Bad Temperature Sensor For Gauge??
Page: 1, 2, 3, 4  Next
jdbs3
jdbs3 is offline
PostPosted: Sun May 15, 2016 2:30 pm    Post subject: Bad Temperature Sensor For Gauge?? Reply with quote
1990 Vanagon GL
I just replaced my thermostat, thermostat housing, and the 2 sensors that fit into the housing - the black sensor for the temperature gauge, and the blue sensor for the fuel injection. The black sensor for the temperature gauge was a Meyle 87°C variant.
After the install, the needle on the temperature gauge was about 3/4 up the gauge, or 1/2 way between the LED and the max indicator. So I re-installed the old temperature sensor.
Now the needle on the gauge is on the upper side of the LED, where it should be.
So was the new black sensor to the temperature gauge bad, or ??
thanks
kamzcab86
kamzcab86 is offline
PostPosted: Sun May 15, 2016 2:46 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
jdbs3 wrote:
So was the new black sensor to the temperature gauge bad, or??
Most likely. Same exact thing happened to me, except the warning light was also triggered. Pulled the new sensor back out and tested it's resistance value vs. the old in some coolant and the new one tested bad. About a year later I tried again, but bought it through a local vendor. Tested the new sensor before installing it and it tested good. So far, no issues (but I kept the original... just in case).
2016 Golf GTI S
childofthewind
childofthewind is offline
PostPosted: Sun May 15, 2016 5:11 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
It is not abnormal to have the temp gauge reading that high. Mine did that when I first purchased it. After years of work and replaced parts the needle is much closer to the led - a little below it and then the rad fan kicks on when it hits the very top of the led bulb which seems more misleading than the old reading.
http://www.gowesty.com/tech-article-details.php?id=74
1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville
Tom Powell
Tom Powell is offline
PostPosted: Sun May 15, 2016 6:33 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
I'm in the middle of this sensor project too. I had a bad sensor and no reading at the gauge. I replaced the sensor with a new one and got much higher than "normal operating temperature" indications at the gauge. Two needle widths above the led instead of half a needle width below and a blinking led twice. I ordered a "Made in USA" sensor from an advertiser on ebay, but it turned out to have an internal short and I put the high reading sensor back in. I now have a "normal operating temperature" at the gauge which is alarming. I'm tired of taking coolant showers under the vehicle and will live with the new gauge indications for now.
IMO The radiator cooling fan is a better indication of coolant temperatures than the sensor, gauge, or led. I have the lower temperature fan switch installed on my radiator and the fan has come on at expected times in bumper to bumper traffic. The gauge needle was nearly pegged and once the led started blinking before the fan came on. I attribute these indications to a new sensor which is "overly sensitive".
Vendors have noted on their websites that their new sensors may have higher than expected gauge readings.
I've done a similar reply in other recent posts regarding coolant temperature indications.
http://www.thesamba.com/vw/forum/viewtopic.php?t=654689
http://www.thesamba.com/vw/forum/viewtopic.php?t=627477
jdbs3 wrote:
... So was the new black sensor to the temperature gauge bad, or ?? ...
Short answer: No it's just different and sensitive.
Aloha
tp
jdbs3
jdbs3 is offline
PostPosted: Wed May 18, 2016 5:25 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
Thanks for all the input. Sounds like the new sensor is just more sensitive. After reading various GoWesty technical bulletins and the threads Tom Powell referenced, I've a few questions.
GoWesty noted "If you can keep oil and coolant in your waterboxer, you can’t kill it!". I'm interested in doing a road trip cross country within the next year or so, so want to understand as much as I can about the coolant system now. I've got Bentley, but it only goes so far.
So a few questions to help me along in my journey.
1. Can I confirm the sensor that read high is okay by measuring its resistance out of the van? If so, what should the resistance range be?
2. I believe my coolant system is working okay. Even with the bad thermostat (the needle would not even register with it), the coolant fan came on if sitting in stop-and-go traffic, etc.
