SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Thu May 09, 2013 1:36 pm Post subject: T3 Gear linkage differences, petrol, diesel and Syncro |
Here are some pics I took of the gear linkages that I have from vans I've broken over the years.
First the rear sections:
From the top down,
The top two are diesel 2WD. The diesel gearbox and engine are mounted higher in the body than the petrol gearbox and engine.
The centre one if from a Syncro, the gearbox and engine are mount further down in the body.
The bottom two are for petrol 2WD.
Next is a photo of the front sections:
The top one is from a Syncro van.
The next one down is from a diesel 2WD van, note that is has a small kink at the right hand end.
The bottom two are from petrol 2WD.
I have converted several 2WD vans to Syncro and managed to use the original 2WD linkage by simply bending it to match up. Also, the front section has cleared the front diff despite not having the section that is bent up to give more room.
Also, I have converted from petrol to diesel and again, I have managed to modify the original petrol linkage to work on the diesel (this is on my daily driver Tristar 2WD).
Obviously the best and easiest way is to just change to which ever one suits your application, but you can modify and make it work.
All of the above linkages are for later style gearboxes, not pre '83 with the three bolt gearbox mount as on air-cooled vans.
I hope that this helps other nutters like me who are always modifying and changing their vans around
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
zeohsix Samba Member
Joined: August 31, 2012 Posts: 501 Location: United States
Posted: Thu May 09, 2013 1:48 pm Post subject: |
Thanks for sharing Mods should make this a sticky. Great reference for future troubleshooting. |
Farfrumwork Samba Member
Joined: October 10, 2008 Posts: 692 Location: Mile High
Posted: Thu May 09, 2013 9:26 pm Post subject: |
Thanks for the info!!
I was wondering if which front linkage I should use on my syncro conversion. Might a well use the syncro component as i have it pulled from the donor van already. (I have the rear section already from the syncro transmission install a couple years ago)
Thanks again
SyncroGhia = wealth of knowledge _________________ sold -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind" |
Posted: Thu May 01, 2014 2:14 am Post subject: |
Just following on from the original post, I have realised that I missed off another piece of information that might cause some issues when swapping parts over.
This info is from ETOS. If anyone knows differently, please let me know.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18600 Location: Retired South Florida
Posted: Thu May 01, 2014 6:50 am Post subject: |
I recall a recent thread where the poster was having a problem with the shifter ball not being deep enough in the cup. I think it was resolved by loosening the bolts and prying the support bracket up. Looks like there are two cups based on those photos. Good to know. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2397 Location: Bonners Ferry Idaho
Posted: Thu May 01, 2014 7:31 am Post subject: |
I agree about the bolting on the socket mount while applying upward pressure. Letting it fall can result in locking up of the gearshift, as the socket’s angle is too acute to move the ball. You have to crawl under the van to move the lever towards the center. This normally happens with worn parts. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Thu May 01, 2014 7:40 am Post subject: |
I've just installed a Syncro gearbox to a Syncro van than my customer bought running with a 2WD gearbox.
When fitting up the linkage to the Syncro gearbox, I realised that the wrong bracket was being used as the socket was a long way off the ball when it a gear was selected.
This is what reminded me that I'd forgotten to include the info here
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
insyncro Banned
Posted: Thu May 01, 2014 7:51 am Post subject: |
I have all of the USDM 2wd and Syncro parts MG has shown, brand new from VW.
Last year I had the Syncro parts copied by my local fabricator out of stainless steel.
I used the linkage tips available from T3technique.
So far so good.
After more miles to make sure that there are absolutely no issues with the parts, I will make them available for sale in the classifieds.
As an aside, coating the interior of the shafts with Wurth wax or sprayable sound deadener has made a huge decrease in noise transmitted by the linkage into the cabin. |
Posted: Thu May 01, 2014 8:10 am Post subject: |
insyncro wrote: |
I always wondered if that would make a difference worthy of note. Good to hear that it does.
And thanks, Michael, for sharing this information. I'm sure that it will be helpful to others down the road who may be experiencing shifting issues due to mismatched parts. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
insyncro Banned
Posted: Thu May 01, 2014 8:34 am Post subject: |
Not using the aftermarket billet rear cup and extremely hard aftermarket bushings will cut down on the noise transfer too  |
Posted: Thu May 01, 2014 8:45 am Post subject: |
In the US market the early vanagons had a 3 piece shift rod setup. Add to that there were subtle differences between the air cooled and 82 diesel rear rod.
The noticeable difference for the early setup is the rear shaft. Rather than being supported by a bushing like the ones above, the rod slipped over a pin at the transmission. Here is a picture of my original 82 rear section.
You can see the pin lower right.
Posted: Thu May 01, 2014 8:50 am Post subject: |
We have those over here also.
They also have different linkage parts and different mounting brackets at the front as the gearbox sits much higher in the diesel install than in the petrol version.
Check out the height of this early diesel bracket in comparison.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7113 Location: Honolulu,Hawaii and France
Posted: Thu May 01, 2014 11:59 am Post subject: |
Shyt, I didn't know about the bushing plate at the transmission on the Syncro was different. I gotta check that out on the pile of parts that's waiting to be assembled.
