vanis13 Samba Member
Joined: August 15, 2010 Posts: 4567 Location: ABQ NM USA.... Except when not
Posted: Fri Dec 27, 2024 11:47 pm Post subject: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
This coolant hose has cost me an engine and has caused trouble for others.
It is a specific/funky hose with two different size ends and a close bend that sits under the AC compressor. Basically if it fails there isn't a simple solution
On this thread tencentlife wrote about a permanent solution here https://www.thesamba.com/vw/forum/viewtopic.php?p=10254133#10254133
"As to permanent fixes, those 1" hose nipples on the cyl heads can be tapped to 1/2" FPT, the nipple ID is ready for a 1/2" NPT pipe tap without drilling."
Thanks tencentlife/Chris!
Here's how I did it. Notice the shop vac blowing in the thermostat hole. It pushed out the aluminum shavings.
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
sanchius  Samba Member
Posted: Sat Dec 28, 2024 6:28 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
Very nice!
An elegant, easy, & reversible fix that I haven't seen documented here before that solves a vexing Vanagon design problem, lots of great pictures and text/info, and a descriptive title.
This has it all! Thanks for posting this! _________________ The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going!
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 769 Location: Lancaster PA
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5881 Location: Bemidji, MN
Posted: Sat Dec 28, 2024 6:52 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
wow! i hadn't seen that mod before. congrats to Chris for the idea and Andy for pulling it off so well. gonna do that on an engine i have in the stand. this is great! _________________ -dan
www.thefixitworkshop.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8488 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Dec 28, 2024 10:11 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
Likewise, beautiful mod…well done!
Not having seen this before, I recently sprung for the GW option (although haven’t installed yet):
https://gowesty.com/products/aluminum-coolant-elbo...6748276901
Your rig is much more elegant and keeps the original 2 clamp configuration (vs. 4 for the GW).
I may have to reconsider my options…
- Dave
PS: What’s a 1/2” tap co$t…??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10116 Location: Where?
Posted: Sat Dec 28, 2024 10:16 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| dhaavers wrote: |
PS: What’s a 1/2” tap co$t…??? |
I got this set a few years ago.
https://www.harborfreight.com/6-piece-pipe-tap-die-set-91395.html
Obviously, HF isn't the highest quality, but they have worked fine for me. |
Posted: Sat Dec 28, 2024 10:55 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
I’m sure you’re correct (and I’m sorry to be “that guy”), but why then does “everyone else”
…i.e. 10¢, markswagen, djkeev, etc… call for 5/16” barb & hose…???
#curious.just.asking
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Sodo Samba Member
Joined: July 06, 2007 Posts: 10762 Location: Western WA
Thats a nice mod.
For some, that could be the first time they've cut a thread.
A first-timer might appreciate a YouTube with some dialogue, about advancing, then reversing to clear the chips.
And using the fitting to decide "how deep" to thread a tapered pipe.
A before and after pic would be cool too. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat Dec 28, 2024 11:07 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
i looked at tap options, from $6.99 ones, to $15 Irwin ones to $240 Emuge ones that machinists love.
did a bunch of 1" and 1.25" NPT stuff on a friend's ground source heat pump and had several leaks from the Chinese fittings despite liberal use of a high quality pipe dope and more torque than should have been needed. had to re-apply dope and re-tighten a few to crazy stupid levels. so, not wanting to split the head outlet, i decided to go quality and found a NEW Emuge 1/2" NPT tap for $40. zooming in on the cutting threads on the Emuge, they are simply beautiful machining compared to the rough cutters on the cheapos. $25 more than the Irwin but, like Loreal, "I'm worth it". actually, just want to do this once on the heads i modify having just suffered insufferable NPT fittings.
the observant will notice this is an NPTF tap... designed to seal without sealant. since NPT threaded parts require sealing compounds, it is acceptable to use an NPTF tap for NPT applications.
Posted: Sat Dec 28, 2024 11:17 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| dhaavers wrote: |
- Dave |
the 5/16 is probably the "best" fit but I couldn't find a one-piece solution 90deg for that I liked. 3/8 seems to fit so went with that since I didn't want to piece together fittings.
If you're stuck on 5/16 ...