In one of the posts, hdenter noted "They [the radiator] have a reputation for getting clogged and restricted."
How would one know if the radiator is clogged and restricted?
3. How would one know if there was an air pocket in the radiator? What would be the symptoms, and what might it result in if the coolant can not move that air pocket along?
Possibly some dumb questions, but the only way to learn.
Thanks
dhaavers
dhaavers is offline
PostPosted: Wed May 18, 2016 6:55 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
There is a thread here somewhere with typical resistor values for typical gauge readings...
Someone must have it bookmarked...???
Check for coolant flow through the radiator with your hand or a temp gun. Once at operating
temp, cooler areas indicate less coolant flow & that's where you are losing cooling capacity.
A new, clean rad will be pretty equal all across - top to bottom, side to side.
Air will of course tend to collect at high points...top of radiator & t'stat housing are common.
Either will prevent full flow and cause decreased cooling. Bleed carefully, watch your gauge
& keep things topped up...See you on the road!
- Dave
"The WonderVan"
Robw_z
Robw_z is offline
PostPosted: Wed May 18, 2016 7:14 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
Just chiming in that I put in a new temp sensor as well, and it also reads high. Don't like it.
To get an air bubble out of the radiator you use the bleeder screw on top of it behind the grill. Tough to know if it's clogged without removing it. If you have overheating problems that can't be traced to anything in the rear, replacing it isn't a bad idea.
-Rob
dhaavers
dhaavers is offline
PostPosted: Wed May 18, 2016 7:20 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
FWIW, my new gauge sender only reads about halfway to (left of) the LED.
Whatever...
<shrug>
"The WonderVan"
Tom Powell
PostPosted: Wed May 18, 2016 8:24 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
jdbs3 wrote:
... 1. Can I confirm the sensor that read high is okay by measuring its resistance out of the van? If so, what should the resistance range be? ...
Mistakenly I originally bought a sensor with the wrong shape for the connections and had to reorder. Possibly that one is for a different year and/or a different gauge. The resistance of that sensor is 867Ω at Kaneohe ambient temperature 80ºF/27ºC.
GoWesty says "The coolant temperature sensor is a variable resistor. Its resistance DECREASES as the temperature INCREASES."
The resistance will decrease as the sensor heats up. Therefore a sensor with a higher resistance will give a lower gauge reading. Possibly a small resistor in series would bring the gauge reading down to a comfortable indication. GoWesty has an inline variable resistor and I inquired about using that and got this reply when I asked them about my alarming gauge readings.
"Hi TP,
I asked a tech to weigh in on your question and he stated a couple things. He said that these sensors can have a range of readings that can either increase or decrease the needle position a bit, which is normal for these sensors as resistance can vary between them. I'm pretty sure that all vendors are offering the same sensor, so getting them somewhere else wouldn't necessarily be any different. The temp-adjust that we offer was not developed to be used with a stock set up, even though it can be. We developed that kit in conjunction with our billet thermostat housing kits as those and the sensors they used were introduing less resistance to the gauge. He stated that your symptoms seem like a thermostat, radiator, or some other issue as your radiator fan is coming on. The radiator fan is on a completely different circuit, so it seems like overheating is real and not related to the sender. Thanks!
Mike Wiehl
Sales Manager
GoWesty Camper Products
1119 Los Olivos Ave.
Los Osos, CA 93402"
I have the lower temperature radiator fan switch and the radiator fan comes on at expected times in bumper to bumper traffic. I think that the overall cooling system is in good operating condition.
It is also possible that my OG corroded and broken wiring caused a higher than OG resistance. That might be the reason for the low/comfortable gauge readings before installing the replacement sensor. The new sensor and repaired readings with less resistance.might be responsible for the higher/uncomfortable present readings.