One thing I will never understand is the difference of the shifter cup 251711973(A) on a Syncro between diesel and petrol: transmission sits at the exact same spot, bushing plate 251711187B is the same between syncro's…. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu May 01, 2014 12:07 pm Post subject: |
ALIKA T3 wrote: |
One thing I will never understand is the difference of the shifter cup 251711973(A) on a Syncro between diesel and petrol: transmission sits at the exact same spot, bushing plate 251711187B is the same between syncro's…. |
I know what you mean. It doesn't make sense.
I did think that the engine could be at a different height on the diesel but that wouldn't make sense for the propshaft angle.
It's always possible that the parts manual is incorrect.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Posted: Thu May 01, 2014 1:34 pm Post subject: |
Here is a side drawing of a 2wd diesel. It shows the install angle. Not that it explains anything, but it looks cool.
Posted: Thu May 01, 2014 1:43 pm Post subject: |
The 2WD diesel setup moves the gearbox around all over the place.
Not only does the 2WD gearbox sit higher but the mount is in a difference place centrally.
The Syncro uses the same gearbox mounts on both.
Good to see it in a diagram
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Posted: Thu Oct 15, 2020 12:14 pm Post subject: |
SyncroGhia wrote: |
MG |
Hi guys!
here are all the rear shifter rods for the 091/1 and 094 transmissions.
It has the missing piece of the puzzle, the Syncro diesel shifter rod.
For all these years I thought there was only one rear shifter rod for the Syncro no matter diesel or petrol until I went to install the late diesel version of the Syncro diesel engine and transmission protection plate. The shifter hits the mounting rectangular tubing on the right side by the nose cone.
It`s now complete, I hope it will be helpful as there`s no pictures online of all together. Thanks Felix Buhler for the pic and the shifter rod, I added part numbers on it
Posted: Thu Feb 04, 2021 1:35 pm Post subject: Re: T3 Gear linkage differences, petrol, diesel and Syncro |
Follow up on this.
Un-accordingly to ETKA, the Syncro diesel does NOT use the petrol plate and shifter. I tried both for the sake of science on a Syncro diesel shifter.
Other members around the world who took pics for me confirmed they had the diesel selector cup and plate.
Petrol on top, diesel on bottom
This explains the 10mm difference between the petrol and diesel selectors, the diesel plate lowers the shifter position from the transmission by 10mm
With petrol parts, the shifter is very close to the transmission, way too close for engineers to accept that...
Much better with diesel plate
Why a diesel and petrol rear shifter when the transmission is in the same location? Because the petrol one hits the engine and transmission skid plate which is different than WBX, much wider.
They could have made a diesel syncro shifter for all Syncros, so I don`t really know...
Comparison of shifters between syncro petrol shifter and syncro diesel shifter
The syncro diesel is also clocked a bit differently at the selector.
Brown shifter is gas, white is diesel
That`s where you see the brown gas shifter would hit the skid plate mounting bar/elbow on the right side of the van.
I also fixed the syncro diesel shifter I got from Germany, it was a zombie shifter!!
Before
Cut and welded a thick 20mm rod
This part had so much play, it got welded shut and redrilled.
I had brazed the head of the pin a long time ago too.
Also, here`s a comparison of the aftermarket shifter bushing 251711207E on the left, kinda beige looking sold by GoWesty and others. It is softer but gets damaged from the grease ( green/blue marine grease). I had this WBX syncro shifter rebuilt for at least 5 years sitting unused and unmounted for my project. The center of the bushing is decaying. The one pictured is a good one I just unpacked and used for my trial set ups. The decaying one was thrown away before I realized I should have documented it.
On the right is a NOS VW bushing, super hard plastic. Choose your poison
I choose the VW part for overlanding and put white lithium grease like factory this time.
I also use the VW brand bellows, the JP Group ones are mega junk, they will crack just sitting for a couple months unused, if you see them, boycott!
Happy Syncro diesel shifter!
Hawk eyes will notice my high tech selector boot, made of neoprene insul tube. This is 7/8 ID. Fits tight and lasts a very long time and much cheaper than the evil undersized junk found nowadays.
Grantus Samba Member
Joined: September 18, 2016 Posts: 1 Location: Southern ACT, Australia
Posted: Mon Dec 23, 2024 6:00 am Post subject: Re: T3 Gear linkage differences, petrol, diesel and Syncro |
Hi all,
Apologies for dragging up this old thread, but can anyone tell me the purpose & function of this bushed gear linkage above the fuel tank in the 82 model?
Seems it was deleted and replaced with a direct shaft from 83 onwards.
Posted: Mon Dec 23, 2024 8:00 am Post subject: Re: T3 Gear linkage differences, petrol, diesel and Syncro |
The early 3 piece shift did not have a universal joint like the later 2 piece ones. The area you ask about was to allow the early shifter to be moved downward to select reverse lockout. You’d need all 3 sections to make it correct. The diesel also had a different rear section from the gas models.
If you aren’t having shifting problems, you are probably ok. |
