TheGrafs Samba Member
Joined: May 07, 2012 Posts: 254 Location: Utica, New York
Posted: Mon Sep 04, 2023 5:15 pm Post subject: Wheel fitment for Empi Wilwood brakes on Type 3 |
Hey there Samba! A few years back I decided to upgrade to the Wilwood brake kit for the Type 3 on my squareback. Well worth the upgrade, these work incredibly well! These were a collaboration with Empi and they fit type 1 applications as well. I decided to buy mine bare to paint and color matched them, and applied decals I made on my vinyl cutter!
At the time, I was running these white stockies that came with my fastback and I went to mount them on the car, there was a bulge on the inner barrels of both wheels around where the valve stem was that didnt clear the caliper. I am aware of the different offsets between Type 1 and Type 3 stock steelies, but I couldnt find a stamping on these. Here's a pic of them on the car before the wilwoods.
Here's how they hit the caliper.
So the classic painters mistake, fit before paint didnt happen and I went wild and did this.
So then I decided to switch wheels again and try my freshly painted Marathon/ Baja Champion SE wheels, an ET34 offset like other type 1 applications. The way the spokes wrap into the barrel, No dice. Wheel wouldnt even turn past each spoke.
So I resorted to running my Superior industries Volks Mags or Turtleback wheels, and aside from rubbing on the sticky weight on the inner barrel, no clearance issues!
So then the fun house began and I checked every wheel in my collection.
My Ronal Kleeblatt's (Pre-restoration)
My Lemmerz Sprint Stars (pardon the bird-poo)
Sprint Star backside
A stock wheel I had I believe to be a correct type 3 steelie, cant see the stamping due to paint filling it in, but fits better than those cream colored steelies that came with my fasty. No "Bulge" around where the valve stem was.
And even this Lemmerz Super Beetle GT wheel I had one of I tried for fun.
This thread is more or less for reference for those considering this brake upgrade and my trial and error of wheel fitment and painting.
Feel free to share your experiences! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Youtube: GrafsGarage3
Instagram: GrafsGarage |
Posted: Mon Oct 16, 2023 5:41 pm Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
Sherlock cracked the code and Im sure to most with more wheel knowledge, this is a known fact…. Some steel wheels have indents near the valve stem, and a bulge on the back side like I mentioned earlier. While going through my stack on wheels to paint for my fasty, I ran into it first hand, then compared them to the white wheels from my fasty.
Without the bulge
With the bulge
Any information guru’s know the difference? Different years possibly? _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
stonewood Samba Member
Joined: November 01, 2006 Posts: 11 Location: Germany
Posted: Sat Nov 02, 2024 8:30 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
So which rim is now your favorite and works with the Wilwood system?
I also thinkig about to change in the future the brake system to a Wilwood system. _________________ 1977 Karmann Mobil
1967 1300L beetle |
Posted: Wed Jan 15, 2025 6:40 pm Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
| stonewood wrote: |
I also thinkig about to change in the future the brake system to a Wilwood system. |
Hey Stonewood! I will need to update this thread in spring. I got 1/4” spacers and the marathons clear! Plan to run them in spring! This past year I ran my sprint stars! I have these same brake calipers going on my 66 fastback so Ill share these wheel selections amongst that car too! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Thu Jan 16, 2025 5:02 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
I'm looking forward which combination do you take on your car. _________________ 1977 Karmann Mobil
1967 1300L beetle |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3896 Location: Eastern WA
Posted: Fri Jan 17, 2025 11:03 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
I'm running the EMPI repo 4 lug Gas Burners on my 80 Ghia and Wilwood calipers, clear fine with no spacers. I'm using balance beads, so not sure if external weights would clear
_________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Sat Jan 18, 2025 4:35 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
Do you have pictures with gasburners and the Wilwood calipers about the space between? _________________ 1977 Karmann Mobil
1967 1300L beetle |
Teeroy  Samba Member
Posted: Sat Jan 18, 2025 9:49 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
No, but it's on the lift now I'll see if I can get some decent shots when I go out to the shop today _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Teeroy  Samba Member
Posted: Sat Jan 18, 2025 3:50 pm Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
Here you go
ARR #3
Posted: Sun Jan 19, 2025 6:05 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
Thanks for the pictures.
Looks like there is a lot of space between the rim and the caliper. _________________ 1977 Karmann Mobil
1967 1300L beetle |
Teeroy  Samba Member
Posted: Sun Jan 19, 2025 9:31 am Post subject: Re: Wheel fitment for Empi Wilwood brakes on Type 3 |
Yes there is, they stick out a lot less than the stock caliper _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
