panicman Samba Member
Joined: December 18, 2011 Posts: 2677 Location: Canby, OR
Posted: Tue Jan 14, 2025 7:56 pm Post subject: I'm rusty and the car has sat for 2 years- no start. SOLVED |
Hi everyone, I've been away for a while. I have a '60 with an old 40hp that was running strong when I parked the car a couple years ago. It's been on a tender so it cranks over fine. Oil looks fine. The gas was obviously bad, dark piss yellow and didn't smell right. Emptied the tank, rebuilt the fuel tap, and put in new sock and braided fuel line. Car cranks merrily over without a pop. I pulled the air cleaner off and watched while the engine was cranked, and no fuel is coming up into the carb at all. I already ordered a carb rebuild kit, assuming I'd have to do that, but now I'm thinking maybe it's the pump? Both were rebuilt about 2500 miles ago, but that was probably 12 years ago. Do y'all think I should start with the carb, pump, or just do them both?
((Note- turned out that I botched the reassembly of the fuel tap. That led me down the path of doing the unplanned tube up that ensued))
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11670 Location: Oregon
Posted: Tue Jan 14, 2025 8:19 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Welcome back.
Validate that you have fuel up to the inlet to the fuel pump.
If so, remove the fuel line from the carb and see if the pump is supplying fuel to the carb inlet.
If not, pour some fuel into the fuel line from the carb end and let it sit for a a minute or so.
Sometimes dormant fuel pumps lose their prime and need a little help getting fuel moving.
If you have some, a short squirt of carb cleaner into the open top of the carb doesn't hurt. Squirt, try to start the engine. If it pops, you have ignition, and just need fuel through the carb. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
viiking Samba Member
Joined: May 10, 2013 Posts: 3471 Location: Sydney Australia
Posted: Tue Jan 14, 2025 8:38 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
A little trick I was taught as a young fellow was to stick your hand over the top of the carb and use the starter. This tends to provide a full vacuum to all the jets of the carb, cleaning them out and even sometimes is enough to re-prime the fuel pump.
Of course for those who are worried about a backfire, disconnect the coil lead.
Do this a couple of times, then remove your hand (obviously), reconnect the coil lead and try to start with or without starter fuel.
At some stage you will need to remove the carb top to see if there is any fuel in the bowl if it fails to start. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue Jan 14, 2025 9:08 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Thanks you guys- I will give these ideas a shot! _________________ 1960 Beetle |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11508 Location: Huntington Beach, CA
Posted: Tue Jan 14, 2025 10:56 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Maybe try a shot of starting fluid in the carb first. That way you know it has fuel. If it starts, keep on your current path. If it does not, go look at spark, engine timing, or compression. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Wed Jan 15, 2025 12:01 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
No luck yet-
Tried injecting about 10cc of gas into the fuel pump from the carb side. Let it sit for awhile, and gave it a try- nada.
Tried the hand over the carb, cranking for :45 sec. No success. The carb is cold and dry still.
Ordering the fuel pump rebuild kit, pulling the carb tonight and I'll just chalk it up to basically overdue service against a backdrop of my neglect.
I don't have carb cleaner on hand to shoot down it. Just a new can of Berryman. _________________ 1960 Beetle |
Posted: Wed Jan 15, 2025 1:03 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
In the waning moments of my evening, I pulled the carb and took the top off. The carb is remarkably clean and the needle valve was moving freely. I think my issue lays with the pump, and I can leave the carb alone for now.
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9985 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Jan 15, 2025 6:50 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Did you remember to put some fresh gasoline in the tank after you drained it?  |
Posted: Wed Jan 15, 2025 9:10 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
I did! _________________ 1960 Beetle |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1081 Location: San Juan Islands
Posted: Wed Jan 15, 2025 10:00 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Ethanol can really gum things up, especially if it sits for longer periods of time. Sounds like your getting things figured, don't forget:
Air - Pretty much have that
Fuel - Determined not getting any to the carb
Spark - Did you check for spark?
Two person job makes it easier, pull a plug wire and with a correct, spare spark plug, ground the plug and have someone crank over. Should see a spark.
That carb does look pretty clean. Doesn't mean those little galleys are not plugged though. _________________ When I set my timing, why do I flush, then take a pee? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26421 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jan 15, 2025 11:42 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Check for spark. Super easy to do with a spark spark plug.
