jbannon Samba Member
Joined: September 19, 2020 Posts: 219 Location: New York
Posted: Sun Nov 03, 2024 8:48 am Post subject: Removing Micarta bushings from the front beam |
I was hoping someone could provide some sage advice (including tools) on removing the inner and outer micarta bushings from my front beam. The old bushings will be replaced, so there is no need to save them given how worn out they are. Thanks! _________________ 59 Beetle - Diamond Grey
58 Beetle ragtop - Glacier Blue
58 Beetle ragtop - Black
56 Beetle - Stratos Silver
62 Beetle - Turkis
67 Beetle - Savannah Beige |
Posted: Mon Nov 04, 2024 2:46 pm Post subject: Re: Removing Micarta bushings from the front beam |
No takers? _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
mkhanshaw Samba Member
splitjunkie Samba Member
Posted: Mon Nov 04, 2024 5:09 pm Post subject: Re: Removing Micarta bushings from the front beam |
Of those videos, only this series of three shows the process for removal. Pretty easy to make the puller from some bar steel and althread.
This one shows how to ream the bushings, but doesn't give much detail about the reamer itself.
_________________ Chris
Posted: Mon Nov 04, 2024 6:10 pm Post subject: Re: Removing Micarta bushings from the front beam |
Thanks for the feedback and comments. All very useful. _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1924 Location: Fontana
Posted: Thu Nov 28, 2024 6:45 pm Post subject: Re: Removing Micarta bushings from the front beam |
you can buy the smaller bearing puller tool from amazon . I think its 20bucks _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Thu Nov 28, 2024 7:34 pm Post subject: Re: Removing Micarta bushings from the front beam |
Can you provide the link for the smaller bearing puller? Thanks. _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11171 Location: Huntington Beach, CA
Posted: Thu Nov 28, 2024 10:53 pm Post subject: Re: Removing Micarta bushings from the front beam |
You need a slide hammer and a large washer from Home Depot. You grind the sides off of the washer, around 1/4” each side, directly opposite of one another. Assemble the washer loose on the end of the slide hammer. Catch the washer on the back edge of the bushing and get it to lay flat against the back of the bushing. Then slide the hammer a few times. It pops out with very little force!
Not hard to do and not expensive. The slide hammer kits are around $60 off of Amazon. The washer is about a buck at HD. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 1000 Location: Lanark County, Ontario, Canada
Posted: Fri Nov 29, 2024 12:29 pm Post subject: Re: Removing Micarta bushings from the front beam |
Also remove the grease fittings first since the bushings can catch on them. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Fri Nov 29, 2024 1:08 pm Post subject: Re: Removing Micarta bushings from the front beam |
Thanks for the feedback. Much appreciated! _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Fri Nov 29, 2024 7:52 pm Post subject: Re: Removing Micarta bushings from the front beam |
Are you referring to these?
_________________ www.vwnos.com [email protected]
Posted: Fri Nov 29, 2024 8:01 pm Post subject: Re: Removing Micarta bushings from the front beam |
Yes. That’s what I am referring too. _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
heimlich  VWNOS.com
Posted: Sat Nov 30, 2024 8:25 am Post subject: Re: Removing Micarta bushings from the front beam |
They should break very easily. I've seen people use taps in other places to get right inside the bushing then pull the tap out. That would be an expensive tap. I like the above post about a bearing puller. I've used something similar on pulling the bushing out from a pedal assembly. I think it's called a blind hole bearing puller. _________________ www.vwnos.com [email protected]
jason Samba Member
Posted: Mon Dec 09, 2024 10:45 pm Post subject: Re: Removing Micarta bushings from the front beam |
You can do what jimbo says. I've done that way a few times. I use a socket over the end and a long bolt. Cheaper than a slide hammer. You can also use one of the torsion springs to tap it out from the other side. |
Robert Chambers Samba Member
Posted: Wed Dec 11, 2024 7:43 am Post subject: Re: Removing Micarta bushings from the front beam |
I made my own puller using a long threaded rod, nuts and appropriate size washers. Simply push the washers in on an angle past the bushing and they will flatten to the bushing. Tap it out using pliers and hammer or use a slide hammer puller. Pull one at a time. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
