Deck Height, Squish and Performance Effect
Page: 1, 2, 3  Next
JPB6061
JPB6061 is offline
PostPosted: Mon Dec 30, 2024 4:57 pm    Post subject: Deck Height, Squish and Performance Effect Reply with quote
Got a set of nice dual port heads but with only 40cc chambers.
92 x 76 "A" forged Mahle pistons.
If I don't buy new heads with say 55cc chambers, how bad would the 2021 run with the 40cc chamber and a .137" deck height which would give me 9:1 CR? I've thought about dished pistons as a solution, but haven't found any type 1 specific 92's. I could mill dishes in mine, but am a bit skeptical about final piston deck thickness.
Empi Web Cam 86B, Dual 44's.
We've built v-8's with .100" deck and no apparent issues, N/A tunnel ram with nitrous and twin turbo. I've read a lot on here about squish, preignition, detonation, etc. and other than the oft-quoted Gene Berg trope have not come across anyone posting current real-world examples.
As per usual, costs are spiraling out of control and I'm curious if anyone has some input here!
b-man
b-man is offline
PostPosted: Mon Dec 30, 2024 5:41 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Build it and report back with your real world results.
Or buy new heads with the proper chamber size and set the deck to .040”.
Had the same quandary myself, my build changed from a 9:1 1835 to a 9.5:1 2276. I sold my 50cc heads and bought 60cc heads.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Dec 30, 2024 5:44 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
I'm rebuilding a 2054 that has 42cc heads. Deck will be .109" so he gets 8.7cr.
He doesn't want to spring for new heads since he didn't expect to spin a rod bearing with only a few hundred miles after he bought the engine from someone else.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Alstrup
Alstrup is offline
PostPosted: Mon Dec 30, 2024 5:48 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Not good, but doable. The engine will respond basicly like a hemi, which means that it will need a lot of timing to make a decent burn. You will alsa have to have some decent spark capacity.
Dont expect any major torque- or hp out of it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Brian_e Premium Member
Brian_e is offline
PostPosted: Mon Dec 30, 2024 6:12 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Here is a long post about it from a while back.
Read jimmyhoffa's post half way down.
https://www.thesamba.com/vw/forum/viewtopic.php?t=761948&highlight=
I have had very similar experiences going from .110 deck down to a .040 and dished pistons on a 2276cc. I can no longer recommend dishing pistons though. Mine ran cooler, idled better, WAY better throttle response, and needed a smaller main jet with the tight deck.
If you have NO money left, just build it. But if you can swing the heads, there are lots of options out there with good chambers that are 60cc.
Dave will be along shortly to call us all rocket scientists, and accuse us of reading chevy books. Tight deck isn't just a chevy thing. It applies to any internal combustion engine. It has been proven to work better since the '50's.
Myself and others have done the A/B comparison, and it does make a noticeable difference in multiple areas.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
txoval
txoval is offline
PostPosted: Mon Dec 30, 2024 6:20 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Can you convince him to change the cam? Way cheaper than heads
Run .06 at 11:1 and an 86C
I guarantee you will sell the 86b quickly
modok
modok is offline
PostPosted: Mon Dec 30, 2024 8:16 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
This one is easy, the answer is very simple
Run it just like that, or get different heads.
Not possible to dish the pistons enough or open the chambers enough to get tight deck.
How bad would it be? depends what you compare it to, but, still pretty good. I mean, what is the goal anyway?
Far as anybody with "real world experience" just use the search feature.
sled
sled is offline
PostPosted: Mon Dec 30, 2024 8:45 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
“Buy once, cry once”
There are tons of benefits to proper deck height
Those heads would yield 9.6:1 on a 1600 with .040 deck….kinda sound like door stops to me Sad
drive your split.
74 Thing
74 Thing is offline
PostPosted: Mon Dec 30, 2024 10:17 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Brian
Brian, why do you no longer dish the pistions-too thin?
Brian_e is offline
PostPosted: Tue Dec 31, 2024 11:18 am    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
I know if 2 engines now that broke the AA hyper pistons that were dished about .055". I know both were not the best tuned, and were pinging and lugging up a long hill when it happened.
On the other hand, I have 30k+ miles on my 2332cc in my bay with big dishes in the AA pistons, and it has been fine. Long hot, hard miles. I have probably 10-12 more with dishes out there that have been just fine, but 2 did break.
I think it is kinda like the old "that guy could break an anvil in a sandbox" kinda thing. Same goes with transaxles. Some guys can make a stock box last forever with a 2332cc, some guys can destroy a build box with a 1641cc. Lots depends on the tune, and driving habits.
With the availability of good quality heads, with correctly shaped, large volume chambers, there really shouldn't be a need to dish pistons anymore.