Bottom line:
My high gauge readings are now the new "normal operating range" for a sensor that is probably ≈867Ω. A small inline resistor or a sensor with higher resistance might bring the gauge readings to a comfortable level. Resistance readings from other posters on TheSamba and/or vendors would be very helpful.
Aloha
tp
Tom Powell
PostPosted: Wed May 18, 2016 8:28 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
dhaavers wrote:
FWIW, my new gauge sender only reads about halfway to (left of) the LED. ...
What brand is it and where did you purchase it?
Aloha
tp
chrisfreemanca
chrisfreemanca is offline
PostPosted: Mon Jul 25, 2016 7:15 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
jdbs3 wrote:
1990 Vanagon GL
thanks
I just put a new one this weekend from GoWesty and same results. It's now reading about about halfway between the red light and the top indicator. Radiator fan does kick on as you'd expect in stop and go traffic and occasionally in the driveway. Makes me very nervous for sure although I've not had the red light blink on yet.
87 2wd manual.
davideric9
davideric9 is offline
PostPosted: Mon Jan 24, 2022 8:54 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
I bought a new Temp Gauge Sender for the 2.1 syncro part number 049919501.
Using a VOM, thermometer, pot of water ready to heat, and video camera I decided to see how the ohm resistance and temperature are related. Your results my vary (I only did this once so not completely scientific).
Here are my results
Here is my setup:
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Tue Oct 04, 2022 6:31 am    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
Digging up this thread (and a variety of others, this one seems most like the title I would use to ask nearly the same question).
I recently put in a new front heater valve, a fancy version with a radiator self-bleeding function. I filled up the pressure tank and ran the engine a minute, filled more. Ran a few minutes to let it warm up. No heat coming through the heater lines, so I backed the rear up a bank and turned it off. The tank, being an aluminum version with a pressure relief lift tab on the cap was glad to let vapor out until the point I could open the cap. I put more coolant in and then started and ran the engine a bit, and the flow to the heater was restored, and also the radiator fan came on in another couple of minutes, seeming like plenty of coolant for all that.
The question I have is what failure modes have been noted with the temp 1 sensor: mine now shows a normal beginning to warm up on the gauge on the dash, it gets to the first fat white bar, then 'dies' and falls back down to the cold position. Anyone seen this kind of failure? I just wondered.
Anyway, seems there are a few Temp 1 sensors out there, Napa, Pelican, etc. but each have readings that indicate normal temp at different locations on the readout, with 'stock OE' being what I'd rather get. There seems to be a definite lack of OE sensors available.
Ronkat81
Ronkat81 is offline
PostPosted: Thu Apr 13, 2023 7:53 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
I'm with you.. my new one is giving ridiculous readings!!.
DuncanS
DuncanS is offline
PostPosted: Thu Apr 13, 2023 8:20 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
I'm having trouble finding a temp 1 sender. Everyone has 2s. A source for one which will be good?
Duncan
kamzcab86
PostPosted: Fri Apr 14, 2023 7:37 am    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
Duncan
https://gowesty.com/products/temperature-sensor-for-gauge
https://www.pelicanparts.com/More_Info/251919501D.htm?pn=251-919-501-D-INT
https://www.fcpeuro.com/products/vw-engine-coolant-temperature-sender-vag-251919501d
https://parts.vw.com/p/volkswagen__/Engine-Coolant...9501D.html $60 via VW!! Shocked
2016 Golf GTI S
RBEmerson
RBEmerson is offline
PostPosted: Sat Apr 15, 2023 1:53 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
FWIW, I did the same "replace everything near the thermostat" procedure, using GW parts. Unfortunately, I have a ScanGauge, and can read T2 directly. The T2 readings are significantly higher than I recall from before I replaced the sensors. Grrr...
Using both the T1 (mostly uncalibrated needle - which stays at the bottom of the "normal" range, as it has for the 11+ years we've owned this rascal) and radiator fan behavior, I suspect T2 is lying like a rug. The challenge is to get a true reading of the coolant temp. Meanwhile, I assume all's well in the motor (hasn't seized yet!).
