Help Identifying Hole In Rear Floor Pan
smokeydogvol
smokeydogvol is offline
PostPosted: Tue Dec 03, 2024 11:05 am    Post subject: Help Identifying Hole In Rear Floor Pan Reply with quote
What is this hole for and where or what is the name of the plug I can get to properly plug it? I'm sure it is a drain hole, but I don't need that open 24/7/365. LOL
74 Thing
74 Thing is offline
PostPosted: Tue Dec 03, 2024 12:18 pm    Post subject: Re: Help Identifying Hole In Rear Floor Pan Reply with quote
It is part 111701309 do a search for it.
There is a hole in the rear for the tunnel for 1, and then you can use 2 more one in the rear of each floor pan.
Al Capulco
Al Capulco is offline
PostPosted: Wed Dec 04, 2024 12:20 am    Post subject: Re: Help Identifying Hole In Rear Floor Pan Reply with quote
That is a drain hole. The plug required for that hole is 111 801 177. You will also find them in the bottom of the rocker panels.
74 Thing
74 Thing is offline
PostPosted: Wed Dec 04, 2024 3:10 am    Post subject: Re: Help Identifying Hole In Rear Floor Pan Reply with quote
My bad-the one I referenced is just for the tunnel.
The other one referenced above is for the floor pan sides as well as the ones under the door area under the rockers so moisture can get out-make sure they are there and clean of debris.
smokeydogvol
PostPosted: Wed Dec 04, 2024 9:31 am    Post subject: Re: Help Identifying Hole In Rear Floor Pan Reply with quote
Thank you very much my friend!
smokeydogvol
Thank you so much! Got it!