Brian
-Modok
BFB
BFB is offline
PostPosted: Tue Dec 31, 2024 12:12 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
WHAAAAA??? Oh the sacrilege! Im surprised the guys arent forming a mob to have you disbarred. Heh heh
I personally think this “040” deck gets made to much out of, is the tight deck better? Sure. But how many engines built with a good deck run around mistuned, probably a lot, and thats worse. I know ive torn down several engines and sure yall have too that had well over .1 deck and had obviously ran for a long time, im pretty sure i measured a few at about .17.
So i dont think .137 is going to be detrimental but it were me, id split the difference and run .1 with 9.9:1 cr
Most experts aren't.
Alstrup
Alstrup is offline
PostPosted: Tue Dec 31, 2024 1:23 pm    Post subject: Re: Deck Height, Squish and Performance Effect Reply with quote
Read up on "the death zone" Its called that for a reason.
Rome
Rome is offline
PostPosted: Tue Dec 31, 2024 3:30 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
[quote="modok"]
People might lob tomatoes at me for this suggestion, but it might be an alternative for improvement- and certainly for discussion: How about machining the heads for semi-hemi chambers? That usually removes several cc of head material, and should allow the PO to run less deck height. Though if the heads already have only 40 cc chambers, maybe there is not enough thickness to the chamber to sustain removing more material safely from the SH.
Alstrup
Alstrup is offline
PostPosted: Tue Dec 31, 2024 5:08 pm    Post subject: Re: Deck Height, Squish and Performance Effect Reply with quote
You most likely answered your own question
94touring
94touring is offline
PostPosted: Tue Dec 31, 2024 6:12 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
Well, then let's say the same amount out of tune WITH a huge deck height, so double the bad. I was one of those guys actually. Bought a turn key 2110 and drove it awhile and was never impressed. Then added a wideband and saw how out of tune it was. Tuned it best I could and it was better but still underwhelming. Then decided to change things up and redid the top end. Granted I upped compression, ported heads w/ matched manifolds, 92TW, and 1.25 rockers, but I also went from a massive 0.1+ deck height to a .040. It was easier to tune and ran the same head temps as before and with over a full point more in compression. Went from underwhelming to hey this is rather whelming!
[/quote]
oprn
oprn is offline
PostPosted: Tue Dec 31, 2024 6:54 pm    Post subject: Re: Deck Height, Squish and Performance Effect Reply with quote
What in the engine going to be used in and for what? Drag racing? Weekend warrior? Daily driver? Rock crawler?
How high would it be with a .040" deck and those heads?
Maybe you could use a high CR with the right fuel and application? 12/1 or 13/1 works for methanol or... heaven forbid... propane/natural gas.
txoval
txoval is offline
PostPosted: Tue Dec 31, 2024 9:31 pm    Post subject: Re: Deck Height, Squish and Performance Effect Reply with quote
change the cam…but it would be nice to get more details on the heads.
modok
modok is offline
PostPosted: Tue Dec 31, 2024 10:23 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
That would be fine choice IMO.
Some would say you are further ruining the heads, but maybe this is just how they will retire from racing.
BFB
BFB is offline
PostPosted: Tue Dec 31, 2024 11:07 pm    Post subject: Re: DECK HEIGHT, SQUISH AND PERFORMANCE EFFECT Reply with quote
I thought about mentioning hogging out the chambers earlier, not necessarily semi Hemi cutting them though, but i figured to get where OP would need to be he’d need to remove about 5cc and thatd be more than most ppl are willing to go. Not to mention all the pissing and moaning about how the engine wouldnt run.
Most ive pulled out was 11cc out of some 42cc empi heads cut for 94’s. Look like boosted LS heads.
Do whatever works , it ain’t rocket science its just a damn 4 stoke engine
Vanapplebomb
Vanapplebomb is offline
PostPosted: Wed Jan 01, 2025 6:56 am    Post subject: Re: Deck Height, Squish and Performance Effect Reply with quote
I have found a tight deck to be really helpful. Somewhere in the range of 0.030 - 0.050 inches seems to be the sweet spot. I tend to go on the tighter end, 0.030 - 0.040 inches.
The engines tend to run cooler (even with slightly more compression) and tune up better. Larger than 050 seems to cause a lazy response to changes in tuning. By the time 0.080 rolls around, it’s a lazy engine that tunes up more vaguely. Overall just less responsive.
One thing I do when running close to 030 is to rock the pistons in the bore when checking. I measure clearance at the top and bottom the cylinder while applying light pressure to the back side of the piston skirt with a wood or plastic dowel. This takes up any clearing play and tips the crown out to give you a better idea of how close the piston comes to the head. On bigger bores with shorter skirts, you can see a few thou difference between that and measuring over the pin.
1800 Type 4 Berrien 295
Page: 1, 2, 3  Next
