slalombuggy Samba Member
Posted: Sat Dec 28, 2024 5:26 pm Post subject: Re: Low down Hillbilly |
The complexity of this build is amazing, but I gotta ask. Why did you even bother to use the VW pan.? |
OCD Garage Samba Member
Joined: May 25, 2020 Posts: 237 Location: British Columbia, Canada
Posted: Sat Dec 28, 2024 7:55 pm Post subject: Re: Low down Hillbilly |
slalombuggy wrote: |
Thanks S.B. It's a fair question, I used a similar style of build when I put a 350 Chev/Toronado transaxle mid-engine into my '70 square back in the 90's.
Only the back bone which holds the suspension and the set of pedals are original VW items that came with this chassis number, the rest is 2x3 or 1.5x1.5 0.120 wall tube and the floor is thick enough to be a skid plate. My thinking in the beginning was, if I have a chassis with a pre-existing number that has been in the ICBC provincial registry, I'll have an easier time getting clean paperwork and safety inspections passed. If the basic chassis looks substantially the same as factory but has then been 'added to' or 'upgraded' rather than 'scratch built' so hopefully less engineering questions to answer. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2883 Location: HdG, MD & NJ
Posted: Sat Dec 28, 2024 9:21 pm Post subject: Re: Low down Hillbilly |
On the Toronado trans, did you go mid or rear engine. I understand that you flip the trans around and turn the diff upside down. I had a site on it and can’t find it. Thanks _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Sun Dec 29, 2024 7:14 am Post subject: Re: Low down Hillbilly |
Got ya. Did you ever come to Saskatoon with your Toranado squareback? There was a car like that running at SIR at the 1st VW Show I ever attended. |
Posted: Sun Dec 29, 2024 2:04 pm Post subject: Re: Low down Hillbilly |
NJ John: I used a mid sixties Eldorado/Toronado tranaxle which was normally fwd and so, the motor/transaxle package was just relocated to the back of the chassis, running in the same direction as ususal. I suspended it over the stock irs pan with a 2x3 tube subframe, which ran the length of the car (not unlike my current buggy). The stock axles required shortening and custom machined adapters made to go from VW to GM pattern. As long as you didn't expect to burn it off the line, the stock CV's held up fine with both the 305 and 350.
This is exactly what I built but sunk it into a TIII chassis.
https://barnfinds.com/v8-roller-1980-kelmark-gt-chassis/
Posted: Sun Dec 29, 2024 2:36 pm Post subject: Re: Low down Hillbilly |
Salalom Buggy: I've been a West Coaster most of my life and have never had the urge to be 'running back to Saskatoon' with that car (in particular). My squareback had the whole roof chopped off with a removable soft top that covered the cockpit and 6 point cage. The rear area had a sheet metal tonneau style cover which opened for easy work access to the drive train. It ran a big, wide 3 core rad where the spare tire would have been. With the top off it looked like a 90's TIII mini truck. A day at SIR would have been a hard no as those poor CV's were only originally intended for 60hp, one big launch off the line at the dragstrip with the 350 would have noodled them  |
Posted: Mon Dec 30, 2024 1:23 pm Post subject: Re: Low down Hillbilly |
Thanks for the info. Now get to painting! _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Sun Jan 12, 2025 1:18 pm Post subject: Re: Low down Hillbilly |
Today I finished the 3rd and last coat of black single stage on the chassis. My plan is to paint the interior section/console/steering support/roll cage and seats in metalic silver.. Once the black has cured and been scuffed up, it'll get a coat of grey primer followed by 'Volvo Lava Sand Metallic' and likely House of Kolors flat clear to finish.
Posted: Thu Jan 16, 2025 7:34 pm Post subject: Re: Low down Hillbilly |
Almost looks like I stripped the paint off again. I was going to do the interior floor/tunnel in silver as well, but I think the added contrast looks good too. The floor will be covered in butyl sound deadner (foil backed generic Dynamat) and industrial rubber mats over that. Another coat of base colour and I'll clear coat the whole chassis together.
Posted: Fri Jan 24, 2025 5:39 pm Post subject: Re: Low down Hillbilly |
Shot the gloss clear on the chassis today after scuffing the 3rd coat of black, things went well, I'm quite happy overall. So far it looks much deeper/glossier than before. Once it sits overnight to cure, i'll be able to mask off the chassis, shoot flat clear on the interior area and that will be it done. When the rear control arms are assembled, I'll finally be on the road to completion.