Here's a straight solution. there's likely enough room for the thin hose to bend around.
https://www.amazon.com/Brass-Fitting-Adapter-CX-WO...Y&th=1
Here's a "swivel" solution, though I fear leaks in that swivel
https://www.amazon.com/Joywayus-Swivel-Fitting-Adjustable-Adapter/dp/B0828V44MQ?th=1
Posted: Sat Dec 28, 2024 11:21 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| DanHoug wrote: |
| did a bunch of 1" and 1.25" NPT stuff on a friend's ground source heat pump and had several leaks from the Chinese fittings despite liberal use of a high quality pipe dope and more torque than should have been needed.[/img] |
Interesting -
1) coolant is 15pst vs. domestic 25-80psi. Lower pressure is less likely to leak
2) I've had good luck with cheap taps, YMMV
3) for a one-time use cost is a factor
4) most plumbing work uses the die (female cutting tool for male pipe) to fit pipes. What did you tap (male cutting tool to make female fittings) in that project? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Sat Dec 28, 2024 11:32 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| vanis13 wrote: |
Interesting -
4) most plumbing work uses the die (female cutting tool for male pipe) to fit pipes. What did you tap (male cutting tool to make female fittings) in that project? |
his system runs <10psi. it was all box store, pre-made NPT pipe and fittings, no cutting threads. frankly, we were surprised that we had ANY leaks as we're both DIY guys with pipe experience. and there were several leaks. so, i'm gun-shy and was happy to find a quality tap for a decent price.
i saw that swivel fitting and wondered how it holds up. nothing worse than being too loose with the fitting in the correct position and hearing that 'snick' as you rotate it juuuust one more time. _________________ -dan
Posted: Sat Dec 28, 2024 11:40 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
Thanks for the reply, all good chatter…
I just verified, my brother (plumber) has a 1/2” NPT tap to borrow, no cost other than a 1.5 hour round trip.
Also found this…short of starting another stainless debate, might be just the thing…???
https://www.amazon.com/dp/B08FX9TX6N/?coliid=I1R4I...t&th=1
Tag, you’re it!
"The WonderVan"
Posted: Sat Dec 28, 2024 11:41 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| DanHoug wrote: |
| it was all box store, pre-made NPT pipe and fittings, no cutting threads. |
So feedback on pipes/fittings not on taps....Maybe you want to get an expensive fitting instead of/or with your expensive tap (teasing) .
If the fitting I used shows issues I'll update.
Luckily, I've had no issues with all sorts of NPT fittings from various sources. And as you can tell by my post, I don't get the pricy stuff unless its justified - like a SABO seal if one can be had ;-p _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Sat Dec 28, 2024 11:44 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| dhaavers wrote: |
Tag, you’re it!
- Dave |
Saw that too. I've had bad results of SS into Alum on the sailboat and didn't' want to chance it on this sealing surface. if there was a hose between SS and Alum I wouldn't have an issue but direct contact I didn't want....Likely would work just fine though unless your van lives on the ocean coast...
...really, the hose fits fine on the 3/8 and it's a readily available fitting.
Tag  _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Sat Dec 28, 2024 11:47 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| dhaavers wrote: |
| I just verified, my brother (plumber) has a 1/2” NPT tap to borrow, no cost other than a 1.5 hour round trip. |
...wonder what he'd have to say on the cheap vs expensive tap decision for this use case. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Sat Dec 28, 2024 11:49 am Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
Hoses & wires: A little too big is better than a little too small.
"The WonderVan"
Posted: Sat Dec 28, 2024 12:09 pm Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
that fitting is in my cart but i'm not crazy about stainless into aluminum either. but MOSTLY from a thread stretch standpoint. NPT seals with a combination of goo and threads locking into a taper, with some resultant thread give. i'd rather have the softness of brass into aluminum vs stainless.
here's one place that sell a 1/2 NPT > 5/16 brass.... IF you can get that one laaaasst turn! a bushing gives a bit more option but twice the leak potential!
https://mettleairstore.com/products/139-5d
someone should get that swivel fitting and let us know how it works out for the next 20 years. THEN we might spend the $10! _________________ -dan
rustyCamper Samba Member
Posted: Sat Dec 28, 2024 12:10 pm Post subject: Re: 025121058M 2.1 "Peace Pipe" coolant hose - better solution |
| Brass is higher on the galvanic series than aluminum. You will likely get galvanic corrosion around the threads contacting the the fitting and this will likely develop a leak as the corrosion eats through. |