Fill the float chamber of the carb with fuel. If you take a plastic fuel filter and cut it up into a fuel proof funnel that makes it so simple to add fuel when needed to the carb. _________________ In Stereo, Where Available! |
vwsonmybrain Samba Member
Posted: Wed Jan 15, 2025 12:16 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
| Also make sure to check your points. Had a similar problem with a car that had been sitting for a few years and that was literally the only issue. Points had corroded enough due to moisture. Fired right up after cleaning them up. |
Posted: Wed Jan 15, 2025 3:49 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
| Eric&Barb wrote: |
Fill the float chamber of the carb with fuel. If you take a plastic fuel filter and cut it up into a fuel proof funnel that makes it so simple to add fuel when needed to the carb. |
Or maybe better still get a large syringe and fill with fuel that way. I'm always wary about splashing too much fuel around near an engine. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Wed Jan 15, 2025 4:01 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
| viiking wrote: |
Or maybe better still get a large syringe and fill with fuel that way. I'm always wary about splashing too much fuel around near an engine. |
Only way that is a real problem is if done with the engine running, and this is definitely NOT for that situation. Have personally for this a small white plastic pill bottle that turned out to be fuel proof, ironically (plus it now is a vintage) Beano pill bottle that we fill from one of our gas cans twice to fill the funnel into the carb. Small bottle is a must for the buses and trucks with limited ceiling height above the carb.
Anytime with fuel spills in the engine it should be left not running for at least ten minutes to let the gasoline vaporize off before starting the engine. _________________ In Stereo, Where Available! |
Posted: Wed Jan 15, 2025 7:11 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Thank you all so much, I appreciate all the input! Now I'll start down the list and let everyone know what works. _________________ 1960 Beetle |
Posted: Thu Jan 16, 2025 9:38 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Since I had the carb out, I went ahead and filled the bowl with gas, and installed it. I turned the engine over for about a minute. It caught, then fell away, and then actually took off almost... enough to smell that "cooked" exhaust smell that comes after the engine has sat for a long time. Then nothing. I refilled the carb in place using a syringe, tried again, and it did "catch" once or twice, but never actually broke into a sustained idle. Pump rebuild kit should be here Saturday. I still need to check the points, and I also wonder about the coil.
Bosch 6v coils look to be harder to find. I am seeing alternatives (I'd plan to paint black anyway), but are they junk? United Pacific? Holstein? Beru? Standard?
I have my mothballed 36hp that I could "borrow" from while I wait for Bosch availability... _________________ 1960 Beetle |
Posted: Thu Jan 16, 2025 10:31 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
I would probably hold off throwing parts at the problem before solving each issue in turn first. You know you're not getting fuel into the carb, solve that first.
You also know you are getting some sort of spark because it tried to light off. I wouldn't swap any ignition parts yet.
Others have mentioned already, check your points. If they sat for a long period of time, could be they are corroded. Same with spark plugs.
Keep us posted!
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Jan 16, 2025 10:41 am Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
| Root_Werks wrote: |
Others have mentioned already, check your points. If they sat for a long period of time, could be they are corroded. Same with spark plugs. |
Since the OP has the engine firing, that is not a problem. So that definitely also means he also has compression, thusly fuel is the problem.
Agreed, tossing new parts more often than not does not make the shortest route to fixing the problem, nor the least expensive. _________________ In Stereo, Where Available! |
Posted: Thu Jan 16, 2025 2:57 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
Thanks! I also forgot to look at if fuel is getting to the pump. That probably should have been my first step. _________________ 1960 Beetle |
Posted: Thu Jan 16, 2025 4:10 pm Post subject: Re: I'm rusty and the car has sat for 2 years- no start. |
| panicman wrote: |
| Thanks! I also forgot to look at if fuel is getting to the pump. That probably should have been my first step. |
If you have an air compressor you could blow air from the fuel pump end of the fuel line to the tank and have a helper listen/look for bubbles in the tank.
Could even be your fuel pump push rod got stuck in the up position due to rust or other crud, so the pump can not move the fuel as intended. Have also had the return spring in the lower part of the fuel pump rust up and break causing the pump not to work anywhere as well as it should have.
Might also check the spark color. You do not want a weak yellow colored spark. Looking for a nice hot white with blue tinge to it. Plus would check the timing and adjust that if need be. _________________ In Stereo, Where Available! |
