving/drawers
metahacker
PostPosted: Tue Feb 04, 2025 11:09 am    Post subject: Re: fridge replacement projects - post here Reply with quote
check the wiring entry point for the interior light and/or temp control... it may need some help from butyl. i had to do a warranty claim on a fancy Vitrifrigo in my bay window because of that. luckily, the moisture only made it inside the light housing (which filled with water and fried the pcb) it was fine after sealing it up.
Oblio7
Oblio7 is offline
PostPosted: Mon Feb 10, 2025 4:44 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Bodega customer service sucks, they give me a a runaround about my warranty claim. Save your money and get something else.
scotty timmerman
PostPosted: Sat Mar 01, 2025 7:06 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Here is my bodega 45L install with a Propex hs2800.
73 super beetle
korfmach
korfmach is offline
PostPosted: Thu Mar 13, 2025 8:32 am    Post subject: Re: fridge replacement projects - post here Reply with quote
I pulled the trigger on a Vitrifrigo C50i this morning--$650 plus tax and $59 shipping to Colorado, at 4-State Trucks:
https://www.4statetrucks.com/vitrifrigo-refrigerat...gIhRPD_BwE
The webpage also includes quite a bit of useful info re: power consumption, installation, etc.
EDIT 14 March...this is NOT a C50i, wrong dimensions. It might be possible to use, bit it's about 4 inches (100mm) deeper than the C50i.
1989 Westy
2016 Golf TSI
Gone, but not forgotten:
1974 Dorper Baywindow, "The Bleeding Trout"
1998 Jetta TDI, "Trixie"
1987 GTI, "Heike"
1974 Thing, "The Luftwaffel"
1974 Ghia
1966 Ghia
snoop
snoop is offline
PostPosted: Thu Mar 13, 2025 8:47 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
I don't see where the fridge model is stated in the advertisement, and I'm sorry to tell you, the photos on that website are of a different model Vitrifrigo fridge than the C50i.
87 Westy Camper
jimf909
jimf909 is offline
PostPosted: Thu Mar 13, 2025 9:03 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
I agree that website fridge looks just like the VF51 (which is the same as the TF49 for the most part - see comparisons earlier in this thread) that I installed in my van years ago.
Website photo
- Jim
Butcher wrote:
Guilty as charged.
korfmach
korfmach is offline
PostPosted: Fri Mar 14, 2025 11:02 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Crap, you're right, it's 100mm deeper than the C50i. Sad Canceling and resuming the search.
1989 Westy
2016 Golf TSI
1987 GTI, "Heike"
1974 Ghia
1966 Ghia
korfmach
korfmach is offline
PostPosted: Wed Mar 19, 2025 7:30 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Ordered a C50i from camperinteriors.co.uk. Price was $722 plus $230 shipping to Colorado, US.
1989 Westy
2016 Golf TSI
1987 GTI, "Heike"
1974 Ghia
1966 Ghia
snoop
snoop is offline
PostPosted: Wed Mar 19, 2025 9:40 am    Post subject: Re: fridge replacement projects - post here Reply with quote
You did good. That's where we got ours about 4 years ago and that's about what we paid. No tarrif on the UK yet.
Enjoy your new fridge; we do ours.
87 Westy Camper
Smileydude
Smileydude is offline
PostPosted: Mon May 26, 2025 9:20 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Don't buy the c50i from camperinteriors!!
Just ordered and the fridge was marked as if it is made in China.
Meaning you are charged tariffs as if it is from China.
Also the flush mounting frame has not made it through custom either as they didn't complete that paper work correctly either...
They have gone silent on me and won't return my emails.
Just a major expensive headache and nothing to show for it.
Page 35 of 37