GoWesty Temp-Adjust kit wrote:
It is also important that the entire cooling system is in proper working order. If in doubt: MAKE REPAIRS BEFORE PROCEEDING. The purpose of your GoWesty gauge calibrator is NOT to force your gauge to read LOWER if your Vanagon is, in fact, running TOO HOT. The intent is to make the gauge read ACCURATELY.
Calibration procedure:
1. Drive vehicle to get it up to (or close to) normal operating temperature.
2. Let the vehicle idle until the cooling fan begins to cycle on/off/on/off.
3. Check reading on temperature gauge; it should read at about 2/3 - 3/4 on the gauge.
4. If it reads TOO HIGH, your GoWesty temperature gauge calibrator will fix this condition (see step 6 below).
5. If it reads TOO LOW, you either have the wrong thermostat that is opening too early AND a fan thermo-switch that is coming on too soon, and/or a bad gauge. Your GoWesty temperature gauge calibrator WILL NOT correct this—your other problem(s) must be corrected FIRST.
6. If your gauge reads TOO HIGH, install the GoWesty temperature gauge calibrator and adjust the variable resistor (white circle, use a small screwdriver) so the temperature gauge reads at 2/3 - 3/4 while idling with the fan cycling on/off.
7. Drive your vehicle on a flat road at 65 MPH at an ambient temperature of 60-80 degrees for about 5 miles.
8. Gauge should read close to mid-scale; exactly ½ way is ideal, but not imperative.
Lord, give me coffee to change the things I can change, and wine to accept the things I can't change.
ZsZ
ZsZ is offline
PostPosted: Sat Apr 15, 2023 11:24 pm    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
just an addon for the info above:
these senders give the variable resistor value referenced to ground - a bad ground either in the engine bay or at the gauge can mess up readings.
and the gauge runs on regulated voltage - if the voltage regulator in the dash give up the ghost it messes up readings too.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
RBEmerson
PostPosted: Sun Apr 16, 2023 5:56 am    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
A very good point!
Too often attention is paid to the "hot" or supply side of a circuit, and the return or ground is ignored. The full path, from battery to device to battery matters.
SamboSamba22
SamboSamba22 is offline
PostPosted: Sun Jan 12, 2025 9:30 am    Post subject: Re: Bad Temperature Sensor For Gauge?? Reply with quote
Alright guys, 20 plus threads about this issue, just happen to choose this one for my questions. 1991 Carat with 86k original miles.
Before any of my work: temp gauge always sat right on the led light or just below it at running temperature. Never any issues.
Work completed:
Stainless steel coolant pipes, new thermostat with aluminum Syncro housing, new aluminum distribution tower, GW expansion tank, new overfill tank, all new rubber hoses. Everything has been replaced for the cooling system aside from radiator (current one installed in 2021, have new one on order).
Temps at the radiator after 40 minutes idling 185° both sides, low speed radiator fan kicks on.
After 15 minutes idling, temp gauge light begins to flash. IR gun is telling nothing is getting too hot, all hoses, radiator are heating up in a normal manner. Temp gauge is sitting right on the 3/4 mark of the gauge, again light flashing the whole time. The led light does flash prior to start up and goes out.
I can’t reuse my old temp sensor for the thermostat as the original housing was plastic and the syncro unit is aluminum. I don’t recall the brand of the new temp sensor. All of the air is out of the system, expansion tank is completely full.
We leave in two days for our road trip, heading to BBB from Arkansas. The temp gauge with its flashing light is freaking me out, especially with the elevation and mountains through our trip.
Are these new sensors that sensitive/variable? Already tossed my original so no measure off of it for resistance. Of course i didn’t measure the new one prior to install.
Looking for some opinions and insight, rather new to the water cooled element of these things, any guidance or thoughts are appreciated.
Sam
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Page 1 of 4