Posted: Sun Jan 26, 2025 2:23 pm Post subject: Re: Low down Hillbilly |
Yesterday I finished the top side of the chassis. Now the interior is done in satin clear, the rest of the chassis in gloss and the body will be Dove Blue L31 covered in flat clear. The seats and roll cage will be painted to match the console/steering support.
Posted: Fri Feb 07, 2025 11:17 pm Post subject: Re: Low down Hillbilly |
And so, it begins...
Posted: Sat Feb 15, 2025 10:28 pm Post subject: Re: Low down Hillbilly |
The fuel line and air lines from all 4 corners up to the switches are in, along with the pressure sensors for the gauge. Seat belt holes are drilled and the sound deadener needs a little trimming before final application. The e-brake cables have been threaded through, but won't be shortened until the rear brakes are assembled. I'll make up the brake lines once the rear control arms are back on, as they have to be re-routed around the bags and were waiting for me to change the fittings of the proportion and residual pressure valves which came with SAE fittings.
Posted: Sat Feb 22, 2025 1:25 pm Post subject: Re: Low down Hillbilly |
After installing the control arms + brakes, I went to finish up by connecting the e-brake cables to find the cable housing to be about 35mm too short to reach to the bracket on the backing plate. I'm pretty sure I ordered the right ones for the year of the pan, so decided to make a couple of extensions from scrap laying around my work bench. If I'd painted it black, you'd likely never notice.
Posted: Sat Mar 01, 2025 7:54 pm Post subject: Re: Low down Hillbilly |
The rear tailing arm bushings, axle bearings, seals and brakes are finished, but still need the e-brake cables shortened. The rear shocks are temporarily mounted to support the weight of the control arms until I can pick up the correct length bolts. Most of the remaining small parts including the spring plate deletes, axle shafts, extinquisher mount, etc are now primered in anticipation of colour matching them to the interior, tomorrow. It'll soon be back on the ground with some additional work/paint to the front beam.
Posted: Tue Mar 04, 2025 10:06 pm Post subject: Re: Low down Hillbilly |
The four spring plate delete pieces, fire extinguisher bracket and drive axles have now been base coated silver, currently waiting for a second coat/clear as it was raining today and I couldn't paint outside. I did however dissolve the old axle grease using Gunk and followed up by scrubbing the CVs clean with Simple Green, which was very effective. They are now ready to pack with grease and install along with new boot kits. The black one on the upper right appears aftermarket as the other three are shiny silver and have VW symbols on them. All the CVs seem to be in good condition and move smoothly/freely for their age.
Posted: Wed Mar 05, 2025 2:59 pm Post subject: Re: Low down Hillbilly |
What color is the body going to be? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Wed Mar 05, 2025 10:18 pm Post subject: Re: Low down Hillbilly |
I've owned the shell for more than 20 years, I don't think I can envision it as any other colour than a shade of blue with a white roof.
As the build is themed along the lines of a 'custom resto-mod-sorta-low buck race car from the late '60s', I've been planning to paint the body, gas & air tanks a flat-cleared period colour like L31 Dove blue which was common for the VW bus at that time. The bomber seats, roll cage, a few suspension and other details are being painted Volvo Lava Sand metallic to match the console/steering support. I will likely have the exhaust Cerakoted at a local shop as it's still way cheaper than a good stainless steel system, I like the look of the glacier titanium coating which fits well with the grey/silver metallic aspects of the build. I'm mixing the gloss, satin and flat textures in with basic solid colours and metallics to add some attitude to the look without it looking too 'rat rod-ish'. |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 387 Location: Noblesville, IN
Posted: Fri Mar 07, 2025 12:06 pm Post subject: Re: Low down Hillbilly |
OCD Garage wrote: |
I've been planning to paint the body, gas & air tanks a flat-cleared period colour like L31 Dove blue which was common for the VW bus at that time. |
Have you looked at Gulf Blue (L390). Lighter and less grey than Dove Blue. And would look awesome with the white top.
I am a bit partial to it.  _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Posted: Fri Mar 07, 2025 12:53 pm Post subject: Re: Low down Hillbilly |
Kafer_Mike wrote: |
OCD Garage wrote: |
I am a bit partial to it.  |
Thanks for the suggestion, I've been looking at a number of those factory blue colours for awhile now. I find when looking at various pictures online sometimes they look the same (or very close) depending on lighting, primer colour, who mixed the paint, etc.
A slightly lighter shade as you suggest would look good too. I am trying to go for 'less cute, more moody/annoyed looking', but haven't made any decisions yet and the final body work/paint for the shell will likely happen next year. I'm trying to concentrate on getting everything together, wired and running this year, but I want to paint the air and fuel tanks soon to match the body... |
