trike newbie Samba Member
Joined: February 22, 2023 Posts: 11 Location: Minnesota
Posted: Sat Dec 07, 2024 2:08 pm Post subject: Points not "mating" |
"64 beetle ,40hp. Points were pitted so I took them out, filed them and replaced the condenser . When re installing I couldn't get the points to meet fully. Two piece points. I got a new set and the fiber washer under the pivot looked better , but when installed the contacts are only meeting about 60%. How the spring is clamped with the wires seems to change the height.
HOW do you tighten the bolt to secure the wires? No room in distributor . If I do it outside, It won't go down all the way on pivot shaft . |
Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 158 Location: North Alabama
Posted: Sat Dec 07, 2024 4:39 pm Post subject: Re: Points not "mating" |
| A picture would help us here.”Meeting 60%” means…? |
Joined: April 27, 2002 Posts: 6839 Location: Pentwater, Michigan
Posted: Sun Dec 08, 2024 7:26 am Post subject: Re: Points not "mating" |
Sounds like you are describing a big cap 40hp distributor issue. On a big cap 40hp distributor the easiest way to work on points and condenser is to disassemble the distributor and work from a better angle. There's a reason the design only lasted a few years. _________________ Roads Scholar
Member# 2059
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7564 Location: Houston, Texas
Posted: Mon Dec 09, 2024 7:28 pm Post subject: Re: Points not "mating" |
Some points are better than others. Some points require them to be bent in order to flatten the mating surface. A picture would help to understand what is needed. Make sure nothing is under the flat part that screw holds down. _________________ www.vwnos.com [email protected]
