obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 3027 Location: East Northport, NY
Posted: Tue Nov 26, 2024 3:27 pm Post subject: Pressure Plate Torque |
My throw out bearing failed the other day and I figure it’s probably worth while to replace the clutch/pressure plate, bearing, clips, and some other things for good measure while I have the car apart.
Last time I did this job was on a Super and I didn’t care much in my youth, so I just bolted shit down and ‘sent it’ as the kids say.
I care a bit more about my 64 and am curious if there should be any thread lock (or anti seize) on the bolts for the plate and if there is a torque spec I should adhere to.
Thanks! _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79486 Location: Sneaking up behind you
Posted: Tue Nov 26, 2024 3:38 pm Post subject: Re: Pressure Plate Torque |
18 ft-lbs
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33068 Location: Hot Arizona
Posted: Tue Nov 26, 2024 4:50 pm Post subject: Re: Pressure Plate Torque |
18 because the 8.0mm x 1.25mm bolts go into steel flywheel.
Most 8.0mm x 1.25mm on the VW engine are 14 ft lbs as the case is softer metal.
Yes, I use a little blue Loctite threadlocker on the pressure plate bolts. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Rome Samba Member
Joined: June 02, 2004 Posts: 10542 Location: Pearl River, NY
Posted: Tue Nov 26, 2024 11:10 pm Post subject: Re: Pressure Plate Torque |
If not using threadlocker liquid, use the factory-style "wavy" lockwashers under the bolt heads. |
Cusser Samba Member
Posted: Wed Nov 27, 2024 8:29 am Post subject: Re: Pressure Plate Torque |
I think I used both threadlocker liquid and the factory-style "wavy" lockwashers under the bolt heads.
No - I don't wear both belt and suspenders ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
